Old 29th March 2011, 22:48   #1  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
Bluray subtitles to dvd confusion
well after trying so many different programs and so many different orders, i finally figured out a way that works.
it definitely requires more than one program. This time, i've kept notepad open and everytime i saved a file, i created a new folder named after the corresponding program...
(Working with DVDFab)
1) Blu-ray movie to .m2ts (with internal PGS)
2) Demux with eac3to to get the subtitles as a .sup file.
3) Use the .sup file in SupRip for OCR and any corrections. (saves as .srt)
4) use easySUP to save as DVD SUB and screen size (for some reason, saving custom colors does not work)
5) Use SubtitleCreator>Manipulate
Use a screenshot from the converted video file (that is to be included in the final output)
Adjust colors/placement for all
Save, then open again to assure colors are saved properly.
May have to adjust twice.
Second time it opens, it may have red colors instead.
6) Mux to dvd.
The goal was never to output file into MKV or AVI, as none of my dvd/bluray machines can playback any of those formats.
And it's not option to upgrade my machines either. Nor is it an option to buy an external multimedia player.
Those are all options further down the road.
Right now, it's convert my bluray movies to dvd.
And only one thing stood in my way: converting bluray subtitles to dvd standards.
I have yet to figure out how to work with Bluray's IDX/SUB formats. It seems everytime I try to open either of those files in any subtitle program, I get "unsupported format" error. And if I do get it to open and convert into a working format, I still get the "unsupported format" down the road.
And set the proper Font size. It's not easy trying figure out what font size works perfectly for the movie without muxing everything and previewing.
None of the programs really load any movie. EasySUP always says "no video associated with subtitle track".
A lot of trial and error. A lot.
Old 30th March 2011, 07:41   #2  |  Link
Ghitulescu
Ghitulescu's Avatar
From your 1000 words I understand that you try to get subtitles from Blu-ray and put them on a DVD. Is this correct?
Born in the USB (not USA)
Old 30th March 2011, 08:34   #3  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
Yes. That is the only process I'm having difficulties with so far.
Old 30th March 2011, 08:43   #4  |  Link
Ghitulescu
Ghitulescu's Avatar
Although I never used this way, it appears that using SupRip to obtain the SRT, then any of these paths: 1. srt->ssa->MaestroSBT, 2. SubtitlesCreator (has a special tool that does the adding of subtitles completely transparent for you), 3. txt2sup or srt2sup, 4. many more.
Old 30th March 2011, 09:50   #5  |  Link
kypec
User of free A/V tools
kypec's Avatar
What about BDSup2Sub? Even the name implies its main feature i.e. converting SUP -> SUB alias Bluray subtitles into DVD subtitles.
kypec is offline   Reply With Quote
Old 31st March 2011, 07:06   #6  |  Link
Chetwood
Chetwood's Avatar
Into VobSubs (idx/sub) actually which cannot be used for DVD authoring without any further conversion, IIRC. Also, if conversion is necessary why not use MKV or AVI instead of DVD with it's older MPEG2 codec?
MultiMakeMKV: MakeMKV batch processing (Win)
MultiShrink
: DVD Shrink batch processing
Offizieller Übersetzer von DVD Shrink deutsch
Chetwood is offline   Reply With Quote
Old 13th April 2011, 13:24   #7  |  Link
Ghitulescu
Ghitulescu's Avatar
SubToSup. It's only a repacking without reencoding.
Old 13th April 2011, 17:23   #8  |  Link
Selur
Selur's Avatar
@Ghitulescu: SubToSup first time heard of it,.. do you know how to contact the author? (wanted to ask if he would make a command line version of the tool, or share the source code so I could make one)
Cu Selur
Old 13th April 2011, 17:52   #9  |  Link
Ghitulescu
Ghitulescu's Avatar
The first hit in google
http://www.videohelp.com/tools/SubToSup
Transforms IDX/SUB subtitles into SUP ones (DVD).
Old 13th April 2011, 17:55   #10  |  Link
Selur
Selur's Avatar
yeah, that I found too, but as far as I see, there's no info about the author or the source code,..
Old 13th April 2011, 18:03   #11  |  Link
Ghitulescu
Ghitulescu's Avatar
It works for me, that's all that counts (no issues at all in 2 years or so).
Old 13th April 2011, 19:49   #12  |  Link
sneaker_ger
That's only one of the possible formats:
Originally Posted by 0xdeadbeef View Post
Supported Formats
  • Blu-Ray SUP: Import (since 1.0) and Export (since 1.6)
  • Sony BDN XML: Import and Export (since 3.3.0)
  • HD-DVD SUP: Import (since 1.9)
  • VobSub (SUB/IDX): Import (since 3.5.0) and Export (since 1.0)
  • DVD-SUP (SUP/IFO): import and export (since 3.9.0)
Old 26th April 2011, 02:15   #13  |  Link
MilesAhead
MilesAhead's Avatar
If we are talking English Subs, this is what works for me like 90% of the time.
Load the .sup file into BDSup2Sub. Change the resolution to 720x480 NTSC. From the drop down box make sure type is sup/ifo.
Export the subs as .sup/.ifo set.
Load the .sup and .ifo files into DVDSubEdit.
Run automatic OCR.
Save as .srt.
Load the .srt in any text editor and search on '_' the underscore character. If you have a lot of OCR failures you'll find a bunch of underscores in most cases. If there's none or only a few, fix the underscores if necessary by matching the subtitle numbers with the underscores to what's still in BDSup2Sub.
For me, the vast majority of the time, if I reduce the resolution to 720x480 the automatic OCR in DVDSubEdit does all the work. If I find a lot of errors then I just export as idx/sub and burn the subs in instead.
"I don't want to belong to any club that would have me as a member."
- Groucho Marx
MilesAhead is offline   Reply With Quote
bluray, conversion, dvd, subtitles
