Old 23rd December 2007, 08:19   #2181  |  Link
calinb
calinb's Avatar
Originally Posted by shanghai2004 View Post
<snip>
Seems LPCM on HD-DVD does something special as I'm not able to get the LPCM audio track with any program so far.
Yeah--I can't get LPCM to work with eac3to either. Here's an audio-only sample that I made with EVOdemux. eac3to didn't work on the original (video+audio+subs) .evo either.
This sample plays fine with Nero 7 Showtime.
EDIT:
I took drmpeg's idea and used Linux "head" utility to trim all after the first 10MB:
http://www.sendspace.com/file/q1hjgy
Be advised that the first 9 seconds or so is silence.
calinb is offline
Old 23rd December 2007, 10:18   #2182  |  Link
madshi
Originally Posted by Thunderbolt8 View Post
another thing, got a question to the conversion of dts-hd ma tracks to flac: the rebuilt .evo with this track only has a size of 1,92GB (16-bit; ~2h30min movie length) for 'the pianist'. the converted flac has a size of 978mb in the end, thats actually reduction of more than 50%. Ive already seen this movie and therefore know that especially later in the movie there are lots of quite scenes with much silence, but could it still be that way that the size shrinks down that much?
It's a bit hard to say. However, DTS MA has the "problem" that there's always a 1.5Mbps core that eats bandwidth/space. And on top of that comes the lossless data. With lossless compression without such a core with a very silent / dialog oriented movie you can easily get lower than 1.5Mbps. I have to say that 1.92GB -> 978MB sounds quite extreme, but I guess it's possible. Does the FLAC file have the correct length and does it seems to play fine? If so, it's most probably correct.
madshi is offline
Old 23rd December 2007, 10:30   #2183  |  Link
madshi
Here there are some ideas. The recommended downmix is the Dolby ProLogic II
Thank you!!
madshi is offline
Old 23rd December 2007, 15:02   #2184  |  Link
Thunderbolt8
it has the correct length and also play fine, so then I guess im lucky :P
Thunderbolt8 is offline
Old 23rd December 2007, 15:18   #2185  |  Link
rickardk
Originally Posted by drmpeg View Post
I have a few simple command line tools for cutting files to create samples.
http://www.w6rz.net/head.zip
Creates a file from the first x bytes of a file.
head <infile> <outfile> <length>
head movie.evo clip.evo 50000000
http://www.w6rz.net/tail.zip
Creates a file from the last x bytes of a file.
tail <infile> <outfile> <length>
tail movie.evo clip.evo 50000000
http://www.w6rz.net/clip.zip
Creates a file of x bytes starting at y bytes into the file.
clip <infile> <outfile> <start offset> <length>
clip movie.evo clip.evo 1000000000 50000000
Ron
Thanks!
Samples of Godfellas and Kingdom of Heaven are coming today, not enough time for this yestersday.
Thunderbolt8
Ripping The Pianist right now. I will report filesize of flac when done. You used Sonic CinePlayer Decoder v4.3.0 right?
rickardk is offline
Old 23rd December 2007, 17:08   #2186  |  Link
Thunderbolt8
I used eac3to :P
i installed all these codecs back then when they were still needed for eac3to, dont know if they are also needed with the new versions. I just used the normal command line without any switch.
Old 23rd December 2007, 17:40   #2187  |  Link
nautilus7
nautilus7's Avatar
For dts (all kinds) sonic is the default-best quality decoder. So... if you have it installed, you used it.
You can type:
eac3to -test
to test the decoders/filters/splitters.
nautilus7 is offline
Old 23rd December 2007, 19:58   #2188  |  Link
rickardk
The DTS-HD MA track from The Pianist is 1.87 GB (EU release). The FLAC created with eac3to is 978 MB (1*025*558*426 byte). Length 2h28m.
rickardk is offline
Old 23rd December 2007, 20:24   #2189  |  Link
Thunderbolt8
almost same for me, length of mine is 1.025.559.456 Bytes :P
Old 23rd December 2007, 20:37   #2190  |  Link
calinb
calinb's Avatar
10MB LPCM audio sample:
I trimmed all but the start of the large sample with the Linux "head" utility. This sample plays in Nero Showtime but eac3to fails to produce a playable file, as also reported by shanghai2004. The first 9 seconds is silence.
calinb is offline
Old 23rd December 2007, 20:40   #2191  |  Link
Chupacabras
Possibly the DTS file is beginning in the middle of a DTS frame. eac3to only accepts DTS files which begin with a full DTS frame. Please try running the DTS file through delaycut. Afterwards eac3to should be able to handle the file just fine.
