Old 12th August 2019, 20:16   #1  |  Link
terminator3
Do you know how to avoid this ghosting or eliminate it?
Well, try to remove the interlacing of these avi videos but the source has a ghost effect
Then I leave two videos, they are different since they come from different sources vhs, I know they take a lot, but if you can help me, I would appreciate it.
terminator3 is offline   Reply With Quote
Old 12th August 2019, 23:58   #2  |  Link
real.finder
AVISource("E:\Fly07-08.avi")
AssumeTFF()
tfm.TDecimate(1) #or AnimeIVTC since it old source
work fine no ghosting
See My Avisynth Stuff
Old 14th August 2019, 17:49   #3  |  Link
terminator3
AssumeTFF()
Thank you very much,
From cap 13 or 14 there is no way to avoid ghosting, look
https://drive.google.com/file/d/1vJ8...ew?usp=sharing
Old 15th August 2019, 19:14   #4  |  Link
real.finder
AVISource("E:\Fly17-18.avi")
AssumeTFF()
tfm.TDecimate(1)
work also fine, you must be more specific by tell what frame or time and post image for the problem, and even post your script
Old 15th August 2019, 21:13   #5  |  Link
terminator3
AssumeTFF()
tfm.TDecimate(1)
Well, in the whole chapter, if you download the chapter that I put you last, the whole chapter suffers from ghosting, and also in fast scenes, the lines look as if the interlacing was not effective in the fast scenes
the configuration is the same that you have put before, and so that you see that the ghost effect is, I show you these captures:
and it is here, it seems as if the lines were interlaced, especially on the left side of the image
Old 15th August 2019, 22:32   #6  |  Link
real.finder
ok, I see it now, did you tried animeivtc(2) or sanimebob.srestore(frate=23.976) ?
Old 15th August 2019, 23:28   #7  |  Link
ChaosKing
This seems to kill most of the blends
Cdeblend( dclip=crop(last, 20,20,-20,-20))
srestore( speed=-22, dclip = crop(last, 20,20,-20,-20))
srestore( frate = 23.976, mode =4, speed=-22, dclip = crop(last, 20,20,-20,-20))
(translated from vapoursynth script)
clip = muf.Cdeblend(clip, dclip=core.std.CropRel(clip, 20,20,20,20))
clip = haf.srestore(clip, speed=-22, dclip = core.std.CropRel(clip, 20,20,20,20))
clip = haf.srestore(clip, frate = 23.976, mode =4, speed=-22, dclip = core.std.CropRel(clip, 20,20,20,20))
VapourSynth Portable FATPACK || VapourSynth Database || https://github.com/avisynth-repository
Old 16th August 2019, 16:43   #8  |  Link
terminator3
What do I put at the end of everything in the script? ok for normal? or just for steam?
Old 17th August 2019, 01:21   #9  |  Link
real.finder
ChaosKing code maybe very ruthless that can make the motions not smooth so here another method
AssumeTFF()
animeivtc(2,mode22=true) #you can play with another parameters as you need
Old 17th August 2019, 14:24   #10  |  Link
terminator3
AssumeTFF()
thanks, I will try both methods, if you can think of anything else tell me
eliminate, ghosting, interleaced, remove, vhs
