Old 25th May 2008, 00:25   #841  |  Link
Yong
Originally Posted by Reimar View Post
If it's completely garbled, it is almost certainly the problem that ati-hack is supposed to help against. You could try if it works when you scale the video to e.g. 256x256 (-vf scale=256:256), but since it looks very much like another driver bug to me, in the worst case it might not be fixable at all by me.
-vf scale 256:256 does help, but the color still display incorrectly, ive tried both xp and vista with catalyst 8.5,
currectly its only work with yuv=0, yuv=2 or 4 give the same garbled output.
Does force pbo only work with yuv=2?
Yong is offline
Old 25th May 2008, 16:38   #842  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
MPUI.2008-05-25.Full-Package.zip
I've uploaded a new test build of my installer, incorporating the latest UltraModern UI update:
http://mplayer.somestuff.org/beta/MP...ll-Package.zip
Now the language dialog will remember your selection and it will appear every time you run the installer.
LoRd_MuldeR is offline
Old 25th May 2008, 16:55   #843  |  Link
LoRd_MuldeR
Software Developer
Question: Does MPlayer use any method of "queuing" frames, like ffdshow and all those DirectShow renderers do ???
If yes, how to display the number queued frames? If not, are there any plans to implement it?
Old 25th May 2008, 20:32   #844  |  Link
Warpman
is it possible to compile mplayer with fontconfig support?
Also it not possible to disassociate filetypes in smplayer.. or is that just me?
Warpman is offline
Old 25th May 2008, 21:50   #845  |  Link
LoRd_MuldeR
Software Developer
I think RVM has a build with fontconfig enabeld...
If you use my installer, please try Start > Programs > MPlayer for Windows > Tools > Set File Associations
Old 26th May 2008, 14:27   #846  |  Link
LoRd_MuldeR
Software Developer
MPlayer for Windows 2008-05-26
[2008-05-26]
* SMPlayer updated to Version 0.6.0 (SVN-r1293)
* Ported the installer to NSIS UltraModern UI
Old 27th May 2008, 00:36   #847  |  Link
LoRd_MuldeR
Software Developer
Sorry, I forgot to say: needs at least MPlayer SVN r26713. Seems like that version is not yet available precompiled...
New Win32 builds including the latest OpenGL fixes plus "-volume" patch available now:
http://oss.netfarm.it/mplayer-win32.php
I will update my installer tomorrow. Why does this come a few hours after my recent update
But I have to say: I love the new OpenGL renderer
Old 27th May 2008, 13:09   #848  |  Link
LoRd_MuldeR
Software Developer
MPlayer for Windows 2008-05-27
[2008-05-27]
* MPlayer binaries updated to SVN-r26874
* SMPlayer updated to Version 0.6.0 (SVN-r1299)
This time with "fresh" MPlayer builds, including the latest OpenGL improvements
Recommended renderer is now "gl:yuv=2:force-pbo:ati-hack" for all users with OpenGL 2.0 capable hardware.
You can enable this by selecting "Use OpenGL renderer" during setup.
Furthermore the new MPlayer builds finally come with the "-volume" patch included.
Old 27th May 2008, 16:10   #849  |  Link
LoRd_MuldeR
Software Developer
I found a possible bug in MPlayer:
I got an AVI file (captured with a digicam) that makes MPlayer crash immediately.
The video format is MJPEG. Audio is not present, although MPlayer seems to detect an "ADPCM" stream.
Sample file is here: crash_sample.7z
This is what MPlayer puts out, reproduced with several builds from various sources:
C:\Downloads\MPlayer-r26853>mplayer -sound c:\S3000002.AVI
MPlayer dev-SVN-r26853-4.2.1-sjlj (C) 2000-2008 MPlayer Team
CPU: Intel(R) Core(TM)2 Quad CPU           @ 2.40GHz (Family: 6, Model: 15, Step
ping: 7)
CPUflags:  MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
Compiled for x86 CPU with extensions: MMX MMX2 3DNow 3DNowEx SSE SSE2
Playing c:\S3000002.AVI.
