24th May 2011, 19:11 | #12083 | Link |
X264 Error And FFDSHOW Dialogue Box Help
just updated to the latest version of bd rebuilder, i am tryin to convert salt (i now this is cinivia protected), to a bd25 backup on the options setting i have set encoder to highest (very slow)
the problem im having is about 30% through i get the error x264 has stopped working? anyone no why this is doing it? also the main problem that geeting to me is this i was prompted with a dialogue box when running bdrebuilder from ffdshow about what to selct or something it said ffdshow "choose dont use now, or always, etc" so i chose no, however apparently on reading up i should have chose yes, how can i get the dialogue box to appear again so i can choose yes?? i have looked in the setiing briefly and found something different in ffdshow, but i can not find the exact popup i had i also got the same popup when i loaded a audio cue file through imgburn Any Help appreciated? |
24th May 2011, 19:23 | #12084 | Link | |
1. You have the wrong version of FFDSHOW, HAALI, or AVISYNTH installed. My testing has shown that using the latest version of FFDSHOW definitely causes this error. 2. Your system is unstable. If you are overclocked, slow it down a little. Last edited by jdobbs; 24th May 2011 at 19:34. |
24th May 2011, 19:29 | #12085 | Link | |
More specifically: 1. Click on the windows/start icon. 2. Select "FFDSHOW" from "All Programs" 3. Select "Video Decoder Configuration" 4. Set the VC-1 decoder (under CODECs) to "wmv9" Last edited by jdobbs; 24th May 2011 at 19:33. |
24th May 2011, 19:36 | #12086 | Link |
Sorry, didn't mean to be a pain. What is weird is that everything was working and suddenly things changed. I had not reinstalled anything but the latest version of BD-RB and apparently the FFDSHOW settings got messed with. I ONLY use this machine for ripping and can't imagine what would have changed the settings. Are there other programs that would mess with FFDSHOW settings without my knowing it????
24th May 2011, 20:49 | #12088 | Link | |
24th May 2011, 22:39 | #12089 | Link |
Something is wrong on your end. Uninstall everyting and install with the software from the first post of this thread. I just ran "Stand By Me" with settings that should be the same as yours -- and it came out to the exact size (22.3 GB) that it was supposed to.
25th May 2011, 04:35 | #12090 | Link | |
i have installed all correct versions of ffdshow hali etc, and the system isnt overclocked i will try again with these settings however im still baffeled by this i was prompted with a dialogue box when running bdrebuilder from ffdshow about what to select or something it said ffdshow "choose dont use now, or always, etc" so i chose no, however apparently on reading up i should have chose yes, how can i get the dialogue box to appear again so i can choose yes?? Do you no how to get the dialogue box to reapper when i open bdrebuilder?? Thanks |
25th May 2011, 12:05 | #12091 | Link | |
Appreciate the time and your help.
[SLiM] |
25th May 2011, 12:40 | #12092 | Link | |
25th May 2011, 20:16 | #12093 | Link | |
and i have read that it should be set to yes always (ffdshow) and i chose no (always) i just wanted the dialogue box to appear again to rectify the problem how can i do this? All so my inspect log seems wrong on a few things here is the log, i hope you can help and am extremley greatfull! - Windows Version: 6.1 [7600] - AVISYNTH Version: 2.5.7.0, Ok - HAALI Splitter: Ok - FFDSHOW: 3326, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set incorrectly: [0] - FFDSHOW MPEG2 set incorrectly: [0] - FFDSHOW AVC set to "libavcodec": Ok - BD Rebuilder v0.38.0.2, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok Thanks |
26th May 2011, 13:53 | #12095 | Link | |
I think I've found a connection. On my test computer I had upgraded to AVISYNTH v2.58 some time ago so I can certify it as the recommended version. When I removed it and reinstalled v2.57 (the currrent recommendation) I was able to repeat the sync issue on certain discs. When I reinstall v2.58, the problem is solved. So, though it is still not completely clear why, it appears that the DVD-5/9 audio synchronization problem is linked to using the combination of HC Encoder and AVISYNTH 2.57. Since I have been running v2.58 for some time now, I am confident it is safe to use and I have now updated the first link of this thread so that it now links to that version. @steveg32 Can you please download and install this version of AVISYNTH and report if it corrects your issue? Thanks. |
