12th April 2011, 20:06 | #6741 | Link | |
Yes the new 051 exclusive mode is as smooth as 049, the frame repeat issues I had are gone. As far as proformance goes I never had any issues with 049 so I can't really report anything on that front. One thing I have noticed with 051 is coming in and out of full screen does not feel as smooth as 049. |
12th April 2011, 20:57 | #6742 | Link |
AV heretic
Thanks for new version.
Win7 x86, ATI 5450 (512Mb, DDR3). Tried 0.51 with 720p/24 video. For me results look almost the same as with 0.50. CPU usage little bit less now, but still 4-5 times more than with 0.49. Funny, RAM usage now looks big too. In FS mode it's still bit stuttering and in windowed mode playback is smooth. OSD keeps the same values if I switch between FS and W modes. Decoder queue is about 7-8/8, no drops. Went back to 0.49 to watch the movie. BTW, I'd like to diagnose more, but didn't find any manual (how to make logs, etc). |
12th April 2011, 21:04 | #6743 | Link | |
Green is perhaps not completely untouched but the difference is clear. 192 red, 160 green, 255 blue. 4:4:4 PC mode: 4:2:2 Cinema mode: (not sure why the font looks weird in the photos it's fine on the screen) Yes, and it sucks. With PCs it is 720p60 or 1080p24. 720p looks awful and 24fps is too slow for games. They should have upgraded the spec. |
12th April 2011, 21:13 | #6744 | Link | ||
I took the liberty of fixing this for you, also marking madVR compatible with the sub renderer in the Output configuration GUI (in r3025)
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 12th April 2011 at 21:20. |
12th April 2011, 21:46 | #6746 | Link |
When paused, and you move the mouse up and down very fast between showing the seekbar and not showing it, occasionally it will get stuck at either showing it or not. If it doesn't show, it will still be there (you can seek by clicking where the seekbar should be). This gets reset when you seek or play (update the movie image).
12th April 2011, 22:37 | #6747 | Link | |
Regarding seeking in paused mode - maybe Nevcairel can help - it happens only with VC-1 videos. H.264/MPEG2 are ok. Additionally, when paused and skipping in the timeline the frames are corrupted: http://img816.imageshack.us/f/paused1.png/ http://img405.imageshack.us/f/paused2.png/ http://img713.imageshack.us/f/paused3.png/ The second issue is, mentioned by anton too - in fullscreen exclusive mode the seekbar does not show always when video is paused and you move over it with the mouse.
__________________ System: Intel Core i5-6500, 16GB RAM, GTX1060, 75" Sony ZD9, Focal speakers, OS Win10 Pro, Playback: madvr/JRiver |
12th April 2011, 22:53 | #6748 | Link | |
R = 1.0*Y + 1.5748*Cr G = 1.0*Y - 0.1873*Cb - 0.4681*Cr B = 1.0*Y + 1.8556Cb If you analyse the above functions carefully, you will see that Cb and Cr have a small influence on Green, but a big one on R and B. So, It's natural that green has more resolution, because the Y resolution is kept intact for every pixel. |
12th April 2011, 23:29 | #6749 | Link |
Is the decoder supposed to pass the color matrix to the renderer? Tested madVR, EVR and Haali, plus exporting RGB from ffdshow.
ffdshow apparently used the correct matrix, but Haali was the only renderer that correctly used the 601 matrix on a HD test video. (edit: nevermind, see later post) Last edited by ajp_anton; 13th April 2011 at 01:52. |
12th April 2011, 23:55 | #6750 | Link | |||
13th April 2011, 00:12 | #6751 | Link |
Envy 17/ Radeon 6850
Got a new Envy 17 3D, madvr does not work with Radeon 6850. Custom EVR pres works fine.
Tested with madvr .50, and .51. Tested with last offical release of MPC-HC and xhmikosr build from the other day (SVN 3021) Issue: When loading any media type, MPC-HC hangs indefinitely on a black screen. This laptop has switchable graphics, when I switch to the onboard intel GPU madvr works fine. Let me know whatever you need for debugging, consider me your servant. |
13th April 2011, 00:16 | #6752 | Link |
madshi,
I'm very impressed with the way v0.51 works - CPU usage is OK and it's smooth as butter with the few short clips I tested. I'm going to watch a couple of episodes now just to check a longer time performance |
13th April 2011, 00:19 | #6753 | Link |
Tested on my AMD machine. Working great! I haven't had a chance to test on my nVidia box which is where the CPU usage was high last night. It'll probably be tomorrow before I can do that.
13th April 2011, 00:25 | #6754 | Link | |
Sony HX909. I could be mistaken but I don't think the Kuros offered 4:4:4 at all. Been too long since I had one to be sure though. (liked the black level, disliked everything else) |
13th April 2011, 01:17 | #6757 | Link |
I don't think we really get a vote, but, hypothetically if we did, I'd vote for green. I can't read the red very easily on my SXRD screen.
13th April 2011, 01:42 | #6758 | Link |
I did a search, but didn't see this problem listed before, so I wanted to report the following behavior.
I have MPC-HC's "auto-change fullscreen monitor mode" enabled. If I toggle the player between fullscreen and windowed, which also causes a monitor resolution change, It immediately locks the player. The video area is black and you can see where mpc-hc was able to draw some of the window elements before it hung. This happened with both the old and new exclusive renderer with and without desktop composition turned off and even with exclusive fullscreen mode turned off. Is there any way that this can be fixed? I like this renderer enough that I'd probably choose to disable the fullsceen mode switch before I stopped using MadVR, but it would be nice to not have to choose. Edit:My apologies. I forgot to include my system details: Windows 7 x64, ATI HD 6970 (Cat 11.4preview), MPC-HC revision 3016 Last edited by mrcorbo; 13th April 2011 at 01:51. |
13th April 2011, 01:42 | #6759 | Link |
I still get higher CPU usage. It's difficult to tell if it's less than before, but the difference is that most of the higher usage before was on one core. Here it seems the difference is spread out to two cores. The dip in the middle is where I switched from new to old exclusive.
Here's my previous graph for comparison: Last edited by Andy o; 13th April 2011 at 01:47. |
13th April 2011, 01:50 | #6760 | Link | |
ffdshow is the only one that can convert these to RGB correctly, every renderer fails. EVR and madVR assumes the clip is 709, probably because of the resolution. Don't know if it can be manually changed. Haali and "video renderer" assumes the clip is 601. Yes, Haali is set to "auto". Don't know about VR's settings. edit: I also did a 0-255 range test, and again ffdshow is the only one that didn't fail. edit2: So adding to the original question "Is the decoder supposed to pass the color matrix to the renderer?", what about the fullrange flag? ffdshow was used as the decoder for all tests. Last edited by ajp_anton; 13th April 2011 at 02:09. |