AVI file format detected.
[aviheader] Video stream found, -vid 0
[aviheader] Audio stream found, -aid 1
AVI: No audio stream found -> no sound.
VIDEO:  [MJPG]  320x240  24bpp  22.824 fps  1623.9 kbps (198.2 kbyte/s)
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Selected video codec: [ffmjpeg] vfm: ffmpeg (FFmpeg MJPEG decoder)
Opening audio decoder: [imaadpcm] IMA ADPCM audio decoder
MPlayer interrupted by signal 11 in module: init_audio_codec
- MPlayer crashed by bad usage of CPU/FPU/RAM.
  Recompile MPlayer with --enable-debug and make a 'gdb' backtrace and
  disassembly. Details in DOCS/HTML/en/bugreports_what.html#bugreports_crash.
- MPlayer crashed. This shouldn't happen.
  It can be a bug in the MPlayer code _or_ in your drivers _or_ in your
  gcc version. If you think it's MPlayer's fault, please read
  DOCS/HTML/en/bugreports.html and follow the instructions there. We can't and
  won't help unless you provide this information when reporting a possible bug.
It seems to file is strange in some way. This is what AVInaptic says:
[ About file ]
Date: 27/05/2008 13:00:49
Size: 6,786,612 bytes (6.472 MB)
[ Generic infos ]
L'AVI č corrotto: dichiara 1 streams, ma ne vengono trovati 2
Nevertheless this file seems to play 100% fine in VLC Player as well as with MPC+ffdshow.
Also I think it played okay with an older revision of MPlayer a while ago...
[EDIT]
Yes, using an old build of MPlayer (r25803) the file plays 100% fine:
C:\Downloads\oldplayer>mplayer c:\S3000002.AVI
MPlayer Sherpya-SVN-r25803-4.2.2 (C) 2000-2008 MPlayer Team
ping: 7)
Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2
SUB: Could not determine file format
Cannot load subtitles: c:\S3000002.txt
Audio: no sound
Starting playback...
VDec: vo config request - 320 x 240 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 3)
Movie-Aspect is undefined - no prescaling applied.
VO: [directx] 320x240 => 320x240 Planar YV12
New_Face failed. Maybe the font path is wrong.
Please supply the text font file (~/.mplayer/subfont.ttf).
subtitle font: load_sub_face failed.
V:  33.3 761/761  0%  1%  0.0% 0 0
Exiting... (End of file)
Old 27th May 2008, 21:04   #850  |  Link
carnage_pl
Posts: n/a
Hi. with the newest build every video crashes mplayer
log :
C:/Program Files/MPlayer for Windows/MPlayer.exe -noquiet -nofs -sub-fuzziness 1 -identify -msglevel demux=6 -slave -vo gl:yuv=2:force-pbo:ati-hack -ao dsound -zoom -nokeepaspect -priority abovenormal -framedrop -wid 132522 -monitorpixelaspect 1 -subfont-autoscale 1 -subfont-text-scale 5 -subcp ISO-8859-1 -subpos 100 -contrast 0 -hue 0 -saturation 0 -volume 100 -nocache -osdlevel 1 -vf-add screenshot -channels 2 -af volnorm=2 -sws 9 -noslices D:\_BAKAW~1.264\_BB22C~1.MKV
MPlayer Sherpya-SVN-r26874-4.2.3 (C) 2000-2008 MPlayer Team
CPU: Intel(R) Core(TM)2 Duo CPU T5250 @ 1.50GHz (Family: 6, Model: 15, Stepping: 13)
Setting process priority: abovenormal
Playing D:\_BAKAW~1.264\_BB22C~1.MKV.
Checking for YUV4MPEG2
Checking for NuppelVideo
Checking for REAL
Checking for SMJPEG
[mkv] Found the head...
[mkv] + a segment...
[mkv] /---- [ parsing seek head ] ---------
[mkv] \---- [ parsing seek head ] ---------
[mkv] /---- [ parsing cues ] -----------
[mkv] \---- [ parsing cues ] -----------
[mkv] |+ segment information...
