11th February 2010, 17:55 | #3301 | Link | |
11th February 2010, 18:11 | #3303 | Link |
@stax76
whats the quicker or proper way to just mux in StaxRip? howto bypass indexing so i can open my source threw set file to mux choose audio, subtitles, chapters so on StaxRip keeps asking me to open source
StaxRip at Doom9's | StaxRip at Sourceforge [RSS] | StaxRip Donations | TheMTiNFo |
11th February 2010, 18:26 | #3304 | Link | |
@tormento
There are some things making it problematic to use it as default. When you open a dgi file for the first time StaxRip sets up a couple of things, only thing left to do then is enabling MPEG-2 file extensions I think. Quote:
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 11th February 2010 at 18:32. |
11th February 2010, 19:14 | #3305 | Link |
@stax76
can i just open the video threw here so i dont have to demux or index the source? i set the file to mux and i see it's added to the container configuration command line but after i load the subtitles, chapter file, audio tracks and try to proceed to just mux to mkv StaxRip does'nt let me continue i keep getting asked to open a source i just want to load the files in StaxRip and mux to mkv no demuxing or indexing
11th February 2010, 19:22 | #3306 | Link |
Job processing always requires to open a source file and currently the only way to prevent demuxing is to disable it in the settings. I know sometimes it's not desired to demux and disabling it in the settings globally is not a good solution, it's mostly Blu-ray related, something that needs to be improved.
11th February 2010, 20:21 | #3307 | Link |
@stax76
yeah it sure is a pain demuxing and indexing large Blu-ray sources to just mux but it's no biggie the good news is i just muxed a Blu-ray backup that has a 5.1 TrueHD track (thd+ac3) and it muxed to .mkv with no problems later i will mux another backup that has a 5.1 DTS-MA (dtshd) track and report back
12th February 2010, 02:21 | #3308 | Link |
@stax76
DTS-MA muxing was a success once again great coding from the staxster
12th February 2010, 02:39 | #3309 | Link |
@stax76
--merange is stuck at 51 no way to make it go higher can you allow up to 64 please also can you show both passes rather then just the second pass and a export option to clipboard just like you did with import?
12th February 2010, 07:10 | #3310 | Link |
Thx for answer. Except this Staxrip is the best solution for encoding my vieos. Is it possible somehow to cut the video in external environment (Premiere, Vegas, Tmpgenc or similar), and then import or reuse the regions for encoding? Sometimes TV rip containing ad blocks, which cause the end of ending movie block overlaps the begin of following movie block, thus it is necessary to cut part of following movie block, unfortunatelly I find this very difficult, if not impossible in Staxrip.
12th February 2010, 14:52 | #3311 | Link |
@stax76
StaxRip is not adjusting the file size after running compressibility checks if audio files are loaded into StaxRip before running the checks please fix
12th February 2010, 15:28 | #3312 | Link |
Acid fr0g
@stax76
As Mosu kindly agreed not to help me, would be possible to get chapters in mkv when batch processing a bunch of files into a single one? One chapter per file would be sufficient P.S: A new keyframe per file beginning would be a good idea too
@turment on Telegram |
12th February 2010, 15:56 | #3313 | Link | |||
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 12th February 2010 at 16:13. |
12th February 2010, 16:48 | #3314 | Link | ||
12th February 2010, 20:36 | #3315 | Link |
I tried to crop the black bars from a vid using StaxRip. The problem is that after encoding, the side bars are there untouched, but the resolution of video was drop down. Already tried to crop with VirtualDub, but the same result. Has anyone know what's the problem with those black side bars? Edit: note that I tried to crop more than it's needed with a dar=2.000, but I've got the same result. Last edited by chagos; 12th February 2010 at 20:43. |
12th February 2010, 22:31 | #3316 | Link |
@chagos
copy and paste the *_StaxRip.log for that project please
12th February 2010, 22:44 | #3317 | Link |
12th February 2010, 23:41 | #3319 | Link |
13th February 2010, 00:53 | #3320 | Link |
FFmpegSource 2.13 Released!
gui, h.264, h.265, hevc, mkv, x264, x265 |
