1st November 2005, 19:09 | #761 | Link | ||
1st November 2005, 19:48 | #762 | Link | |
clueless n00b
@Sharktooth: I've been unable to reproduce your problem in the 0.2.2.9 build.
2nd November 2005, 08:21 | #763 | Link |
clueless n00b
Regarding AVC Levels I need your input: VBV isn't so much of a problem, but levels impose limits on frame size and bitrate. Now if we're queueing video jobs manually and have the AviSynth script loaded prior to configuration, I can display the appropriate warning right in the configuration. But once you start using profiles the problems start: say you select your profile prior to selecting the input. When do I notify that the level is incompatible with the frame size, and what about the bitrate?
It gets worse in auto mode as there the bitrate may only be known after audio encoding, so I would have to interrupt the queue to ask you if you want to relax the level for a certain bitrate, or reduce the bitrate (thus not achieving your desired size anymore). One click mode is worst as there prior to encoding I know neither the framesize of the AviSynth script, nor what bitrate I'm getting. Either way, as soon as we go automated, levels either have to be ignored or I have to interrupt the queue and you can forget about setting up a couple of movies and encode them through the night or while you're at work if you've made one small mistake with regards to levels.
2nd November 2005, 15:26 | #764 | Link |
Bug report
i'v come across a really annoying bug in MeGui... "sticking to jobs"
when a job is supposed to be finished, MeGui will _not_ start the next job scheduled... This is version 0.2.2.8 im using http://arienai.com/Capture.jpg <-- screenshot also, when i output a x264 encode in .MP4, i cant playback the MP4 (even when muxed with sound) So i encode to raw first and then mux audio + video -> MP4 wich works fine. [edit] forgot to mention this, but when i Abort the stuck job and manually start the next job, the resulting file is playable (when muxed) without errors [/edit]
All you gotta do is run for your life, i just gotta know why!? Last edited by subcool; 2nd November 2005 at 15:28. |
2nd November 2005, 17:29 | #765 | Link | |
clueless n00b
2nd November 2005, 17:42 | #766 | Link |
Mr. Sandman
use the "nicefps()" filter in your .avs file: http://mirror05.x264.nl/eMotionEstimation/nicefps.zip
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 2nd November 2005 at 17:46. |
2nd November 2005, 18:10 | #767 | Link |
mp4 files created during an aborted encode will not work. thats the normal behaviour
2nd November 2005, 19:07 | #769 | Link |
Sir Lionel Luckhoo
Hi
what means this error: Log for job job2-4 IsoMedia import - track ID 1 - Video (size 640 x 272) Error importing D:\Leon\VTS_01_1 T01 3_2ch 448Kbps DELAY 0ms.mp4: Invalid IsoMedia File ---------------------------------------------------------------------------------------------------------- The current job contains errors. Skipping chained jobs ---------------------------------------------------------------------------------------------------------- Log for job job2-4 IsoMedia import - track ID 1 - Video (size 640 x 272) Error importing D:\Leon\VTS_01_1 T01 3_2ch 448Kbps DELAY 0ms.mp4: Invalid IsoMedia File an exception ocurred when trying to read from stdout: Key cannot be null. Parameter name: key ------------------------------------------------------------------- |
3rd November 2005, 01:26 | #770 | Link | |
@Doom9: just because nobody else has the same problem, doesnt mean it can't be a bug :P i'v had this 'sticking' of jobs in multiple encode over multiple version of MeGui en its kinda annoying when you wanna do long encodes at night. and if you wanna read logs, here is the log of the job that got stuck: Code:
---------------------------------------------------------------------------------------------------------- Next job job1-1 is a video job. encoder commandline: "C:\x264\x264.exe" --pass 1 --bitrate 718 --stats "D:\encoding\raws\kaleidoscope\Kaleidoscope.stats" --keyint 240 --bframes 2 --subme 1 --weightb --analyse none --qpmax 27 --ratetol 90 --qcomp 0.9 --me dia --sar 1:1 --progress --no-psnr --output NUL "D:\encoding\raws\kaleidoscope\Kaleidoscope.avs" successfully set up video encoder and callbacks for job job1-1 ---------------------------------------------------------------------------------------------------------- Log for job job1-1 avis [info]: 640x480 @ 23.98 fps (34884 frames) x264 [info]: no need for a SAR x264 [info]: using cpu capabilities MMX MMXEXT SSE 3DNow! x264 [info]: slice I:250 Avg QP:22.16 size: 22593 x264 [info]: slice P:16274 Avg QP:24.32 size: 5707 x264 [info]: slice B:18360 Avg QP:25.93 size: 1001 x264 [info]: mb I I16..4: 43.0% 0.0% 57.0% x264 [info]: mb P I16..4: 11.5% 0.0% 0.0% P16..4: 36.4% 0.0% 0.0% 0.0% 0.0% skip:52.1% x264 [info]: mb B I16..4: 0.6% 0.0% 0.0% B16..8: 11.7% 0.0% 0.0% direct: 4.9% skip:82.8% x264 [info]: kb/s:642.8 Actual bitrate after encoding without container overhead: -174933.45 ---------------------------------------------------------------------------------------------------------- The current job was aborted. Stopping queue mode The current job contains errors. Skipping chained jobs
