View Poll Results: Are you using tags in your MKV files already ? | |||
No, i dont use tags, because i dont need them | 10 | 13.51% | |
No, i dont use tags, because the apps to read/write them suck | 29 | 39.19% | |
Yes, i use them, but only the very basic ones | 29 | 39.19% | |
Yes, i use them, and many of them | 6 | 8.11% | |
Voters: 74. You may not vote on this poll |
14th January 2004, 19:48 | #23 | Link |
I have only used the language tag for the subtitle files......
I am also planning to use timecode file to do vfr in matroska...... Are these effected? I really don't mind as long as their playback ability is no effected, and here is a easy way to convert to new tags............ |
15th January 2004, 06:09 | #24 | Link | |
Matroska Team
[QUOTE]Originally posted by haibane I have only used the language tag for the subtitle files......[] .. language is an important track element, and not a tag.
16th January 2004, 04:04 | #25 | Link |
Software Developer
ChristianHJW:
I've recently implemented the APETAG v2 system into ZP, it's a VERY simple interface to support and it's easily extendable. Perhaps MKV should just use that. http://www.personal.uni-jena.de/~pfk...v8/apetag.html |
16th January 2004, 08:02 | #26 | Link |
Seņor Member
APEv2 tags cannot be exactly implemented in Matroska as it goes against the basic design. However the new tagging system is very similar in functionality to APEv2. Any program that can parse Matroska and supports APEv2 should be able to write the new Matroska tags. The Matroska tags also offer the ability to have nested tags and to have tags that are specific to tracks and/or chapters and/or attachments.
16th January 2004, 20:29 | #28 | Link |
I like how the new tagging works with the new Foobar plugin, it's great for music. Is anything using the new tagging system yet other than MKVMerge and the Foobar plugin? ( I couldn't find a version of the shell extension later than 2.3)
KpeX Audio FAQs: General | BeSweet | SVCD/MP2 | MP3 | Vorbis | AC3 | DTS | AAC Linux Audio/Video FAQ |
19th January 2004, 03:49 | #30 | Link |
Seņor Member
In Matroska, the reason for putting it at the end is so that it is easy to edit. At the beginning of most Matroska files there is an index that points to where everything else is. (Its not necessary, but it makes things faster) Because of this, you could put the Tags anywhere and it would take the same amount of time to find them. But, if you edit the Tags and it makes it bigger than the space that you allotted for them in the middle of a file, you have to rewrite a good amount of the file. If they are at the end, then you just keep expanding the size.