Thanks for advice.
delaycut processed source file, but showed many errors:
Time 00:00:02.110; Frame#= 199. Unsynchronized frame...SKIPPED  68 bytes. Found new synch word
Time 00:00:02.132; Frame#= 201. Unsynchronized frame...SKIPPED  68 bytes. Found new synch word
Too Many Errors. Stop Logging.
Number of written frames = 112737
Number of Errors= 112743
Final (fixed) file is half the original size (original is 571MB, fixed is 216MB). Is that normal?
Then I tryed eac3to with this fixed audio, it wrote this:
X:\eac3to>eac3to.exe "X:\audio_fixed.dts"  "X:\audio_fixed.ac3"  -448  -sonic
DTS, 5.1 channels, 0:20:07, 24 bits, 1536kbit/s, 48khz
Decoding with DirectShow (Sonic Audio Decoder)...
The DirectShow audio decoder didn't accept the input stream.
Chupacabras is offline
Old 23rd December 2007, 20:53   #2192  |  Link
nautilus7
nautilus7's Avatar
Your dts file is f@cked up. Try demuxing the file again, maybe using a different program.
Old 23rd December 2007, 21:18   #2193  |  Link
Chupacabras
I tryed these:
mencoder
projectx (demuxes only video)
dgindex (throws error)
tsremux (throws error)
I don't know what else could I try...
(unfortunately I don't have original disc, file was downloaded)
Old 23rd December 2007, 21:30   #2194  |  Link
nautilus7
nautilus7's Avatar
I am not sure, but i think xport can demux .ts files. Try it.
Old 23rd December 2007, 22:05   #2195  |  Link
TripleH
A little off-topic - something strange about Nero Audio Decoder 2 and Blu-ray Disc Dolby TrueHD audio tracks.
I built the following graph with graphedit:
File source (BD m2ts file) ---> Nero Splitter ---> Nero Audio Decoder 2 ---> Renderer.
The graph plays fine, but when I go to the Nero Audio Decoder 2 settings it reports that the bitrate is 640kbps (so I guess it basically gets the DD core).
Is this a mistake or is it really plays the DD core instead of TrueHD audio ?
Edit: I think the problem is even worse.
I took a look at two BD movies with Dolby TrueHD track using TSRemux and it recognized all of the audio streams, including the TrueHD track.
But in Nero splitter and Haali it only shows 4 audio tracks, where there are five actually, so this makes me think that the problem is the splitter.
Which splitter can recognize Dolby TrueHD tracks ?
TripleH is offline
Old 23rd December 2007, 22:18   #2196  |  Link
nautilus7
nautilus7's Avatar
Without really know how to help you... What do want to do?
Old 24th December 2007, 04:39   #2197  |  Link
Thunderbolt8
yes, it definately can. just leave out the -h option, which is for blu-ray .m2ts files
Old 24th December 2007, 10:20   #2198  |  Link
madshi
Thanks. LPCM demuxing will be fixed in the next build. I found out that the LPCM headers differ between EVO and VOB. That's why demuxing didn't work: The current eac3to version expects VOB LPCM headers! Doh...
madshi is offline
Old 24th December 2007, 10:21   #2199  |  Link
madshi
Originally Posted by Chupacabras View Post
Thanks for advice.
Ah well, delaycut probably just removed all the DTS-HD information. Delaycut doesn't fully support DTS-HD. But still, decoding should work now.
Try "eac3to -test" to check whether the Sonic decoder is working correctly on your PC.
madshi is offline
Old 24th December 2007, 10:22   #2200  |  Link
madshi
In that case I can't help you further since Doom9 is not about pirating but about free rights with the content you legally own. See forum rule 6.
madshi is offline
eac3to
