Old 7th April 2020, 19:00   #1  |  Link
tugatomsk9
tugatomsk9
VHS capture using Avermedia Game Capture II
Iím thinking of digitally recording my personal motorsports VHS collection that spans over 20 years, but Iím unsure as to what hardware should I buy.
Iíve had a poor experience with a MAGIX usb-pen video capture device. It uses proprietary codecs that are a hassle to configure and the maximum video bitrate is not impressive. Moreover, the audio quality is poor, with noticeable signal noise. This is the reason why I havenít considered ElGatoís video-pen device.
My PC has no available PCI or PCI-e slots available, so fully dedicated video capture cards are not an option.
Then thereís this: the Avermedia Game Capture II. Even though itís mainly designed for videogame capture, but the fact it could work as a standalone video capture device caught my attention.
Can its maximum 14000 kbps using k264/AVC could record interlaced video with good quality, i.e., without interlacing or other artifacts? Also, can this device double the framerate (from 50i to 50p) via hardware directly into a finished video file?
Thanks in advance.
tugatomsk9 is offline   Reply With Quote
Old 8th April 2020, 23:15   #2  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Avermedia Game capture II (115..125€) will employ a hardware encoder.
If its implementation is poor and generates artifacts you can not avoid that.
A Blackmagic Intensity Shuttle USB 3.0 (190..210.-€) can deliver 4:2:2 10bit uncompressed.
From a VHS tape source this would mean: without a visible quality loss.
You may work your Avisynth way from there, enhance, encode as you prefer.
But it needs a dedicated USB 3.0 port to work, see:
https://forum.doom9.org/showthread.p...55#post1847255
"Data reduction ? Yep, Sir. We're working on that issue. Synce invntoin uf lingŲage..."
Old 9th April 2020, 00:30   #3  |  Link
Asmodian
In my testing with my Intensity Shuttle the last two bits of the 10-bit capture, using their software, were 0s when capturing from s-video. This is really a non-issue, uncompressed 8 bit is great for VHS anyway, but I would not bother capturing s-video in 10 bit with the Intensity Shuttle.
I would still recommend it over a hardware encoder.
madVR options explained
Asmodian is online now   Reply With Quote
Old 10th April 2020, 00:30   #4  |  Link
tugatomsk9
tugatomsk9
My motherboard is USB 2.0 only. Does that rule it out?
Old 13th April 2020, 16:53   #5  |  Link
Emulgator
Emulgator's Avatar
Yes, USB 2.0 is excluded, sorry for that.
BTW, just counterchecked one of my samples of Blackmagic Intensity Shuttle captures.
Codec was v210 uncompressed, decoding in Vegas 16 shows a densely populated 10 bit histogram without regular holes.
Old 17th April 2020, 18:50   #6  |  Link
tugatomsk9
tugatomsk9
Thanks for the help anyway, it was much appreciated.
avermedia, capture, gamecapture, vhs
