3rd April 2014, 18:44 | #19902 | Link | |
Regardless of what disc I test, BD-RB does not deduct the stripped/core extracted audio from the calculations for disc size. It always assumes the movie's original size divided by target is the compression needed. I can't find anything where the calculation does work properly. Maybe it's something weird about my setup, maybe most people just aren't noticing because the calculation still includes a reduction for the stripped audio so the difference is small for most discs. Maybe no one is bothering to do the math since the numbers are reported in bytes. The point being, assuming it's just me, I'm afraid it's probably irreproducible. No mystery. |
3rd April 2014, 19:52 | #19904 | Link | |
3rd April 2014, 20:17 | #19906 | Link | |
[Edit] I see right away why it is not doing it. It is a multipart source. BD-RB currently only looks at one part at a time as it encodes them. Since it cannot tell the output size of the other sections it never keeps the original on a multipart source. I'll have to get creative and see if there is a way I can look at all the sections combined. I'm not sure when I will do that. Last edited by jdobbs; 3rd April 2014 at 20:22. |
3rd April 2014, 20:26 | #19907 | Link | |
While I was running the latest drivers for HD4000 I did not have a display connected to the GPU. Instead I used the "connect to VGA display" trick to activate HD4000. Once FRIMEncoder began crashing all the time, I lugged the rig into my office, connected a real display to HD4000 and downgraded drivers to the previous release. After all that the rig has performed pretty much perfectly with both decode and encode done in hardware. And it's seriously fast even with quality setting 2: 60-70 fps all the way. |
3rd April 2014, 20:39 | #19908 | Link | |
The auto quality used ABR on this one for me and came out more than a gigabyte light for a BD25. Which works out to about the stripped audio size times the compression ratio applied. The messed up jumble that is Red 2 is not present on the other discs I tested. I really don't want to see you wasting too much time on this. My computer is old and will be rebuilt within a month and I'm running WinXP which will reach end of life in a couple weeks. If I see the same thing on my new system though, I will be sure to comment. Last edited by DoctorM; 3rd April 2014 at 20:43. |
3rd April 2014, 20:45 | #19909 | Link | |
I don't think this has anything to do with your rig. BD-RB just won't keep the originals on multi-part sources. It never has. Last edited by jdobbs; 3rd April 2014 at 20:47. |
3rd April 2014, 22:30 | #19910 | Link |
About bogus playlists:
I just came across a disc which took about 10 minutes for scanning the playlists. Eventually the total duration indicated something like 90 hours playback time, but the Quick-Play menu (set to 10 minutes threshold) was empty. I found that there were 2 playlists with 25 hours duration and 712 chapters each (probably still pictures). No wonder that BDRB got confused. I had to manually delete the 2 playlists, set the threshold to 21 minutes in order to keep the Feature and 2 wanted Extras. The backup is running now .... The disc is Game of Thrones, S2D5. I wonder whether BDRB should perhaps do a sanity check to skip insane playlists? |
3rd April 2014, 22:50 | #19911 | Link | |||
Jdobbs, I just finished pacific rim few hours ago. During process I choose to keep English subtitle and audio only. However I recently watched and I see their entry. (Please note I am not talking about menu but actual stream name itself while playing in software player)
If you fail to plan; you plan to fail, would you not agree? Think about it. |
3rd April 2014, 23:50 | #19912 | Link | |
https://forum.slysoft.com/showthread...886#post380886 |
4th April 2014, 00:15 | #19913 | Link | |
Update: Just found win64-153318. I will install it and try again. Last edited by dfsooner; 4th April 2014 at 00:23. |
4th April 2014, 00:42 | #19914 | Link |
[04/03/14] BD Rebuilder v0.46.14 (beta)
