27th December 2019, 06:26 | #141 | Link | |
31st March 2020, 11:01 | #142 | Link |
Hi there,
Iv'e searched many times but couldn't find what I'm looking for. My question is, can I use any filter of Avisynth separately. For example, someone gave me an encoded video and I wanna apply some filter on it without encoding it again? is that possible by command line or any other way? Thanks. |
31st March 2020, 11:29 | #143 | Link | |
ffmpeg filters: https://mpv.io/manual/master/#video-filters vapoursynth filters: https://mpv.io/manual/master/#video-filters-vapoursynth per file configuration: https://mpv.io/manual/master/#file-s...guration-files
31st March 2020, 11:38 | #144 | Link |
Mertiz88,
If you have ffdshow installed it has an Avisynth filter and you can add most things to it. "Add ffdshow video source" usually needs to be checked near the top of the Avisynth filter section. You can probably install only the ffdshow raw video filter and add it to MPC-HC as an external filter and add Avisynth stuff to it. I don't use Potplayer, but it has an Avisynth section in it's options so it should do much the same. Or you could create a script to open the video and audio, add filters to it, then open the script with a media player such as MPC-HC. ie LoadPlugin("C:\Program Files\MeGUI\tools\ffms\ffms2.dll") FFMS2("E:\Episode 7.mkv") SomeFilter() You'll probably have to be careful not to use any filtering that's too slow to allow real-time playback. |
31st March 2020, 12:14 | #145 | Link |
There is also a new-ish video source for VLC [ VLC - AviSynth plugin ]:- https://forum.doom9.org/showthread.php?t=178531
31st March 2020, 17:05 | #146 | Link |
Thanks guys for great information, much appreciated!!
I'm still newbie for these stuff (like using or adding filters of (avisynth/vapoursynth) to other softwares). I just used handbrake to encode some videos and found out they need to be denoised (slightly) but couldn't do that with its filters (NLMeans & HQDN3D). So, I intended to filter them with staxrip at first and then thought about doing that separately by (avisynth/vapoursynth). What I meant, I want a new video to be created (like 'render' in some video editors) but with exactly the same encode settings (CRF, subme, ref, ....etc) i.e. only the filter will be applied. Is that even possible with the methods you mentioned above OR the filter's effect will remain only in the media player (VLC/mpv/MPC). If you can explain with some details, I'll be thankful! Last edited by Mertiz88; 1st April 2020 at 11:33. |
2nd April 2020, 04:54 | #147 | Link |
Filtering interlaced content:
Reading: http://avisynth.nl/index.php/FAQ_dif...ced_content.3F I'm wondering whether: Code:
AssumeXY().Bob().Filter(...).AssumeXY().Separatefields().Selectevery(4,0,3).Weave() Code:
SeparateFields() even = SelectEven(last).Filter(...) odd = SelectOdd(last).Filter(...) Interleave(even, odd) Weave() What do you think is 'better' and why? Is it depended on the following filter or is one always better than the other. Note: that I don't care that the first method adds an additional bobber and the time it takes,... Cu Selur |
2nd April 2020, 07:03 | #148 | Link | |
It depends on source, and what you are doing, obviously Not bob() for the first case - use a smarter double rate deinterlacer that corrects for the up/down field shift. It's pros /cons - In the 1st case you have to deinterlace, but you can use temporal filter more effectively In the 2nd case, you don't get temporal filtering between even/odd fields, only within each group. Motion vectors don't cross between even/odd because they are grouped separately. This can induce a type of flicker on some sources. But on the other hand some sources may require separate filtering (eg. some defect occurs on even fields, maybe more noise or more saturated etc...) . Using the 1st method will "contaminate" the good fields in those cases |
2nd April 2020, 14:02 | #149 | Link | ||
2nd April 2020, 16:43 | #150 | Link |
And how is it for spatial filtering?
In the 'bob' case the spatial filtering is basically done for the original field and the synthesized other field. In the 'even/odd' case the spatial filtering is done intra-field (the original fields) only. Is this correct? Is one method better than the other, or does it also depend on the source? Some noise filters are spatial-temporal; is there a clear preference for these, or is it also source dependent (I tend to believe so). Last edited by Sharc; 2nd April 2020 at 16:49. |
7th July 2020, 23:51 | #151 | Link |
Broadcast Encoder
Question about the wiki.