[mkv] | + timecode scale: 1000000
[mkv] | + duration: 92.374s
[mkv] |+ segment tracks...
[mkv] | + a track...
[mkv] | + Track number: 1
[mkv] | + Track type: Video
[mkv] | + Default flag: 1
[mkv] | + Codec ID: V_MPEG4/ISO/AVC
[mkv] | + CodecPrivate, length 41
[mkv] | + Default duration: 41.708ms ( = 23.976 fps)
[mkv] | + Language: jpn
[mkv] | + Name: H.264 R2J DVD
[mkv] | + Video track
[mkv] | + Pixel width: 848
[mkv] | + Pixel height: 480
[mkv] | + Display width: 853
[mkv] | + Display height: 480
[mkv] | + Track number: 2
[mkv] | + Track type: Audio
[mkv] | + Codec ID: A_AAC
[mkv] | + CodecPrivate, length 7
[mkv] | + Default duration: 42.667ms ( = 23.438 fps)
[mkv] | + Name: AAC Stereo
[mkv] | + Audio track
[mkv] | + Sampling frequency: 24000.000000
[mkv] | + Channels: 2
[mkv] | + Track number: 3
[mkv] | + Track type: Subtitle
[mkv] | + Codec ID: S_TEXT/ASS
[mkv] | + CodecPrivate, length 1024
[mkv] | + Language: eng
[mkv] | + Name: Styled Subtitles (GG)
[mkv] |+ found cluster, headers are parsed completely
ID_VIDEO_ID=0
[mkv] Aspect: 1.777083
ID_VID_0_NAME=H.264 R2J DVD
[mkv] Track ID 1: video (V_MPEG4/ISO/AVC) "H.264 R2J DVD", -vid 0
ID_AUDIO_ID=0
ID_AID_0_NAME=AAC Stereo
ID_AID_0_LANG=jpn
[mkv] Track ID 2: audio (A_AAC) "AAC Stereo", -aid 0, -alang jpn
ID_SUBTITLE_ID=0
ID_SID_0_NAME=Styled Subtitles (GG)
ID_SID_0_LANG=eng
[mkv] Track ID 3: subtitles (S_TEXT/ASS) "Styled Subtitles (GG)", -sid 0, -slang eng
[mkv] Will play video track 1.
Matroska file format detected.
VIDEO: [avc1] 848x480 24bpp 23.976 fps 0.0 kbps ( 0.0 kbyte/s)
ID_FILENAME=D:\_BAKAW~1.264\_BB22C~1.MKV
ID_DEMUXER=mkv
ID_VIDEO_FORMAT=avc1
ID_VIDEO_BITRATE=0
ID_VIDEO_WIDTH=848
ID_VIDEO_HEIGHT=480
ID_VIDEO_FPS=23.976
ID_VIDEO_ASPECT=1.7771
ID_AUDIO_FORMAT=MP4A
ID_AUDIO_BITRATE=0
ID_AUDIO_RATE=24000
ID_AUDIO_NCH=2
ID_LENGTH=92.37
ID_SEEKABLE=1
[gl] using extended formats. Use -vo gl:nomanyfmts if playback fails.
Opening video filter: [screenshot]
Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264)
ID_VIDEO_CODEC=ffh264
Opening audio decoder: [faad] AAC (MPEG2/4 Advanced Audio Coding)
FAAD: compressed input bitrate missing, assuming 128kbit/s!
AUDIO: 48000 Hz, 2 ch, s16le, 128.0 kbit/8.33% (ratio: 16000->192000)
ID_AUDIO_BITRATE=128000
ID_AUDIO_RATE=48000
ID_AUDIO_NCH=2
Selected audio codec: [faad] afm: faad (FAAD AAC (MPEG-2/MPEG-4 Audio) decoder)
AO: [dsound] 48000Hz 2ch s16le (2 bytes per sample)
ID_AUDIO_CODEC=faad
VDec: vo config request - 848 x 480 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.
