23rd September 2010, 15:33 | #9641 | Link |
hello,i encoded a blu-ray movie with bd rebilder size 43 gb to dvd 5.i get good rasult.this movie had 1080p and have black border on up and.i want to ask help for remove border.how can i removie border with bd rebulider.please help and advance thxxxxxxxxxxxxxxxxxxxx.
23rd September 2010, 17:11 | #9642 | Link |
You mean there's a black bar above and below the picture? If the aspect ratio of the movie is wider than 1.78:1 (i.e. 16:9), the black bars are supposed to be there. Or are you saying the movie has an incorrect aspect ratio?
23rd September 2010, 17:18 | #9643 | Link | |
23rd September 2010, 18:12 | #9644 | Link |
Hi jdobbs. I hope you are well! I think I have an issue related to new versions. When I Abort/Restart a full BD reencoding, it seems to mess up the out-time values of the reencoded .mpls files. It makes some bonuses to not play anymore or the main movie to stop 10 minutes before the end (10:00:00 in-time related?). Here are some screenshots to show you the difference between original and rebuilded .mpls files. I'm on win7 x64, so I don't know if it's 64bit related. I don't seem to encounter this issue when the reencoding is not break.
24th September 2010, 05:34 | #9645 | Link |
Failed to retrive Audio
Following failed in a Movie only extract:
(I had to select alternate Playlist): ----------------------- [19:15:09] BD Rebuilder v0.34.11 (beta) - Source: xxx - Input BD size: 23,38 GB - Approximate total content: [01:55:53.486] - Target BD size: 45,80 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), ABR - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [19:15:11] PHASE ONE, Encoding - [19:15:11] Extracting A/V streams [VID_00066] - [19:15:29] ExtractAudioSubs() 00053 1605 [21:46:53] - Failed to retrieve audio, aborted Code:
[Status] LABEL=xxxx VERSION=v0.34.11 (beta) SOURCE_SIZE=25108813824 SOURCE_VIDEO_SIZE=25108813824 TARGET_SIZE=49178214400 REDUCTION=1.95860364988622 RESIZE_1080=0 AUDIO_TO_KEEP= SUBS_TO_KEEP= BACKUP_MODE=1 MOVIEONLY_TYPE=0 USE_LAVF=-1 QUICK=0 [00066] USE_ORIGINAL=1 AUDIO=000 PGS=00000000000 [00421] USE_ORIGINAL=1 [00422] USE_ORIGINAL=1 [00423] USE_ORIGINAL=1 [00424] USE_ORIGINAL=1 [00425] USE_ORIGINAL=1 [00426] USE_ORIGINAL=1 [00427] USE_ORIGINAL=1 [00428] USE_ORIGINAL=1 [00429] USE_ORIGINAL=1 [00430] USE_ORIGINAL=1 [00431] USE_ORIGINAL=1 [00432] USE_ORIGINAL=1 [00433] USE_ORIGINAL=1 [00434] USE_ORIGINAL=1 [00435] USE_ORIGINAL=1 [00436] USE_ORIGINAL=1 [00437] USE_ORIGINAL=1 [00438] USE_ORIGINAL=1 [00439] USE_ORIGINAL=1 [00752] USE_ORIGINAL=1 [00440] USE_ORIGINAL=1 [00441] USE_ORIGINAL=1 [00442] USE_ORIGINAL=1 [00443] USE_ORIGINAL=1 [00444] USE_ORIGINAL=1 [00445] USE_ORIGINAL=1 [01125] USE_ORIGINAL=1 [00447] USE_ORIGINAL=1 [00448] USE_ORIGINAL=1 [00449] USE_ORIGINAL=1 [00450] USE_ORIGINAL=1 [00451] USE_ORIGINAL=1 [00452] USE_ORIGINAL=1 [00453] USE_ORIGINAL=1 [00454] USE_ORIGINAL=1 [00455] USE_ORIGINAL=1 [00456] USE_ORIGINAL=1 [00457] USE_ORIGINAL=1 [00458] USE_ORIGINAL=1 [00788] USE_ORIGINAL=1 [00459] USE_ORIGINAL=1 [00460] USE_ORIGINAL=1 [00461] USE_ORIGINAL=1 [00462] USE_ORIGINAL=1 [00754] USE_ORIGINAL=1 [00463] USE_ORIGINAL=1 [00464] USE_ORIGINAL=1 [00465] USE_ORIGINAL=1 [00466] USE_ORIGINAL=1 [00467] USE_ORIGINAL=1 [00468] USE_ORIGINAL=1 [00469] USE_ORIGINAL=1 [00470] USE_ORIGINAL=1 [00471] USE_ORIGINAL=1 [00472] USE_ORIGINAL=1 [00473] USE_ORIGINAL=1 [00474] USE_ORIGINAL=1 [00475] USE_ORIGINAL=1 [00476] USE_ORIGINAL=1 [00477] USE_ORIGINAL=1 [00478] USE_ORIGINAL=1 [00479] USE_ORIGINAL=1 [00480] USE_ORIGINAL=1 [00481] USE_ORIGINAL=1 [00482] USE_ORIGINAL=1 [00484] USE_ORIGINAL=1 [00485] USE_ORIGINAL=1 [00810] USE_ORIGINAL=1 [01026] USE_ORIGINAL=1 [01027] USE_ORIGINAL=1 [00816] USE_ORIGINAL=1 [00818] USE_ORIGINAL=1 [00820] USE_ORIGINAL=1 [00822] USE_ORIGINAL=1 [00824] USE_ORIGINAL=1 [00826] USE_ORIGINAL=1 [00828] USE_ORIGINAL=1 [00830] USE_ORIGINAL=1 [00832] USE_ORIGINAL=1 [00834] USE_ORIGINAL=1 [00836] USE_ORIGINAL=1 [00838] USE_ORIGINAL=1 [00840] USE_ORIGINAL=1 [00842] USE_ORIGINAL=1 [00844] USE_ORIGINAL=1 [00846] USE_ORIGINAL=1 [00848] USE_ORIGINAL=1 [00850] USE_ORIGINAL=1 [00852] USE_ORIGINAL=1 [00854] USE_ORIGINAL=1 [00856] USE_ORIGINAL=1 [00866] USE_ORIGINAL=1 [00868] USE_ORIGINAL=1 [00870] USE_ORIGINAL=1 [00872] USE_ORIGINAL=1 [00874] USE_ORIGINAL=1 [00876] USE_ORIGINAL=1 [00878] USE_ORIGINAL=1 [00880] USE_ORIGINAL=1 [00882] USE_ORIGINAL=1 [00884] USE_ORIGINAL=1 [00886] USE_ORIGINAL=1 [00888] USE_ORIGINAL=1 [00890] USE_ORIGINAL=1 [00892] USE_ORIGINAL=1 [00894] USE_ORIGINAL=1 [00896] USE_ORIGINAL=1 [00898] USE_ORIGINAL=1 [00900] USE_ORIGINAL=1 [00902] USE_ORIGINAL=1 [00904] USE_ORIGINAL=1 [00906] USE_ORIGINAL=1 [00908] USE_ORIGINAL=1 [00910] USE_ORIGINAL=1 [00912] USE_ORIGINAL=1 [00914] USE_ORIGINAL=1 [00916] USE_ORIGINAL=1 [00918] USE_ORIGINAL=1 [00920] USE_ORIGINAL=1 [00942] USE_ORIGINAL=1 [00944] USE_ORIGINAL=1 [00946] USE_ORIGINAL=1 [00950] USE_ORIGINAL=1 [00952] USE_ORIGINAL=1 [00954] USE_ORIGINAL=1 [00956] USE_ORIGINAL=1 [00958] USE_ORIGINAL=1 [00960] USE_ORIGINAL=1 [00962] USE_ORIGINAL=1 [00964] USE_ORIGINAL=1 [00966] USE_ORIGINAL=1 [00968] USE_ORIGINAL=1 [00970] USE_ORIGINAL=1 [00972] USE_ORIGINAL=1 [00974] USE_ORIGINAL=1 [00976] USE_ORIGINAL=1 [00978] USE_ORIGINAL=1 [00996] USE_ORIGINAL=1 Last edited by jdobbs; 24th September 2010 at 15:21. |
24th September 2010, 15:23 | #9650 | Link | |
24th September 2010, 17:32 | #9651 | Link |
tsmuxer crashed in win7
----------------------- [18:02:00] BD Rebuilder v0.34.11 (beta) - Source: PRINCE_OF_PERSIA - Input BD size: 23,38 GB - Approximate total content: [01:55:53.486] - Target BD size: 45,80 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), ABR - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [18:02:00] PHASE ONE, Encoding - [18:02:00] Extracting A/V streams [VID_00066] - Extracting A/V to M2TS [VID_00066] - Extracting A/V from M2TS [VID_00066] - Error in attempt to extract audio/subs. - H.264 stream does not contain fps field. Muxing fps=23.976 - Error in attempt to extract audio/subs. - H.264 stream does not contain fps field. Muxing fps=23.976 [18:30:51] - Failed to retrieve audio, aborted |
24th September 2010, 17:44 | #9652 | Link | |
BD Rebuilder experienced an error 1605 Extract Audio Subs() 00053 1605 |
24th September 2010, 17:51 | #9653 | Link | |
You may want to try running TSMUXER independently and see what is causing it to fail. There is a .meta file that is created just before the demux attempt. In this case it would be called "AUD_00066.META". Depending upon where you installed BD-RB and what your working path is, try this: 1. Run CMD from windows start button (or win icon). This will open up a command window. 2. Set youself to the working folder, then go one layer deeper to WORKFILES. 3. Run this command line (modified base on your paths): c:\bd_rebuilder\tools\tsmuxer.exe aud_00066.meta Report what error you get that causes it to abort. Note: The second error "ExtractAudio Subs() 00053 1605" you are receiving is a result of missing files from the first (failed) attempt. Last edited by jdobbs; 24th September 2010 at 18:16. |
24th September 2010, 21:14 | #9654 | Link |
hi!
i'd like to know if this is possible! If i want to rencode a blu-ray movie, without changing the size and audio, but i wanna only convert the Video VC1 to H264, what i have to do? Because if i lower the size, 2-pass, it'll be converted to h264, but if i left the same size, the program leave the VC1 video track intact! hope its possible thx |
25th September 2010, 01:25 | #9655 | Link |
Blackwalker : you can try to add FORCE_ENCODE=1 in BDREBUILDER.INI and just set the wanted BD size as the original, you will have all the parts converted to H264 without any check. More infos in HIDDENOPTS.TXT . Use this if you know what you do.
25th September 2010, 02:35 | #9656 | Link | ||
@jdobbs
Regarding the problem "longtom" is having with "Prince of Persia" you say, Quote:
25th September 2010, 03:36 | #9657 | Link |
@setarip_old
The error reported seems to indicate an issue with the large number of multi-segment parts, not the disc. That's what drives this line: - Extracting A/V to M2TS [VID_00066] If he follows the instructions I gave him he should be able to report why TSMUXER is failing. Last edited by jdobbs; 25th September 2010 at 04:23. |
25th September 2010, 04:25 | #9658 | Link | |
25th September 2010, 05:49 | #9660 | Link | ||
Thx a lot, i'll try!! |
