6th March 2009, 15:27 | #1841 | Link | |
Aging Video Hobbyist
6th March 2009, 15:55 | #1842 | Link |
Hi mate,
Yes i`ve managed to do about a dozen but it fails with the same error on a few; Mr and Mrs Smith Deja Vu Independence day please help if you can or let me know what all the settings should be in the various apps? Kind regards |
6th March 2009, 16:05 | #1843 | Link | |
EDIT - This is using wmv11 decoder, however most 1080i stuff in VC1 is fine. Could just be that you got unlucky and your discs all have the hybrid VC1....Depends how many we're talking tho. I doubt you'd be so unlucky as to have 10 of 10 of your discs for example etc. Last edited by Furiousflea; 6th March 2009 at 16:08. |
6th March 2009, 19:02 | #1848 | Link | |
Should help you out abit, note though that you can't keep menus when you convert but you can keep all audio streams\subs etc. |
6th March 2009, 22:10 | #1851 | Link |
Sounds like a setup problem or BD_Rebuilder\tools\tsmuxer.exe missing, can you check to see if this file exists?
If it does, can you try downloading BD-RB and put it in a fresh directory and without changing any settings except loading in the source and working? If still no luck can you paste your the AUD_<M2TS>.meta file? |
6th March 2009, 22:21 | #1852 | Link | |
According to neuron2's tools, there ain't nothin' "hybrid" about these clips, they are just interlaced VC-1. How to ID a hybrid clip--must be a better way than "something that crashes my PC"! EDIT: OK I loaded-up one of those nasty extras (00289.m2ts) from Mamma Mia! and used neuron2's tool to go step-by-step thru the fields, and it is indeed more odd than anything I've seen before. This clip starts with ABBA concert footage, most likely video camera footage because every field is different (although many are blended--very ugly) and then it cuts to location footage of the cast & crew, which is in a 2,2,2... cadence (same field twice) so was maybe shot with a high-def video camera or something; I dunno but it doesn't seem to be film. Also eac3to calls it "60i /1.001" while MediaInfo says 29.97 so confusion reigns. IIRC in BD-RB the decoder works for a bit before crashing (looks like a x264 error but is clearly decoder) so it must be the 2:2 material it's crashing on, a few seconds into the clip. Last edited by laserfan; 6th March 2009 at 23:04. |
6th March 2009, 23:31 | #1854 | Link |
Hi Jdobbs,
at first nice app,.... ;-) So, in my case my panasonic bd-55 doesn't play any remastered movie which was made with bd rebuilder when the player is using 24p playback mode, but after deactivate 24p everything is fine. Any ideas ? Last edited by Lif3styl3; 6th March 2009 at 23:39. |
6th March 2009, 23:43 | #1855 | Link |
Lif3styl3 I think I remember someone else mention this awhile back and I don't recall a workaround for it. It was before BD-RB came out and I think every compatible encoded video suffers from it.
Perhaps it should be mentioned in the first post of the list of compatible players thread but I'm not sure which Panasonic models are affected besides the BD55. I will check if Panasonic BD30 has the issue. Last edited by turbojet; 6th March 2009 at 23:46. |
7th March 2009, 08:36 | #1856 | Link | |
Hi.
