Old 21st March 2011, 22:46   #41  |  Link
*.mp4 guy
*.mp4 guy's Avatar
Originally Posted by tritical View Post
Under what [arbitrary] definition of close?
If the avisynth linear interpolators could use an infinite sinc kernel, and and the input to the interpolator is a perfectly bandlimited signal capable of being properly sampled at the destination resolution, then the support width calculations used by avisynth guarantee perfect reconstruction at the destination resolution, and any other arbitrary resolution that does not cause sub-critical sampling to occur.
Certainly it does not completely capture the only thing that really matters for image processing - the perceived quality of the person doing the resizing.
In my opinion, it is overall the best compromise. Avisynth resizers certainly look much better then the abysmal interpolators used on most dvds; said dvds either being blurred to hell, with accompanying gibbs artifacts or have aliasing everywhere.
*.mp4 guy is offline   Reply With Quote
Old 23rd March 2011, 13:30   #42  |  Link
Sapo84
I think that YV12 output is a bit broken at the moment, and there are visible artefacts, in particular they are pretty obvious near reds border.
But, well, let's make screenshots speak.
ResampleHQ(1280,720,"YV12","TV.709","TV.709",false,198,22,-48,-164)
http://www.cbland.net/images4/ResampleHQYV12.png
around the red circle there are obvious problems with the resampler output
Spline36Resize(1280,720,198,22,-48,-164)
http://www.cbland.net/images4/SplineYV12.png
on the other hand Spline36's output is perfect
and if we convert to RGB32
ResampleHQ(1280,720,"RGB32","TV.709","TV.709",false,198,22,-48,-164)
http://www.cbland.net/images4/ResampleHQRGB32.png
there are no more artefacts
Spline36Resize(1280,720,198,22,-48,-164).ConverttoRGB32(matrix="Rec709")
http://www.cbland.net/images4/SplineRGB32.png
Spline is good as well.
Using different matrix/crop/dither did not change the outcome at all.
Sapo84 is offline   Reply With Quote
Old 23rd March 2011, 18:13   #43  |  Link
PhrostByte
Grand Fruitioner
PhrostByte's Avatar
Confirmed. I'll look for a solution. Chroma sub-sampling is evil.
PhrostByte is offline   Reply With Quote
Old 24th March 2011, 03:37   #44  |  Link
henryho_hk
Sapo84, can we have the original picture for comparsion? And what program do you use to extract the PNG file from a YV12 AVS?
henryho_hk is offline   Reply With Quote
Old 24th March 2011, 10:22   #45  |  Link
Dogway
Yes, I can confirm it, YV12 is totally broken. Even the next line outputs wrong results:
# converting from RGB to YV12
ResampleHQ(DSTCOLORSPACE="YV12",dither=false)
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 24th March 2011, 10:35   #46  |  Link
Sapo84
Sure.
http://www.cbland.net/images4/notresampled.png
AvsPmod.
Now that you can even specify the matrix used to convert from YV12 to RGB32 during playback is basically the swiss knife of avisynth ^^
Old 25th March 2011, 01:07   #47  |  Link
PhrostByte
Grand Fruitioner
PhrostByte's Avatar
This is turning out to be a tricky problem to solve. It occurs whenever sub-sampled YUV is converted between gamma-compressed and linear.
You can't go directly from YUV -> linear YUV. You need to do YUV -> RGB -> linear RGB -> linear YUV.
When it is sub-sampled, you run into the same problem run-of-the-mill renderers do: when converting to RGB the chroma isn't rescaled nicely, but simply point sampled.
I wanted to avoid rescaling gamma-compressed chroma, but I'm not sure if that's possible now. Any clever ideas?
Old 25th March 2011, 02:47   #48  |  Link
Mug Funky
interlace this!
Mug Funky's Avatar
could the gamma resize be just done on the luma only? chroma exists in chroma-land where gamma makes no sense...
or perhaps the gamma can happen on the chroma channels using a correspondingly subsampled luma channel to convert them to intermediate chroma channels. that might work.
Old 25th March 2011, 04:16   #49  |  Link
PhrostByte
Grand Fruitioner
PhrostByte's Avatar
Chromaticity is independent from luminance. Chroma is dependent on luma. Not the same thing
I thought of sub-sampling luma too, but I haven't tried it yet. Will report back in a bit
Old 25th March 2011, 07:54   #50  |  Link
madshi
Resampling luma will change the luma and chroma value of every pixel. So if you want resampling to be done with proper quality, I don't think you have any chance of avoiding doing proper chroma upsampling as a first step. Of course that means that the output of your filter should probably be either RGB or YCbCr 4:4:4 because otherwise chroma will lose quality. For chroma upsampling I'd suggest a soft filter to avoid aliasing artifacts.