All you gotta do is run for your life, i just gotta know why!? Last edited by subcool; 3rd November 2005 at 01:30. |
3rd November 2005, 06:19 | #771 | Link | |
developer wannabe
3rd November 2005, 06:33 | #772 | Link |
developer wannabe
Bugs in 0.2.2.9a:
* Tools -> Settings -> OneClick Defaults gives an unhandled exception. Stack trace: System.ArgumentOutOfRangeException: Specified argument was out of the range of valid values. Parameter name: '2' is not a valid value for 'index'. at System.Windows.Forms.ComboBox.set_SelectedIndex(Int32 value) at MeGUI.OneClickDefaultWindow..ctor(Hashtable videoProfiles, Hashtable audioProfiles, Int32 videoIndex, Int32 audioIndex) at MeGUI.SettingsForm.configOneClick_Click(Object sender, EventArgs e) at System.Windows.Forms.Control.OnClick(EventArgs e) at System.Windows.Forms.Button.OnClick(EventArgs e) at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ButtonBase.WndProc(Message& m) at System.Windows.Forms.Button.WndProc(Message& m) at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) * Adding/deleting profiles does not refresh the main window. New profiles don't show up; selecting deleted profiles gives an unhandled exception: System.NullReferenceException: Object reference not set to an instance of an object. at MeGUI.MeGUI.audioProfile_SelectedIndexChanged(Object sender, EventArgs e) at System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e) at System.Windows.Forms.ComboBox.WmReflectCommand(Message& m) at System.Windows.Forms.ComboBox.WndProc(Message& m) at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) |
3rd November 2005, 09:26 | #773 | Link | ||
clueless n00b
However, I cannot reproduce your deletion problem either so can you please give me a scenario, starting with a blank megui.exe (no settings, profiles and jobs), how to create profiles and how I can reproduce your second problem? Quote:
@subcool: does using mencoder work? besweet? mp4box? mkmerge? mencoder for avi merging? @hackboyz: it probably means something is wrong with your mp4 file
3rd November 2005, 09:55 | #774 | Link |
Of course does side by side execution work, you can install different .NET versions. Assemblies can be installed to the GAC that have same filename but are different in version. Your application will run with the runtime and assembly versions it was compiled against. DLL hell is a thing of the past.
I don't think VS 2005 can compile against .NET 1.1 so you would have to fire up csc.exe by hand. You might have a hard time not to use .NET 2.0 features
3rd November 2005, 10:28 | #775 | Link |
clueless n00b
hmm... they finally did something right then. This is a major bonus over Java. I know the runtime picks the proper DLL versions but I wasn't aware it also applied to the whole runtime libraries. Thinking about it, it does make sense though. Since you have 2.0 installed and know how to handle a compiler, have you tried compiling MeGUI with the 2.0 csc? It would be neat if I could develop with VS2k5 and then for the release just compile with the 1.1 csc.. but as you said, I've been using the new Java 1.5 features extensively and have missed typed arraylists and hashtables in C# ever since.
3rd November 2005, 12:42 | #776 | Link |
irc compiling your app didn't even issue a compiler warning. When I started StaxRip in april using DVX as base I enabled "treat all warnings as errors". I got more than hundred compile time errors and warnings as the compiler was much improved. Not to mention I had cross thread gui code *everywhere* which worked fine with 1.1 but it is not permitted with 2.0 (you'll get a nice runtime exception). I knew it shouldn't be done back then but I didn't care since it appeared to work very well. Since I felt like redoing anything (having some lessons learnt...) I wasn't much concerned that my code was completely broke using the new runtime. Anonymous methods can be handy for cross gui code btw, not a VB feature as it don't mix well with basic VB concepts but maybe they'll come anyway.
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 3rd November 2005 at 12:47. |
3rd November 2005, 14:35 | #777 | Link | |
[edit] Strange thing is that sometimes is does do the chained jobs (1-1 and 1-2) but then gets stuck on job 1-2. [/edit]
All you gotta do is run for your life, i just gotta know why!? Last edited by subcool; 3rd November 2005 at 14:37. |
3rd November 2005, 19:44 | #778 | Link | |
clueless n00b
Is x264.exe still running before you manually abort? Also, could you run the exact same commandline that gets stuck (does it always? if you restart the job does the same thing happen) in a commandline and paste everything you see here?
3rd November 2005, 23:13 | #779 | Link | ||
developer wannabe
I will see about reproducing that OneClick Settings problem when I get home. I've never been to that dialog before (analog capture = no OneClick for me). I have Sharktooth's x264 profile collection installed. |
4th November 2005, 00:12 | #780 | Link |
Mr. Sandman
@Doom9: x264 has got a new option: trellis quantization.
usage: -t, --trellis <integer> Trellis RD quantization. Requires CABAC. [0] - 0: disabled - 1: enabled only on the final encode of a MB - 2: enabled on all mode decisions
