Old 31st August 2006, 11:41   #201  |  Link
Gabriel_Bouvigne
L.A.M.E. developer
Gabriel_Bouvigne's Avatar
Originally Posted by jruggle
I really do not want to include a decoder with Aften, so either I will make an attempt to do a basic parsing to get exponents only or I might create a completely separate program which would use the liba52 decoder, analyze for dialnorm/DRC, then output modified ac3 frames.
I think that it would be quite nice to be able to compute the "dialog level" directly during encoding. This would allow live encoding.
I think that it sould be possible to obtain a good approximation of dialog level using exponents values (weighted according to freq band)
Gabriel_Bouvigne is offline   Reply With Quote
Old 31st August 2006, 18:00   #202  |  Link
tebasuna51
tebasuna51's Avatar
I don't agree with this comment and similar.
- This force to 2 pass encoding, and not live encoding.
- Automatic Dialog Normalization can work maybe with modern music, but never with movie tracks. The correct DialNorm must be calculated over a selected fragment with dialogs presents, not over the full track with aleatory silences.
- There are enough tools to calculate this parameter over the source to be encoded, and the related DRC type (film, music, speech, ...) I don't know how can be selected automatically.
Old 31st August 2006, 20:40   #203  |  Link
jruggle
The DRC can be done while encoding, but the dialog level is a trickier thing because it is supposed to be constant across the entire stream.
Like Tebasuna said, the dialog level should be measured using just an excerpt which typifies the dialog level of the whole stream. I can modify the wavrms utility program to accept a time or sample range and improve the dialnorm calculation as well...and/or include it in Aften as a 2-pass option.
A possible solution for live encoding might be to add some sort of "dialog calibration" functions in libaften. Something like start_calibration(), append_calibration(audio samples), end_calibration(). This could be used by a live encoder app to do a sort of microphone test. Or it could be used by a production app by passing a user-selected dialog range. Extending that idea to modifying existing AC3 streams, it could optionally take ac3 frames as input and analyze the exponents.
I'm just throwing ideas out here... I need to get the DRC actually working before jumping into any of these.
jruggle is offline   Reply With Quote
Old 1st September 2006, 02:48   #204  |  Link
Mug Funky
interlace this!
Mug Funky's Avatar
with live stuff, the level should already be sorted before it hits the encoder
so i can't see it hurting to just enter a number in the CLI, then let the DRC handle the rest. if it's a little off it shouldn't hurt too bad. considering other encoders rely on user input, there's no reason aften can't too
perhaps a "-live" switch or similar could be added so aften knows how many passes to do? or perhaps 2-pass should be specified explicitly (that's probablythe way to do it).
Old 1st September 2006, 15:39   #205  |  Link
Gabriel_Bouvigne
L.A.M.E. developer
sorry, I mixed both (and it's now more clear due to your comments), mainly because I am not fluent with the AC3 standard.
At the Paris AES convention, some people from Swedish TV explained (roughly) how they are proceding:
DRC is computed on the fly, while dialog level is selected based on the content type (a set of standard values for movies/news/sports/advertising/...).
If we assume that this represent a typical use case, then what is needed is dynamic DRC and ability to manually specify dialog level (even while encoding).
Old 2nd September 2006, 00:51   #206  |  Link
jruggle
That's a good point. There are probably many values (mostly metadata) that it might be good to read from the user context when encoding each frame instead of just at start of encoding. That way the user can change them during encoding without having to reinitialize.
Old 3rd September 2006, 17:57   #207  |  Link
mean
private field
Hello,
Could you rename the private field of aftencontext to something else ?
It is c++ unfriendly
Thank you
mean is offline   Reply With Quote
Old 3rd September 2006, 19:29   #208  |  Link
jruggle
Originally Posted by mean
Hello,
Thank you
Thanks for the info. I just changed it in SVN.
Old 13th September 2006, 03:45   #209  |  Link
ADLANCAS
ADLANCAS's Avatar
Ive made a small batch file that uses the aplication wavrms.exe presents on Aften v0.05 package.
With this batch we can use Aften with a "automatic measure of parameter Dialog Normalization".
rem This batch works on Win-XP
@echo off
setlocal enabledelayedexpansion
wavrms.exe video1.wav | find "Dialnorm" > "Dialnorm.txt"
for %%F in (Dialnorm.txt) do (
    for /F "usebackq tokens=1 delims=B" %%J in ("%%F") do (
      set char=%%J
      set char=!char:~12,2!
      echo Dialnorm = - !char! dB
      aften -b 224 -dnorm !char! -acmod 2 -bwfilter 1 -dcfilter 1 video1.wav video1.ac3
I hope that can be useful for community.