Old 25th March 2011, 14:25   #51  |  Link
Gavino
Avisynth language lover
If the final output is to be YV12, the chroma accuracy could potentially be improved by having a separate chroma conversion path using resampled luma. Instead of effectively doing this:
YV12->YV24->sRGB->linear RGB->resample->sRGB->YV24->YV12
which involves chroma resampling as both the first and last steps, do this:
YV12->YV24->sRGB->linear RGB->resample->sRGB->luma
and
YV12->resample luma to chroma grid->sRGB->linear RGB->resample to destn chroma grid->sRGB->chroma
Whether this would make a visible difference, I don't know.
Old 26th March 2011, 19:03   #52  |  Link
kolak
This has also chroma problems- not as visible as direct YV12, but visible enough.
Andrew
Old 30th March 2011, 02:07   #53  |  Link
PhrostByte
Grand Fruitioner
PhrostByte's Avatar
Got caught up in Crysis 2 for most of this past week -- it's like a frakkin' Michael Bay movie in all the right ways.
I'm going full-speed on ResampleHQ now. Should have something new up in the next couple days.
Old 5th April 2011, 19:02   #54  |  Link
PhrostByte
Grand Fruitioner
PhrostByte's Avatar
I'm going to default it to bilinear like Avisynth does, but let it be customized. Can you post code for the SoftCubic kernel you use? I'd like to add support for it.
Old 5th April 2011, 19:09   #55  |  Link
madshi
Ok, here goes:
float Cubic(float distance, float param1, float param2)
// return cubic weight coefficients
  float P0, P1, P2, P3;
  float result = 0;
  if (distance <= 2.0f)
    if (distance < 1.0f)
      P0 = (+ 1.0f - 1.0f/3.0f * param1 - 0.0f * param2);
      P1 = 0;
      P2 = (- 3.0f + 2.0f      * param1 + 1.0f * param2);
      P3 = (+ 2.0f - 3.0f/2.0f * param1 - 1.0f * param2);
    } else {
      P0 = (- 0.0f + 4.0f/3.0f * param1 + 4.0f * param2);
      P1 = (+ 0.0f - 2.0f      * param1 - 8.0f * param2);
      P2 = (- 0.0f + 1.0f      * param1 + 5.0f * param2);
      P3 = (+ 0.0f - 1.0f/6.0f * param1 - 1.0f * param2);
    result = P0 + P1 * distance + P2 * distance * distance + P3 * distance * distance * distance;
  return result;
float GetFilterCoeffs(float distance, RESAMPLING_FILTER filter)
// return coeffecients for the specified resampling filter
  float result = 0;
  switch (filter)
    case rfCatmullRom     :
    case rfBicubic50      : result = Cubic(distance, 0.00f, 0.50f); break;
    case rfBicubic60      : result = Cubic(distance, 0.00f, 0.60f); break;
    case rfBicubic75      : result = Cubic(distance, 0.00f, 0.75f); break;
    case rfSoftCubic100   : result = Cubic(distance, 1.00f, 0.00f); break;
    case rfSoftCubic80    : result = Cubic(distance, 0.80f, 0.20f); break;
    case rfSoftCubic70    : result = Cubic(distance, 0.70f, 0.30f); break;
    case rfSoftCubic60    : result = Cubic(distance, 0.60f, 0.40f); break;
    case rfSoftCubic50    : result = Cubic(distance, 0.50f, 0.50f); break;
    case rfMitchell       : result = Cubic(distance, 1.0f/3.0f, 1.0f/3.0f); break;
Old 5th April 2011, 19:37   #56  |  Link
Gavino
Looks like that is just the same as Avisynth's BicubicResize, where param1 and param2 represent the b and c arguments.
Then, in the 'soft' settings, used with 0.5<= b <=1 and c = 1-b.
Old 5th April 2011, 20:44   #57  |  Link
madshi
Is it? Well, there's only one way to do the math correctly, I guess...
Old 5th April 2011, 21:50   #58  |  Link
Gavino
Actually, there is more than one way of doing it. In the Avisynth implementation, your line:
is effectively replaced by:
    result = P0 + distance * (P1 + distance * (P2 + distance * P3));
which is marginally faster (fewer multiplies).
Old 6th April 2011, 05:24   #59  |  Link
PhrostByte
Grand Fruitioner
PhrostByte's Avatar
Ok, here goes:
Thanks!
So it does.
Old 7th April 2011, 03:18   #60  |  Link
henryho_hk
Found an interesting diagram about cubic resizers: http://www.imagemagick.org/Usage/resize/#mitchell