I was doing The Mummy 3 (german). But I got an Error message at build and also at Rebuild (at "CorrectMPLS() 00009 5"): Quote:
[Status] LABEL=MUMMY_3TODE_G51 VERSION=v0.20.02 (beta) SOURCE_SIZE=49198008571 SOURCE_VIDEO_SIZE=44728922112 TARGET_SIZE=24589107200 REDUCTION=.449821274266794 RESIZE_1080=0 AUDIO_TO_KEEP=deu;eng;fra;fre;ger;ita;pol;rus; SUBS_TO_KEEP=all BACKUP_MODE=0 QUICK=0 ENCODE_STEP=0 COMPLETED=29 REBUILD_COMPLETE=0 [00009] M2TS_TARGET=15106842043 RATE=13516 AUDIO=0100101 NSIZE=14822965248 FLINK=0 MLINK=0 [00010] M2TS_TARGET=1075853216 RATE=4906 AUDIO=1 NSIZE=1064706048 FLINK=0 MLINK=0 [00057] M2TS_TARGET=96773786 RATE=2379 AUDIO= NSIZE=62803968 FLINK=0 MLINK=0 [00071] M2TS_TARGET=675219359 RATE=4352 AUDIO=1 NSIZE=666359808 FLINK=0 MLINK=0 [00072] M2TS_TARGET=726538540 AUDIO=1 NSIZE=1130201088 FLINK=0 MLINK=0 [00073] M2TS_TARGET=187423209 RATE=1844 AUDIO=1 NSIZE=193443840 FLINK=0 MLINK=0 [00075] M2TS_TARGET=158758092 RATE=1964 AUDIO=1 NSIZE=162969600 FLINK=0 MLINK=0 [00076] M2TS_TARGET=169409400 RATE=1977 AUDIO=1 NSIZE=173684736 FLINK=0 MLINK=0 [00077] M2TS_TARGET=210466955 RATE=1984 AUDIO=1 NSIZE=217012224 FLINK=0 MLINK=0 [00084] M2TS_TARGET=104155634 RATE=7004 AUDIO=01111011 NSIZE=106536960 FLINK=0 MLINK=0 [00086] M2TS_TARGET=115102657 RATE=6883 AUDIO=01111011 NSIZE=117792768 FLINK=0 MLINK=0 [00088] M2TS_TARGET=155190153 RATE=6771 AUDIO=01111011 NSIZE=156628992 FLINK=0 MLINK=0 [00090] M2TS_TARGET=248105811 RATE=6597 AUDIO=01111011 NSIZE=258035712 FLINK=0 MLINK=0 [00094] M2TS_TARGET=105053837 RATE=8910 AUDIO=01111011 NSIZE=118671360 FLINK=0 MLINK=0 [00098] M2TS_TARGET=107145959 RATE=7347 AUDIO=01111011 NSIZE=130676736 FLINK=0 MLINK=0 [00099] M2TS_TARGET=104144579 RATE=7005 AUDIO=01111011 NSIZE=105547776 FLINK=0 MLINK=0 [00100] M2TS_TARGET=104150106 RATE=7005 AUDIO=01111011 NSIZE=107304960 FLINK=0 MLINK=0 [00101] M2TS_TARGET=104191562 RATE=7010 AUDIO=01111011 NSIZE=107888640 FLINK=0 MLINK=0 [00102] M2TS_TARGET=114566499 RATE=6828 AUDIO=01111011 NSIZE=137650176 FLINK=0 MLINK=0 [00103] M2TS_TARGET=115116476 RATE=6884 AUDIO=01111011 NSIZE=118069248 FLINK=0 MLINK=0 [00104] M2TS_TARGET=156417237 RATE=6862 AUDIO=01111011 NSIZE=200650752 FLINK=0 MLINK=0 [00105] M2TS_TARGET=155201208 RATE=6772 AUDIO=01111011 NSIZE=157083648 FLINK=0 MLINK=0 [00106] M2TS_TARGET=287516201 RATE=8460 AUDIO=01111011 NSIZE=316059648 FLINK=0 MLINK=0 [00107] M2TS_TARGET=248086466 RATE=6597 AUDIO=01111011 NSIZE=257126400 FLINK=0 MLINK=0 [00108] M2TS_TARGET=248080938 RATE=6596 AUDIO=01111011 NSIZE=254435328 FLINK=0 MLINK=0 [00109] M2TS_TARGET=248105811 RATE=6597 AUDIO=01111011 NSIZE=256591872 FLINK=0 MLINK=0 [00317] M2TS_TARGET=154543447 RATE=4903 AUDIO=1 NSIZE=156082176 FLINK=0 MLINK=0 [00334] M2TS_TARGET=155203972 RATE=6772 AUDIO=01111011 NSIZE=157065216 FLINK=0 MLINK=0 [00335] M2TS_TARGET=155212263 RATE=6773 AUDIO=01111011 NSIZE=158097408 FLINK=0 MLINK=0 Bye |
7th March 2009, 09:59 | #1858 | Link | |
This would make sense on a movie only encode with only one audio stream. Your original Bluray may well be 40GB+ in size but of that 40GB only around half of it will usually be the main move and one audio track, often much less. Couple that with x264 being a very efficient codec and it could be that you've just topped out. ^ my guess anyway EDIT - What size is the main move before encoding anyway? How many audio tracks are in it to start with and at what quality? This is really obvious information you should be handing over if you want help. |
7th March 2009, 10:07 | #1859 | Link | |