SwScaler: reducing / aligning filtersize 7 -> 8
SwScaler: reducing / aligning filtersize 1 -> 1
SwScaler: reducing / aligning filtersize 7 -> 6
[swscaler @ 0pe797fc]Lanczos scaler, from yuv420p to rgb24 using MMX2
[swscaler @ 0pe797fc]using 8-tap MMX scaler for horizontal luminance scaling
[swscaler @ 0pe797fc]using 8-tap MMX scaler for horizontal chrominance scaling
[swscaler @ 0pe797fc]using n-tap MMX scaler for vertical scaling (BGR)
[swscaler @ 0pe797fc]848x480 -> 854x480
VO: [gl] 848x480 => 854x480 Planar YV12 [zoom]
MPlayer interrupted by signal 11 in module: filter video
ID_SIGNAL=11
My graphic card ATI Radeon HD2300 and video output : gl:yuv=2:force-pbo:ati-hack
it happens even with avi files with xvid and mp3
Old 27th May 2008, 21:16   #851  |  Link
LoRd_MuldeR
Software Developer
@carnage_pl
1. Does your CPU support all the extensions? (MMX, MMX2, SSE and SSE2)
2. What happens if you use "gl" or "directx" renderer?
Old 27th May 2008, 21:20   #852  |  Link
carnage_pl
Posts: n/a
CPU Z says yes (SSE, SSE2, SSE3, SSSE3)
with directx everything is ok
Old 27th May 2008, 21:25   #853  |  Link
LoRd_MuldeR
Software Developer
And what happens with "gl" renderer only, without "force-pbo" or "ati-hack" ???
Old 27th May 2008, 21:33   #854  |  Link
carnage_pl
Posts: n/a
with gl only works but very slowly. Is cause of that may be old drivers for mobile version of my graphic card?
edit: ok I know what casues that. Old drivers. I used 8.5 modded and everything works. But I won't use it because it breaks DXVA.
Old 27th May 2008, 21:47   #855  |  Link
LoRd_MuldeR
Software Developer
That's what "force-pbo" is supposed to fix. It seems "ati-hack" is also required for some ATI cards.
Always try latest drivers first...
Old 27th May 2008, 22:26   #856  |  Link
carnage_pl
Posts: n/a
But i use the latest drivers but for mobile verson the latest was a long time ago...
Old 27th May 2008, 23:26   #857  |  Link
LoRd_MuldeR
Software Developer
ATI's driver support really sucks
At least the latest Catalyst drivers seem to work more or less okay, but still special workarounds are needed ("ati-hack").
In your case I can only recommend to either use the modded drivers or to stick with DirectX renderer ....
[EDIT]
From what I see on the AMD/ATI page, there is "ATI Catalyst™ 8.5" as well as "ATI Catalyst™ Mobility 8.5" available.
So using the latest (Mobility) Catalyst driver package should support your "mobile" card.
Old 28th May 2008, 11:10   #858  |  Link
petran79
I have another problem with the new installer.
While in the Complete installation it installs flawlessly, when I select custom installation, to uncheck the "set file assosiations" box and "Start Menu folders", the installer crashes the moment the extraction begins
"The instruction at "0x7c911e58" referenced memory at "0x0000000". the memory could not be read. " message appears
Both in the Full and Light package. Another time it gave a ntdll.dll error and only once the Custom installation in the light package worked correctly.
Has to do with the AMD Athlon Processor?
petran79 is offline
Old 28th May 2008, 11:20   #859  |  Link
LoRd_MuldeR
Software Developer
You mean you check all section on the components page, except for "Set File Associations" ???
And you also select "Do not create shortcuts" on the startmenu page ???
Seems to work 100% fine here. And no, this should no happen. With no type of CPU.
If the installer crashes like that, this would indicate a bug in NSIS and/or UMUI and there's not much I can do
Can you give some more system info please?
And did you check the stability of your machine with Prim95 and/or Memtest86+ ???
Old 28th May 2008, 11:41   #860  |  Link
carnage_pl
Posts: n/a
saddly only for XP. I have vista home 32 bit
mplayer, mpui, smplayer, windows