ADLANCAS is offline   Reply With Quote
Old 13th September 2006, 07:44   #210  |  Link
raquete
hi ADLANCAS
...rem This batch works on Win-XP
i'm horrible in command lines and need to ask you if works in 2K too.
so much.
ps:
are you from SP,MG,RJ,CE,RS...? (BR here too)
regards.
search raquete
raquete is offline   Reply With Quote
Old 13th September 2006, 14:37   #211  |  Link
ADLANCAS
ADLANCAS's Avatar
Me too
It should also run in 2K.
(Here is SP)
Old 14th September 2006, 23:46   #212  |  Link
Chainmax
Huh?
Chainmax's Avatar
What is currently being worked on?
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it.
Chainmax is offline   Reply With Quote
Old 15th September 2006, 01:58   #213  |  Link
jruggle
DRC, dialnorm, and speed. Also, I'm trying to make up my mind on changing the build system.
I just applied a simplification of the dialnorm calculation in wavrms. Instead of using the sort/percentile approach as in replaygain, I chose something a bit simpler. Now it does averaging of RMS, but throws out values which are outside of a reasonable dialog range. Some testing has shown that it works pretty well. I'd really like to get some feedback on it though. Since it was applied today, it will show up in tomorrow's daily build.
-Justin
Old 15th September 2006, 02:05   #214  |  Link
ADLANCAS
ADLANCAS's Avatar
You could see his blog:
http://aftenblog.blogspot.com/
Last edited by ADLANCAS; 15th September 2006 at 02:13. Reason: Oh, sorry! I posted in the same time as jruggle posted.
Old 15th September 2006, 02:14   #215  |  Link
Chainmax
Huh?
Chainmax's Avatar
Oh, I forgot about the blog . Justin, do you think channel coupling might be a possibility in the future?
Old 16th September 2006, 21:06   #216  |  Link
raquete
@ jruggle,
i can't wait to use, just waiting for Kurt new Gui with that feature.
jruggle,you left the idea to use replaygain in Aften?
thanks.
search raquete
Old 19th September 2006, 18:18   #217  |  Link
NorthPole
Originally Posted by jruggle View Post
Inline resampling is on my TODO list. Also, optionally downmixing or upmixing the number of channels is on the TODO list. The list just keeps growing!
-Justin
@justin
I know you probably have a long TODO list but... Any chance that you have made any progress on inline resampling? Like from 44100 to 48000.
NorthPole is offline   Reply With Quote
Old 19th September 2006, 21:04   #218  |  Link
Exl
Aften is looking great so far, but I have a file on which it generates bad output. The wav source is this 20 second excerpt:
http://members.home.nl/meuwissenth/0.0.0.wav
Which sounds just fine. Once I run it through Aften with the parameters -b 192 -acmod 2 or even just either one of them, it outputs this:
http://members.home.nl/meuwissenth/0.0.0.ac3
Which plays back with pauses and the seeker bar visibly skipping in VLC Media Player. Am I doing something wrong here?
Exl is offline   Reply With Quote
Old 20th September 2006, 02:15   #219  |  Link
tebasuna51
tebasuna51's Avatar
Seems only VLC are doing something wrong, because Winamp, Foobar, Bsplayer and PowerDVD play correctly the file.
Azid and the new NicAudio (is a 44100 Hz) can decode the 0.0.0.ac3 without problems.
The same wav resampled to 48000 play ok with VLC, and other ac3 44100 Hz have the same problem in VLC.
Edit: my vlc version is 0.8.2
Old 20th September 2006, 03:54   #220  |  Link
jruggle
Yes, sort of. The basic RMS calculation is still there. Replaygain does not have anything to do with dialog level though, it has to do with _overall_ perceived loudness. The 95% point does a good job for that measurement, but for dialog in a movie, for example, it isn't as good. I was adjusting it down by a fixed amount as an educated guess based on sample data...this really was not very accurate though. The new method throws out very quiet and very loud sections, which can occur pretty often in movies, but rarely include normal dialog. Also, the specification of a time range gives the user more control to select a good section of audio which has typical dialog.
