8th October 2013, 19:46 | #7681 | Link |
Yes, but I meant that it's useful when you wanna go to the next title by clicking next (chapter) with the player's remote when you wanna go to the second title before the end of the first.
If you don't check "add chapter at title end", I believe nothing will happen if you click on next if you are in the last chapter of the first title (or if there is no chapter in this first title, which means that the first chapter is also the last, going from title's debut to its end). |
10th October 2013, 02:57 | #7684 | Link | |
http://forum.doom9.org/showpost.php?...1&postcount=20 Last edited by mariner; 10th October 2013 at 03:00. |
11th October 2013, 13:10 | #7685 | Link |
weird how multiAVCHD can chunk all the files into 4GB blocks, and play them seamlessly, but can't transition from each source without a hiccup ? That makes no sense and should be easily accomplished, but I just can't figure it out.
14th October 2013, 04:39 | #7687 | Link | |
Anyway, I think I solved the issue by locating the correct playlist associated with the source files, and used that as the project source. |
14th October 2013, 14:35 | #7689 | Link | |
If that hadn't worked, I would have tried joining. |
14th October 2013, 16:20 | #7691 | Link |
I figured out how the total time of the videos. Added full BDMV folder to multi. Selected "re-author". Figured out which playlist was the total time. Selected "top 3" to import instead of "all". Removed the 2 that were not of interest. Then processed it.
31st October 2013, 08:22 | #7695 | Link |
I don't know but sometimes, the simple fact to re-start multiAVCHD helps (I often have crashes when I start export and when I make it again there's no problem ).
That's why it's important to save the project before to start the export, you just have to open the project after re-start. |
