Old 1st September 2017, 18:47   #4501  |  Link
vinnytx
I hope 10-bit support will be improved.
I mean that it should be available even in windowed mode.
Also, 8-bit videos should not have 10-bit output
vinnytx is offline   Reply With Quote
Old 1st September 2017, 18:58   #4502  |  Link
madshi
Why should 8bit videos not have 10bit output? Videos are YCbCr. Output is usually RGB. The conversion is floating point math, so you have more than 8bit after YCbCr -> RGB conversion.
Old 1st September 2017, 20:01   #4503  |  Link
vinnytx
I thought that conversion was lossy.
Old 1st September 2017, 20:04   #4504  |  Link
yes float to integer is lossy.
but float to 8 bit is more lossy than float to 10 bit.
Old 2nd September 2017, 18:42   #4505  |  Link
vinnytx
I have problems when I play 4k 10-bit videos in fullscreen. I have this error.
I tried many settings in "Video Renderer" > General/Presentation/Composition and I couldn't solve the problem.
Example
http://www.mediafire.com/file/a3knqi...sng/10_bit.mp4
Old 3rd September 2017, 19:56   #4506  |  Link
Shiandow
You don't have enough memory on your GPU apparently. Are you using any renderscipts? Those could make things worse. I think SSIMDownscaler in particular could end up using quite a lot of memory.
Old 4th September 2017, 01:08   #4507  |  Link
vinnytx
Thanks
My video card is 960 gtx with 4GB. I don't use any render script. Have you tested the video I posted?
Old 4th September 2017, 07:55   #4508  |  Link
ryrynz
ryrynz's Avatar
Usually these sorts of problems are related to your graphics card driver installation, uninstall and then reinstall the latest ones.
Old 4th September 2017, 12:55   #4509  |  Link
vinnytx
I uninstalled and reinstalled Nvidia driver and nothing has changed.
I found the problem: when I enable DXVA2 copy-back in Lav Filters x86 the problem occurs.
No problem with MPDN x64 and Lav Filters x64
Old 4th September 2017, 16:14   #4510  |  Link
Shiandow
Are you sure MPDN is actually part of the problem? Does Lav Filter x86 work when you use a different video player?
Old 4th September 2017, 16:39   #4511  |  Link
vinnytx
Yes, I'm sure. Zoom Player and PotPlayer don't have this problem
Old 4th September 2017, 17:35   #4512  |  Link
stax76
stax76's Avatar
Any news on the 2880 DPI issue? I've my own player now but still follow development of other players.
Old 5th September 2017, 10:07   #4513  |  Link
Shiandow
I've had a quick look and it looks like MPDN just didn't like it when it had to resize before it had a chance to initialise everything. I've managed to fix it.
Surprisingly most things actually worked. Apart from some small cosmetic problems.
Still not sure why the x64 vs x86 MPDN would behave differently. One possible explanation is that there is a problem in the settings of the x64 version. Also, the error dialog should have a button to copy the detailed information, if you could get the stacktrace from there I might be able to figure out where the problem occurs.
Also, there's still the possbility that you're actually just running out of GPU memory, and that minor changes in settings affect whether you run out completely or not.
Old 5th September 2017, 12:51   #4514  |  Link
vinnytx
I have problems with MPDN x86.
I uninstalled x86 version and I installed x64. At the moment I can't do other tests. I tried MPDN x86 portable version and it gives me an error regarding filters that are not properly configured (video graph failed to render). That's not a problem since I configured my pc for x64 video players
Old 18th September 2017, 04:08   #4515  |  Link
Anime Viewer
Troubleshooter
Anime Viewer's Avatar
I'm encountering a problem during playback of:
http://tracker.minglong.org/torrents...5D.mkv.torrent
At 20:06 (twenty minutes and six seconds) into the video MPDN stops responding. I tried running in debug mode, but it didn't generate a crash dump. My settings are as follows:
MPDN 64-bit edition
version 2.48.0.3603
XySubFilter with reduce aliasing checked
Prefer: Image Quality
Always use new OpenCL Interop API (I tried disabling this and restarted, but it still crashed at the same part, so I have ruled this out)
Presentation API: Driect3D 11
Graphic Adapter: Nvidia GeForce GTX 680M
Video Renderer:
Colormetric: Automatic
Output Range: Full
Video Output bit depth: 10-bit
Script Chain Deband -> SuperChromaRes -> Super-xBR
Ordered dithering
I tried in full screen and in a window, and both crashed but anyway here is what I'm using for scalers:
Luma up: Jinc with anti-ring
Chroma up: Jinc 4 tap with anti-ring
Luma Down: Softcubic 75
Chroma down: Bicubic 75
If you need any more info, or testing with another setting let me know.
BTW: I ran the video with MPC-HC (with MadVR) and didn't encounter the crash/freeze.
System specs: Sager NP9150 SE with i7-3630QM 2.40GHz, 16 GB RAM, 64-bit Windows 10 Pro, NVidia GTX 680M/Intel 4000 HD optimus dual GPU system. Video viewed on LG notebook screen and LG 3D passive TV.
Last edited by Anime Viewer; 18th September 2017 at 04:09. Reason: added MPC-HC/MadVR test result
Anime Viewer is offline   Reply With Quote
Old 18th September 2017, 10:56   #4516  |  Link
carpedee
I really like this video player, I feel like it puts less strain on my cpu than MPC used with the LAV filters (DX11 helps a lot I guess).
I have a few questions/suggestions regarding some features I didn't find:
- Is it possible to edit the hotkeys like the one to enter in fullscreen mode for example?
- Is it possible to run several instances of MPDN at the same time?
- Is there a hotkey to take a screenshot when playing a video?
carpedee is offline   Reply With Quote
Old 24th September 2017, 05:28   #4517  |  Link
kingpage
I've just been reading up on Madshi's NGU (NG1). It's very impressive. Is there any plan on bring it to MPDN? Does anyone know if it's easier to run than SSSR (SuperxBR, NNEDI3, etc)?
kingpage is offline   Reply With Quote
Old 24th September 2017, 14:21   #4518  |  Link
aufkrawall
NGU will remain madVR exclusive and questions regarding it should be discussed in madVR thread. It got different quality settings and the performance costs range goes from relatively close to Jinc to ~NNEDI3 64 neurons.
Old 25th September 2017, 02:17   #4519  |  Link
Heaud
Is there a way for MPDN to gain window focus when opening a video? Everytime I open a file, the video loads but does not gain focus. Operating system is Windows 10 64-bit with Creators Update.
Heaud is offline   Reply With Quote
Old 25th September 2017, 11:47   #4520  |  Link
Shiandow
Whether NGU will be brought to MPDN, is up to Madshi, and really there's no reason for him to help improve a video player which uses a different renderer. Despite that Madshi has already helped MPDN quite a bit in various ways, but expecting him to implement all of MadVR's functionality in MPDN is just not realistic.
As of now that's the expected behaviour when MPDN is already running when the file opens. It would be fairly easy to change that with a player extension.
You can make MPDN stay on top while playing, which might help. You can enable this in the context menu > Window > Always on Top. And you can limit it to only stay on top while playing in Options > General > Window.
direct3d, mpdn, nnedi3, opencl, reclock
