Old 19th February 2007, 16:10   #1421  |  Link
vlada
I think it would be very nice to have a new official release with these features: Aften encoder, AVI support, Nero AAC encoder support, latest Vorbis and lame encoders etc.
The only 2 alternatives are foobar2000, which might be difficult to set up for beginners and BeHappy, which isn't very easy neither and has AviSynth and .NET 2.0 dependency.
vlada is offline   Reply With Quote
Old 19th February 2007, 18:40   #1422  |  Link
tebasuna51
tebasuna51's Avatar
If the problem is the .NET 2.0 dependency, you can try another AviSynth method the SoundOut plugin
Old 19th February 2007, 19:06   #1423  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Originally Posted by dwrbudr View Post
Still no go with the latest bsn.dll and WA_aac.dll from the site provided. I can use older enc_aacplus.dll but not that from WinAmp 5.33
No problem here...May I see your logfile ?
@all: new packages should be online this weekend at http://coreforge.org/ (CoreCodec.org moves to CoreForge.org)
Old 19th February 2007, 19:27   #1424  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
@dwrbudr
you need nscrt.dll as well, in order to get it running.
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Old 20th February 2007, 01:28   #1425  |  Link
vlada
tebasuna51
I know this plugin, seems very interesting to me. But it still needs some AviSynth knowledge. I'm trying to find the simplest solution possible for my audio-video processing guides. I think it is BeLight, but many users are now confused with all the different BeLight versions that are around and they don't which one to pick.
Kurtnoise13
That will be great, thank you very much for your work.
Old 20th February 2007, 01:56   #1426  |  Link
Pookie
vlada - ffmpeg can do most of the functions you require. And if this is for beginners anyway, they probably won't notice a big difference in sound quality. I'd still use Aften for AC3, however.
ffmpeg for: aac, mp3, mp2, AVI support, wav
aften for: ac3
Maybe a command line normalizer/limiter and and a resampler like SSRC_HP
Pookie is offline   Reply With Quote
Old 20th February 2007, 06:19   #1427  |  Link
Kurtnoise
Kurtnoise's Avatar
faac is quite old compared to Nero Digital and/or CT encoders and has much less features (no sbr, no ps tools...) than previous ones.
blacksword's vorbis tunings are so great too...
Old 20th February 2007, 08:18   #1428  |  Link
intelinside69
I have a 1.5 gig AVI where i want to extract the audio stream.
After installing the stable version of besweet, upgrading to 1.5b31 and installing belight,
with belight, i used the source file and chose to output to MP3
once i hit the start button, the dos prompt quickly opens and closes and nothing happens
any ideas of how to fix this problem?
i'd really appreciate it
intelinside69 is offline   Reply With Quote
Old 20th February 2007, 09:06   #1429  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
Don't post in the sticky, and don't cross-post. >(
Er, does besweet even work with AVI files? Don't you have to use vdubmod/avimux gui to demux the audio first? Pretty sure you do, so you should try that first.
There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order. ~ Ed Howdershelt
Old 20th February 2007, 09:19   #1430  |  Link
vlada
@foxyshadis: BeSweet supports AVI. But only Belight 0.21 supports them, not 0.22 betas.
@intelinside69: Please provide us your log file, noone can help you without it.
Old 20th February 2007, 10:53   #1431  |  Link
AlanHK
While BeSweet can often work directly on an AVI file, sometimes it fails.
In that case, demux the audio (MP3 or whatever) and run BeSweet on that.
(Though as you want an MP3, quite likely you can just use the demuxed audio as-is.)
AVI2RAW is a simple command line demuxer, find it at
http://pbx.mine.nu/w21sa/mpeg4ip.html
and docs at http://karmak.org/archive/2003/05/encoding.html
To extract MP3 from file video.avi:
avi2raw -a video.avi video.mp3
Or many other ways.
AlanHK is offline   Reply With Quote
Old 20th February 2007, 19:01   #1432  |  Link
intelinside69
worked perfectly, thanks!
Old 27th February 2007, 21:52   #1433  |  Link
Gilgamesh83
just wondering
Is there a dll pack with the latest dlls for download to make it simpler or links to stuff or just a list of what is needed to run all kinds of encoding. I get a little lost searching for the stuff that gets it to work properly.
Great work otherwise!!!!