26th May 2011, 18:18 | #12096 | Link | |
I think the problem is that the message sais at some point "... secondairy video stream". However when you take a look at the properties for vid_00033 there IS no secondary video stream. VID_00002 also had the non-existant secondairy stream but it was mentioned during the encoding process. Maybe thats the reason 2.57 crashed. I'll let you know about the final outcome Also there are 14 audio streams present, stream 13 is being flagged as "undetermined". This may be because of stream 8. 8 is often incorrectly flagged as english (on the main m2ts though its correctly identified as dutch). Stream 13 however is also dutch but flemish (belgian) to be exact. Maybe add another language option ? I also couldnt help but notice that x264-64 didnt get called on VC-1 streams, a bug or is x264 incapable of doing vc1 in 64bit with the LAFV. UPDATE 1: Encode was aborted and restarted from scratch to make sure it wasnt a fluke, VID_00033 was successfully encoded again with AVS 2.58 and multiplexed back. So far its going good. Last edited by Ch3vr0n; 26th May 2011 at 19:30. |
27th May 2011, 07:38 | #12097 | Link | |
thank you so much. Adding bd to dvd was a huge bonus for me , so thank you . Last edited by jdobbs; 27th May 2011 at 13:51. |
27th May 2011, 14:15 | #12099 | Link |
BD Rebuilder v0.38.03 (beta)
I have updated the first post of this thread with a link to a new release of BD-RB (v0.38.03). Changes for this version:
- Corrected an error in which .CHP files could be created and never removed in the destination folder while previewing streams. - Fixed an issue in subtitle end-times related to previously resized (via TSMUXER) subtitles. - Changed the default setting for B_PYRAMID (see HIDDENOPTS.TXT) to disabled. While it should be supported per standard, at least two standalone players appear to have difficulty with b-frame references. - Corrected level settings associated with 720x480 or 576 secondary video streams. - Added code to prevent redundant reencoding of secondary video streams when resuming after the encoding has previously been completed. - Changed the recommended version of AVISYNTH to v2.58. This should solve reported audio sync issues on ALTERNATE DVD-5/9 output that can occur on certain discs. AVISYNTH v2.58 can be downloaded from here: http://www.jdobbs.net/freeware/Avisynth_258.exe - Other minor corrections and cosmetic fixes. Please note that the recommended version of AVISYNTH has changed. All users are advised to update to v2.5.8.0. A link to that version is included in the first post of this thread. Last edited by jdobbs; 27th May 2011 at 14:17. |
27th May 2011, 17:10 | #12100 | Link |
This may be off-topic for this forum, but here goes:
Is there any way to force BD-Rebuilder to keep HD-Audio on a BD9 encode? According to the following excerpt: If doing BD-5 or BD-9: 1. Default (all audio options unchecked) ---- All audio is converted to DD AC3. Bitrate is 640Kbs for 5.1 and 224Kbs for 2.0. ---- All 7.1 sources are down-converted to 5.1 1.1 448Kbs selected -- 5.1 = 448Kbs, 2.0 = 224Kbs 1.2 192Kbs selected, all sources down-converted to 2.0 @ 192Kbs 2. "Do not convert DTS" checked and full-backup, or movie-only and "Strict AVCHD" is not checked: When the source is DTS, the DTS core is extracted and used intact (bit-for-bit). 3. "Do not reencode AC3" checked and full-backup, or movie-only and "Strict AVCHD" is not checked: When the source is Dolby, the Dolby core is extracted and used intact. 4. LPCM is always converted to AC3. 5. Keep HD is always ignored. 6. Setting "OVERRIDE_AVCHD_AUDIO_LIMIT=1" in the INI will allow strict AVCHD to also use DTS. and I was wondering if there is perhaps a hidden setting that can be turned on to allow HD-Audio on a BD-9 level. If not, what would the minimum custom size that would allow HD-Audio to be kept intact? Thanks! Mike |
