22nd July 2010, 01:53 | #13543 | Link |
Hi guys. Does anyone know how MPC-HC evaluates whether to use DXVA or not?
I have two desktops, one with AMD 785G and the other with an ATI Radeon 4870 (both are UVD2) running 10.6 drivers (latest) and Win7 x64. The 4870 opens almost all the videos I throw at it, disregarding what I set in DXVA Compat Check. DXVA works fine MS DTV-DVD Decoder too. The 785G only does the same if I set DXVA Compat Check to "Skip all checks". Again, DXVA works fine MS DTV-DVD Decoder. I know I can go and "Skip all checks" and just disable DXVA if I find glitches, but is this recommended? Both MPC and Microsoft filters corrupt SD video, seems to be a driver glitch. Hope someone can help! Thanks! |
22nd July 2010, 03:08 | #13544 | Link |
Otaku
@chapas
Although I'm using NVIDIA I use "Skip all Checks" because otherwise some files will not trigger DXVA. In you case enable "Disable DXVA for SD", because it's already known that with recent Catalyst drivers SD videos get corrupted, and use software decoding instead.
In the school, the three guys met. Their relation had been changed in the season, and turned into three love stories.
22nd July 2010, 05:08 | #13545 | Link |
@Kado
I'll do that, then! It seems that, no matter the checks, the player cannot guess if the file will be properly supported. What seemed strange to me was the 4870 with 10.6 drivers just triggering DXVA on anything, as if having a great DXVA compatibility, but that may be an illusion. I'll keep wondering why the 785G (IGP) does not trigger DXVA as frequently, having the same capabilities and drivers! |
22nd July 2010, 09:13 | #13547 | Link |
OSD feature request
Can somebody add support for displaying commands via OSD from the "After playback" group ? (exit, stand by, shutdown, etc. and for their off states)
It would be very useful when you are using a remote control ... Thanks
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
22nd July 2010, 13:58 | #13549 | Link |
MPC-HC Project Manager
i think the check is inaccurate.
the check should be rewritten with documenten fact on what does and does not work.
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
23rd July 2010, 00:01 | #13551 | Link |
Is there any way to get animated subtitles without dropped frames (Or flashing on and off briefly if set to buffering animation option)? If I set buffering to 0 I get dropped frames whenever ANY subs appears (Not just animated). I tried enabling buffering for animated subs but then all I get is a brief flash of the animated subs which kinda defeats the point. It's either 1. No animated subs. 2. Animated subs but dropped frames or 3. Animated subs with no dropped frames but they flash on and off briefly.
23rd July 2010, 03:28 | #13552 | Link |
Fantasy Codecs writer
Revision 2140 - Directory Listing
Modified Wed Jul 21 02:26:19 2010 UTC (47 hours, 21 minutes ago) by Aleksoid Fix : Can't open specific mp3, Ticket #363(modify path by koolspin); this not good fix! if i use mpc-hc Internal MPEG Audio Source Filter and standalone mpc-hc AviSplitter ,mpc-hc can not show video for some avi files! but if i not use standalone mpc-hc AviSplitter and use Internal avisplitter play is fine! and i use mpc-hc 1.3.2138 use Internal MPEG Audio Source Filter and standalone mpc-hc AviSplitter! play is fine too! can fix it? I repot bug at here http://sourceforge.net/apps/trac/mpc-hc/ticket/586/ |
23rd July 2010, 04:58 | #13553 | Link | |
23rd July 2010, 05:21 | #13554 | Link | |
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
23rd July 2010, 07:57 | #13558 | Link | |
