18th January 2013, 17:08 | #12061 | Link |
Banned
Move the Demux?!?!
I am a BIG FAN of RipBot264 ... absolutely great work.
I was wondering if there was any plan to move the initial demux to the actual processing stage. Right now, you choose an input, and a chapter, and then the computer proceeds to do 5 minutes of processing before presenting you with a screen which lets you choose a filename and options. The default options work for me just fine, which means that it is a 5 minute wait to enter a filename. When ripping multiple TV episodes, this can be hours just to set up the queue. Is there any way you would consider allowing a way to enter the filename and accept whatever default would have happened if it went through the 5 minutes, and leave that initial processing to the actual transcode? Thanks! |
18th January 2013, 17:21 | #12062 | Link | ||
@Red Fish Are you sure that you have enough space on C: partition? Is your movie correctly decrypted with latest version of AnyDVD HD? @bugmen0t I will think about it. I do not promise anything...
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 18th January 2013 at 17:27. |
18th January 2013, 17:35 | #12063 | Link |
I have over 500 gb space on my C drive. The movie was decrypted with latest version of DVD fab. Is that an issue? As I mentioned others are working fine, just a few recent new ones. Perhaps different audio streams? Still kinda new to all this. Thanks
18th January 2013, 18:18 | #12064 | Link |
Try again with ANYDVD HD to be sure.
19th January 2013, 07:05 | #12067 | Link |
Atak_Snajpera:
When I encoded the video (framesize of source video=704x480) always remains at 4:3, then I put in the command line --sar 1:1 to avoid this. It should be the default value 1:1. With other programs as TX264 and Bencos the result is fine. Another thing: once more ask please check the duration of the audio when muxed with video, can be cut and only with YAMB to separate and reassemble to correct the problem. Thank you. Last edited by GMJCZP; 19th January 2013 at 08:13. Reason: Added framesize of source video |
19th January 2013, 12:12 | #12068 | Link |
Hello,
I have a problem with Ripbot. I cannot encode anything, when I load a file and press encode it encodes the video instandly without an output. I downloaded the program several times reinstalled all codecs and required programs, everything on default but the same problem every time. I tried several different video files. I'm using windows 8 X64. Thanks, Last edited by godfavor; 19th January 2013 at 12:16. |
19th January 2013, 12:25 | #12069 | Link |
ripbot always checks source aspect ratio . in your case madiainfo detected your file as 4/3 . in order to have correct aspect ratio during playback ripbot calculates correct sar value . in your case --sar 0.909:1000.
when you use 1:1 your video file will have incorrect proportions 1.46:1 . that kind of aspect ratio does not exist in movie industry.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 19th January 2013 at 12:44. |
19th January 2013, 12:26 | #12070 | Link | |
19th January 2013, 12:30 | #12071 | Link |
You mean the Job1_log.txt?
C:\>"C:\Users\Θεοχάρης\Documents\Ripbot\tools\avs2yuv\avs2yuv.exe" "C:\Temp\RipBot264temp\job1\job1.avs" -o - | "C:\Users\Θεοχάρης\Documents\Ripbot\tools\x264\x264_x64.exe" --crf 20 --stats "C:\Temp\RipBot264temp\job1\job1.stats" --fps 24000/1001 --force-cfr --min-keyint 24 --keyint 240 --frames 181626 --sar 1:1 --level 4.0 --aud --nal-hrd vbr --vbv-bufsize 25000 --vbv-maxrate 25000 --b-pyramid none --stdin y4m --output "C:\Temp\RipBot264temp\video.264" - ’¦ ©η©«ž£˜ ›œ¤ œε¤˜* ©œ Ÿβ©ž ¤˜ œ¤«¦§ε©œ* «ž¤ ΅˜Ÿ¦¨*©£β¤ž ›*˜›¨¦£γ ›ε©΅¦¬. C:\>"C:\Users\Θεοχάρης\Documents\Ripbot\tools\mkvtoolnix\mkvmerge.exe" -o "C:\Users\Θεοχάρης\Desktop\Hugo (2011) 3D Half-SBS.mkv" --compression 0:none --title "Hugo (2011) 3D Half-SBS" --default-duration 0:24000/1001fps "C:\Temp\RipBot264temp\video.264" --forced-track 0:yes --language 0:ell -s 0 -D -A "C:\Temp\RipBot264temp\job1\Hugo (2011) 3D Half-SBS.ass" ’¦ ©η©«ž£˜ ›œ¤ œε¤˜* ©œ Ÿβ©ž ¤˜ œ¤«¦§ε©œ* «ž¤ ΅˜Ÿ¦¨*©£β¤ž ›*˜›¨¦£γ ›ε©΅¦¬. ------------------------- Elapsed Time: 00h:00m:00s |
19th January 2013, 12:34 | #12072 | Link |
move ripbot folder to location without national characters in path. for example c:/program files(x86)/ripbot264
21st January 2013, 00:10 | #12075 | Link |
any fix for gathering information? I have read all posts in this thread and have tried all suggestions but nothing. I have windows server 2008 x64. Rip bot stuck on gathering information. I use ripbot in my desktop pc and my laptop both have windows 8 installed and everything is ok but in my vps not work.
21st January 2013, 17:50 | #12076 | Link | |
21st January 2013, 18:38 | #12077 | Link | |
With that, I'll be able to determine if the issue is with the stream or your processing. What VC-1 decoder are you using? |
22nd January 2013, 19:49 | #12078 | Link | |
Here is the link to the first 100 MB: http://www.mediafire.com/?0wqkbwq6mei5baa |
22nd January 2013, 19:59 | #12079 | Link | |
