29th May 2013, 02:19 | #1161 | Link |
Yes - for Youtube, parse &index in url is not supported ... i hope yet
P.S. youtube.com do not support &index tag.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 Last edited by Aleksoid1978; 30th May 2013 at 01:00. |
29th May 2013, 06:04 | #1163 | Link | |
For 16bit - 16bit. For Shared Mode - always is 32 bit float.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
29th May 2013, 22:53 | #1165 | Link |
No. I don't have DVB card and can't test.
30th May 2013, 07:26 | #1167 | Link |
I can't coding & port change(many changes) without testing myself
30th May 2013, 09:19 | #1168 | Link |
You guys haven't touched the DVB code from HC have you? Wouldn't it "just work"? HC is usually quite stable with changes in DVB area, perhaps make a test build for Mercury22 and then if he says it's good
you could get one of the beta testers to test to your liking so it can be committed later? |
30th May 2013, 12:40 | #1169 | Link | |
Need DVB support - use MPC-HC or DVB viewer
30th May 2013, 15:00 | #1170 | Link |
are you guys aware of a bug where the mpc-be process remains after the player has been closed?
I believe mpc-hc may have had the same issue and had it fixed recently - https://github.com/mpc-hc/mpc-hc/commit/9c5bdfe645a41622e6fd4bfa471ff55014a62e30 Last edited by mindbomb; 30th May 2013 at 19:34. |
30th May 2013, 22:56 | #1171 | Link |
in MPC-BE it's bug a present ?? I do not have same bug.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 Last edited by Aleksoid1978; 31st May 2013 at 00:24. |
31st May 2013, 03:16 | #1173 | Link |
http://pan.baidu.com/share/link?shar...&uk=2302073050
Cant load these .sup |
31st May 2013, 03:57 | #1174 | Link | |
Load external "matroska + subtitle" as external subtitle do not supported.
3rd June 2013, 07:48 | #1175 | Link |
Sorry for ignorant question, but ... I see discussion of v1.1.3 from January, but now it looks like the latest version is v1.1.1. Are they different branches or different levels of stability? Why should I choose one over the other?
(I'm using 1.1.1 now with no major problems, on a pretty slow/crusty W7 box) |
3rd June 2013, 08:52 | #1176 | Link |
1.1.1 is the dev version. Just grab the latest from the Sourceforge website
I'm not sure that they'll be releasing a new "stable" any time soon.. there's not really any need when the dev build is so stable. |
4th June 2013, 22:52 | #1179 | Link | |
Anyway I want to download the 64-bit version but there is one compiled in Visual Studio 2010 and one in 2012, what is the difference? Also if I enable the option "Replace file name with title" it uses the title and year in the case of mp3 files, i.e. "Dazed and Confused (1969)"; is there a way to change it to "Led Zeppelin - Dazed and Confused"? Last edited by ceb; 4th June 2013 at 23:12. |
5th June 2013, 08:44 | #1180 | Link | |
There may be slight differences in performance between the two but it won't be noticeable. Either is fine, I'm aware of no drawbacks to using the VS2012 version now, so unless someone can come up with a reason not to use it, I'd prefer that. |