Gilgamesh83 is offline   Reply With Quote
Old 27th February 2007, 22:53   #1434  |  Link
HeadBangeR77
HeadBangeR77's Avatar
The installer package from ...here... contains most of the libraries you will ever need.
However, if you want to update some in the future or replace some of those you will have to do it manually (that's what I did once a couple of months ago). I haven't heard of any pack, which would be updated on regular basis. And you're right, one might get a bit lost.
Btw. Lame_enc.dll is 3.98 alpha11 - I would suggest using 3.97 final, but that's me.
"Only two things are infinite: the universe and human stupidity, and I'm not sure about the former."
HeadBangeR77 is offline   Reply With Quote
Old 28th February 2007, 04:58   #1435  |  Link
Gilgamesh83
thx
Yeah!
I figured that would be the case, not saying it doesn't work but could be cool if there where a list of what is the latest so one could find the right stuff for the latest version of belight.
Noticed that AAC+ High winamp encoding doesn't work on 5.1 should this be like this or is this a bug I have the latest bsn.dll and all the latest winamp dll except for the fact that winamp 5.33's dll of enc_aacplus.dll isn't supported other wise the latest I think.
Old 28th February 2007, 07:25   #1436  |  Link
m0rtal
open source addict
m0rtal's Avatar
Gilgamesh83
RareWares will help ya
Software is like sex - better when it's free!
m0rtal is offline   Reply With Quote
Old 28th February 2007, 20:53   #1437  |  Link
Kurtnoise
Kurtnoise's Avatar
did you read previous posts ??? Doesn't seem to be the case.
Old 1st March 2007, 00:46   #1438  |  Link
Gilgamesh83
sooory
soooory
have everything working now hehe thx
Old 4th March 2007, 11:19   #1439  |  Link
Gilgamesh83
Well I might aswell do a list of where to find most of the files needed to transcode with belight.
- Belight: http://coreforge.org/projects/belight/ (the new page for belight downloads)
- Besweet link: http://dspguru.doom9.net/ (Download everything, doesn't hurt )
- Winamp AAC+: http://www.winamp.com/ (Download the full pack, remember using aac+ dlls from 5.33 one must use both the enc_aacplus.dll and nscrt.dll from the plugin directory in the winamp install directory)
- Needed Files for Encoding AAC+: http://mirror05.x264.nl/dimzon/ (download All the files, neccesary for encoding 5.1 aac+, great stuff!)
- Nero AAC: http://www.free-codecs.com/Nero_Burn...M_download.htm (Install Nero Burning Rom and copy the aac dll's found in the shared folder in the programs folder or search for Aac.dll, aacenc32.dll and aacplus.dll. I don't think you need registering.)
- Ogg Libvorbis: http://homepage3.nifty.com/blacksword/ (This page has sse enhanced ogg encoder dlls download the libvorbis.dll e.g libvorbis_dll_sse2_lancer20061110.zip, or if your cpu supports sse3 download that. If you don't know what your cpu supports download cpu-z from www.cpuid.com)
- Lame Mp3: http://www.rarewares.org/mp3.html (download either 3.97 or 3.98 in the bundled pack and extract enc_lame.dll to the belight folder, one can also find almost all the needed dlls from this site)
- Belight and stuff: http://kurtnoise.free.fr/BeLight/ (some things that helps belight to work, such as WA_aac-2.4.zip for Winamp AAC+ and bsn.zip and bsn_Aften_20060926.zip for AC3 encoding, remember to only copy the files from the release folder in these zipped files)
- Might be needed: http://www.rarewares.org/files/libmmd9.1.zip (just extract it in the belight folder)
- Flac Flake Encoder: http://sourceforge.net/project/showf...roup_id=177048 (A flake encoder that I got working, might be the wrong one but the ones I downloaded from http://win32builds.sourceforge.net/flake/index.html doesn't work, they are recognized by belight 0.22rc1 but does not encode)
- Aud-X: http://www.aud-x.com/ (In my oppinion not really neccesary if you know how to encode with aac+)
Old 4th March 2007, 15:28   #1440  |  Link
Kurtnoise
Kurtnoise's Avatar
1/ There is already an installer with most libs and executables (except Nero Digital command line tool and Winamp library) in http://kurtnoise.free.fr/BeLight/
2/ Flake from my bundle works perfectly.
3/ No need to post anymore in this thread.
4/ belight != BeLight.
PS: if a moderator can close this thread, this could be great.