[10:22:39] Source: THE_ODD_LIFE_OF_TIMOTHY_GREEN - Input BD size: 39.99 GB - Approximate total content: [02:27:53.489] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [10:22:49] PHASE ONE, Encoding - [10:22:49] Processing: VID_00800 (1 of 20) - [10:22:49] Extracting A/V streams [VID_00800] - [11:03:22] Reencoding video [VID_00800] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 150,504 frames - Bitrate: 20,301 Kbs - [11:03:22] Reencoding: VID_00800, Pass 1 of 1 - [11:56:15] Video Encode complete - [11:56:15] Processing audio tracks - Track 4352 (eng): Keeping original audio - [11:56:15] Multiplexing M2TS - [12:06:47] Processing: VID_00875 (2 of 20) - [12:06:47] Extracting A/V streams [VID_00875] - [12:07:38] Reencoding video [VID_00875] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,992 frames - Bitrate: 18,696 Kbs - [12:07:38] Reencoding: VID_00875, Pass 1 of 1 - [12:10:20] Video Encode complete - [12:10:20] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:10:20] Multiplexing M2TS - [12:10:37] Processing: VID_00876 (3 of 20) - [12:10:37] Extracting A/V streams [VID_00876] - [12:13:57] Reencoding video [VID_00876] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 13,310 frames - Bitrate: 18,506 Kbs - [12:13:57] Reencoding: VID_00876, Pass 1 of 1 - [12:25:46] Video Encode complete - [12:25:46] Processing audio tracks - Track 4352 (eng): Keeping original audio ----... - [13:02:19] Reencoding: VID_00890, Pass 1 of 1 - Encode failed. Aborting. - BD-Rebuilder v0.46.14 (beta) - Windows Version: 6.1 [7601] - Working Path Free Space: 774.10GB - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: 1.9.42.1, Ok - FFDSHOW: 4504, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - AnyDVD settings check: Ok. - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [13:02:21] - Failed video encode, aborted |
4th April 2014, 00:44 | #19915 | Link | |
4th April 2014, 00:48 | #19916 | Link | |
4th April 2014, 00:54 | #19918 | Link | |
example 1. English 2. French 3. Spanish Although all are visible in TMT, but changing any of them result in English, which of course is expected. Normally you only have entry for which stream exist.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 4th April 2014 at 01:05. |
4th April 2014, 01:53 | #19919 | Link |
[10:22:39] Source: THE_ODD_LIFE_OF_TIMOTHY_GREEN - Input BD size: 39.99 GB - Approximate total content: [02:27:53.489] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [10:22:49] PHASE ONE, Encoding - [10:22:49] Processing: VID_00800 (1 of 20) - [10:22:49] Extracting A/V streams [VID_00800] - [11:03:22] Reencoding video [VID_00800] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 150,504 frames - Bitrate: 20,301 Kbs - [11:03:22] Reencoding: VID_00800, Pass 1 of 1 - [11:56:15] Video Encode complete - [11:56:15] Processing audio tracks - Track 4352 (eng): Keeping original audio - [11:56:15] Multiplexing M2TS - [12:06:47] Processing: VID_00875 (2 of 20) - [12:06:47] Extracting A/V streams [VID_00875] - [12:07:38] Reencoding video [VID_00875] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,992 frames - Bitrate: 18,696 Kbs - [12:07:38] Reencoding: VID_00875, Pass 1 of 1 - [12:10:20] Video Encode complete - [12:10:20] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:10:20] Multiplexing M2TS - [12:10:37] Processing: VID_00876 (3 of 20) - [12:10:37] Extracting A/V streams [VID_00876] - [12:13:57] Reencoding video [VID_00876] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 13,310 frames - Bitrate: 18,506 Kbs - [12:13:57] Reencoding: VID_00876, Pass 1 of 1 - [12:25:46] Video Encode complete - [12:25:46] Processing audio tracks - Track 4352 (eng): Keeping original audio ... [12:55:01] Reencoding: VID_00887, Pass 1 of 1 - [12:59:49] Video Encode complete - [12:59:49] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:59:49] Multiplexing M2TS - [13:00:17] Processing: VID_00888 (15 of 20) - [13:00:17] Extracting A/V streams [VID_00888] - [13:00:36] Reencoding video [VID_00888] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,537 frames - Bitrate: 9,583 Kbs - [13:00:36] Reencoding: VID_00888, Pass 1 of 1 - [13:01:43] Video Encode complete - [13:01:43] Processing audio tracks - Track 4352 (eng): Keeping original audio - [13:01:43] Multiplexing M2TS - [13:01:52] Processing: VID_00890 (16 of 20) - [13:01:52] Extracting A/V streams [VID_00890] - [13:02:19] Reencoding video [VID_00890] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,668 frames - Bitrate: 10,215 Kbs - [13:02:19] Reencoding: VID_00890, Pass 1 of 1 - Encode failed. Aborting. - BD-Rebuilder v0.46.14 (beta) - Windows Version: 6.1 [7601] - Working Path Free Space: 774.10GB - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: 1.9.42.1, Ok - FFDSHOW: 4504, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - AnyDVD settings check: Ok. - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [13:02:21] - Failed video encode, aborted ---------------------- Last edited by wakko709; 4th April 2014 at 01:55. |
4th April 2014, 03:17 | #19920 | Link |
---------------------- [04/03/14] BD Rebuilder v0.46.14 (beta) [16:42:43] Source: THE_ODD_LIFE_OF_TIMOTHY_GREEN - Input BD size: 39.99 GB - Approximate total content: [02:27:53.489] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [16:43:08] PHASE ONE, Encoding - [16:43:08] Processing: VID_00800 (1 of 20) - [16:43:08] Extracting A/V streams [VID_00800] - [17:23:38] Reencoding video [VID_00800] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 150,504 frames - Bitrate: 20,301 Kbs - [17:23:38] Reencoding: VID_00800, Pass 1 of 1 - [18:12:59] Video Encode complete - [18:12:59] Processing audio tracks - Track 4352 (eng): Keeping original audio - [18:12:59] Multiplexing M2TS - [18:23:16] Processing: VID_00875 (2 of 20) - [18:23:16] Extracting A/V streams [VID_00875] - [18:24:07] Reencoding video [VID_00875] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,992 frames - Bitrate: 18,696 Kbs - [18:24:07] Reencoding: VID_00875, Pass 1 of 1 - [18:26:36] Video Encode complete - [18:26:36] Processing audio tracks - Track 4352 (eng): Keeping original audio - [18:26:36] Multiplexing M2TS - [18:26:53] Processing: VID_00876 (3 of 20) - [18:26:53] Extracting A/V streams [VID_00876] - [18:30:13] Reencoding video [VID_00876] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 13,310 frames - Bitrate: 18,506 Kbs - [18:30:14] Reencoding: VID_00876, Pass 1 of 1 - [18:41:02] Video Encode complete - [18:41:02] Processing audio tracks - Track 4352 (eng): Keeping original audio - [18:41:02] Multiplexing M2TS - [18:42:03] Processing: VID_00877 (4 of 20) - [18:42:03] Extracting A/V streams [VID_00877] - [18:45:44] Reencoding video [VID_00877] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 14,689 frames - Bitrate: 18,509 Kbs - [18:45:44] Reencoding: VID_00877, Pass 1 of 1 - [18:57:59] Video Encode complete - [18:57:59] Processing audio tracks - Track 4352 (eng): Keeping original audio - [18:57:59] Multiplexing M2TS - [18:59:34] Processing: VID_00878 (5 of 20) - [18:59:34] Extracting A/V streams [VID_00878] - [18:59:41] Reencoding video [VID_00878] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 168 frames - Bitrate: 6,674 Kbs - [18:59:41] Reencoding: VID_00878, Pass 1 of 1 - [18:59:45] Video Encode complete - [18:59:45] Processing audio tracks - Track 4352 (eng): Keeping original audio - [18:59:45] Multiplexing M2TS - [18:59:50] Processing: VID_00879 (6 of 20) - [18:59:50] Extracting A/V streams [VID_00879] - [19:00:10] Reencoding video [VID_00879] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 954 frames - Bitrate: 18,736 Kbs - [19:00:10] Reencoding: VID_00879, Pass 1 of 1 - [19:01:01] Video Encode complete - [19:01:01] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:01:01] Multiplexing M2TS - [19:01:09] Processing: VID_00880 (7 of 20) - [19:01:09] Extracting A/V streams [VID_00880] - [19:01:15] Reencoding video [VID_00880] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 168 frames - Bitrate: 6,674 Kbs - [19:01:15] Reencoding: VID_00880, Pass 1 of 1 - [19:01:18] Video Encode complete - [19:01:19] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:01:19] Multiplexing M2TS - [19:01:23] Processing: VID_00881 (8 of 20) - [19:01:23] Extracting A/V streams [VID_00881] - [19:01:46] Reencoding video [VID_00881] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,145 frames - Bitrate: 18,634 Kbs - [19:01:47] Reencoding: VID_00881, Pass 1 of 1 - [19:02:48] Video Encode complete - [19:02:48] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:02:48] Multiplexing M2TS - [19:02:58] Processing: VID_00882 (9 of 20) - [19:02:58] Extracting A/V streams [VID_00882] - [19:03:04] Reencoding video [VID_00882] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 168 frames - Bitrate: 6,674 Kbs - [19:03:04] Reencoding: VID_00882, Pass 1 of 1 - [19:03:07] Video Encode complete - [19:03:07] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:03:07] Multiplexing M2TS - [19:03:12] Processing: VID_00883 (10 of 20) - [19:03:12] Extracting A/V streams [VID_00883] - [19:03:41] Reencoding video [VID_00883] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,583 frames - Bitrate: 18,665 Kbs - [19:03:41] Reencoding: VID_00883, Pass 1 of 1 - [19:05:00] Video Encode complete - [19:05:00] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:05:01] Multiplexing M2TS - [19:05:12] Processing: VID_00884 (11 of 20) - [19:05:12] Extracting A/V streams [VID_00884] - [19:05:18] Reencoding video [VID_00884] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 168 frames - Bitrate: 6,674 Kbs - [19:05:18] Reencoding: VID_00884, Pass 1 of 1 - [19:05:21] Video Encode complete - [19:05:21] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:05:22] Multiplexing M2TS - [19:05:26] Processing: VID_00885 (12 of 20) - [19:05:26] Extracting A/V streams [VID_00885] - [19:05:44] Reencoding video [VID_00885] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 790 frames - Bitrate: 18,676 Kbs - [19:05:44] Reencoding: VID_00885, Pass 1 of 1 - [19:06:23] Video Encode complete - [19:06:23] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:06:23] Multiplexing M2TS - [19:06:31] Processing: VID_00886 (13 of 20) - [19:06:31] Extracting A/V streams [VID_00886] - [19:06:37] Reencoding video [VID_00886] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 168 frames - Bitrate: 6,674 Kbs - [19:06:37] Reencoding: VID_00886, Pass 1 of 1 - [19:06:40] Video Encode complete - [19:06:40] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:06:40] Multiplexing M2TS - [19:06:44] Processing: VID_00887 (14 of 20) - [19:06:44] Extracting A/V streams [VID_00887] - [19:08:24] Reencoding video [VID_00887] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 6,749 frames - Bitrate: 18,632 Kbs - [19:08:25] Reencoding: VID_00887, Pass 1 of 1 - [19:12:34] Video Encode complete - [19:12:34] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:12:35] Multiplexing M2TS - [19:13:02] Processing: VID_00888 (15 of 20) - [19:13:02] Extracting A/V streams [VID_00888] - [19:13:20] Reencoding video [VID_00888] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,537 frames - Bitrate: 9,583 Kbs - [19:13:21] Reencoding: VID_00888, Pass 1 of 1 - [19:14:19] Video Encode complete - [19:14:19] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:14:19] Multiplexing M2TS - [19:14:27] Processing: VID_00890 (16 of 20) - [19:14:27] Extracting A/V streams [VID_00890] - [19:14:54] Reencoding video [VID_00890] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,668 frames - Bitrate: 10,215 Kbs - [19:14:54] Reencoding: VID_00890, Pass 1 of 1 - Encode failed. Aborting. - BD-Rebuilder v0.46.14 (beta) - Windows Version: 6.1 [7601] - Working Path Free Space: 774.10GB - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: 1.9.42.1, Ok - FFDSHOW: 4504, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - AnyDVD settings check: Ok. - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [19:14:56] - Failed video encode, aborted Last edited by jdobbs; 4th April 2014 at 13:47. |