In the VapourSource page it says: "*Y8/YV12/16/24 allow bit depths >8 using the Stack16 format." however when I look at the color spaces themselves like YUV420P16 it says "YV12 (x2 width)". I haven't tried to output anything through VapourSource 'cause I don't have VapourSynth installed, but to me "x2 width" means DoubleWidth which is 16bit interleaved NOT 16bit stacked (which is double height). Is it outputting 16bit stacked or interleaved? Is it 2x height so 16bit stacked or 2x width so 16bit interleaved? I'm asking 'cause I generally correct the wiki when I find boo boos and I like everything to be right. p.s yes, wiki maintainers, if you found out some pages (like this) silently and "auto-magically" updating themselves, it wasn't dark magic, it was me xD Last edited by FranceBB; 8th July 2020 at 00:15. |
8th July 2020, 15:59 | #153 | Link | |
but in avs+ it will output HBD I think you should re-stated that lsb in most filters mean stacked in http://avisynth.nl/index.php/ConvertStacked since there are many n00bs users
See My Avisynth Stuff |
9th July 2020, 09:03 | #154 | Link | ||
Broadcast Encoder
8th December 2020, 22:16 | #155 | Link |
It is possible to insert Unicode char into text, rendered by Subtitle() function ?
Trying Subtitle(c, +Chr($2022),font="Arial",size=isize,x=10,y=20,halo_color=$FF000000, text_color=$00e0e0e0,utf8=true) to rasterize 'bullet' char with code 0x2022 and it prints " - symbol with code 0x22. I.e. it ignores first byte. May I need somehow StrToUTF8() ? I set font to Arial and looks for the char code in the Insert->Symbol window. Using Avisynth+. |
8th December 2020, 22:50 | #156 | Link |
Formerly davidh*****
Not in general, it seems (edit: wrong, see below), but that particular character does exist in whatever the default Windows ASCII character set is these days, and can be typed directly into your script with "ALT+7".
EDIT: Got it. You can do it, but you have to use the full UTF-8 encoding spelled out in bytes, and specify utf8 = true: Code:
subtitle(chr($E2) + chr($80) + chr($A2), utf8 = true) Code:
subtitle("•", utf8 = true) Last edited by wonkey_monkey; 8th December 2020 at 22:57. |
8th December 2020, 23:08 | #157 | Link |
Try Chr($95)
Function SubtitleCharSet() { S="" for(y=0,15) { s=s+"$"+RT_Hex(y*16,2)+ " " for(x=0,15) { n=y*16+x c=(n<32) ? "." : Chr(n) s=s+c } s=s+"\n" } S } colorbars(width=360,height=512).Trim(0,-1).KillAudio s=RT_StrReplace(SubtitleCharSet,Chr(10),"\n") Subtitle(s,font="Courier New",size=32,lsp=0) return Last EDIT Code:
BlankClip(Length=1,width=20,height=20) Bullet=Chr($95) Subtitle(Bullet) return last Code:
BlankClip(Length=1,width=20,height=20) Bullet=Chr($95) Subtitle(Bullet) BilinearResize(80,80) return last
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 8th December 2020 at 23:41. |
8th December 2020, 23:37 | #158 | Link |
Wait, something's not right there... $80 is the Euro symbol, that's correct, but the ellipsis (…) should be $85. Your graphic shows it at position 84.
Likewise the • symbol sould be $95, but it's at position $94. Characters $90 and $81 do not encode to anything. There are other missing characters too. |
8th December 2020, 23:49 | #159 | Link |
It depends upon Character Set [EDIT: Font] , I used Courier New [which is MonoSpaced to maintain format of the hex/ascii block]
8th December 2020, 23:56 | #160 | Link | |
WingDings
Function SubtitleCharSet() { S="" for(y=0,15) { s=s+"$"+RT_Hex(y*16,2)+ " " for(x=0,15) { n=y*16+x c=(n<32) ? "." : Chr(n) s=s+c } s=s+"\n" } S } colorbars(width=880,height=512).Trim(0,-1).KillAudio s=RT_StrReplace(SubtitleCharSet,Chr(10),"\n") #Subtitle(s,font="Courier New",size=32,lsp=0) Subtitle(s,font="Wingdings",size=32,lsp=0) return Last EDIT: Default Character sets of Subtitle(), RT_Subtitle() and RT_DebugF() are all different outside of $20 -> $7E range. EDIT: The Hex/Ascii block prints out chars below 32($20) as '.' as they are usually control characters, some Subtitle() fonts may actually have valid characters for those chars, but we just printed same as '.', as in Hex/ASCII block. Also, the similar-ish stuff on the Left above in Windigs block, are Digits in the hex/ascii block. EDIT: Quote:
[Mentally align with the characters above the euro line] EDIT: hang on. you're right, maybe something strange there. I reccon that something on $80 line prints nothing, dont offhand know which character. [there are spaces at end of line]
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 11th December 2020 at 17:40. |
avisynth, faq |
