12th June 2017, 16:58 | #14922 | Link |
What happens if you manually run \\DESKTOP-8NBTRJ0\RipBot264temp\Job1\Chunks\1.cmd from remote-pc?
Ps. That behaviour seen on your video means that something is wrong with shared folder. (ACCESS DENIED)
12th June 2017, 18:53 | #14923 | Link |
ByteShare
Is there a way to specify avs2yuv64.exe rather than avs2yuv.exe when using MT? I think this might be the reason I get issues (often encodes cut out early) with MT in RipBot but not another application.
13th June 2017, 16:21 | #14924 | Link | |
AviSynth 64bit will require ALL plugins in script to be 64 bit as well. Not all plugins are available for x64 architecture.
13th June 2017, 16:50 | #14925 | Link | |
ByteShare
For example MDegrain: http://avisynth.nl/index.php/Temporal_Degrain I thought was x64. Sorry if I'm wasting your time, just thought this was easier than it seems now that you explained it a little. |
13th June 2017, 17:37 | #14926 | Link |
I mean that every single plugin which is used by RipBot264 would have to be 64bit. Not only MDegrain.
13th June 2017, 19:10 | #14927 | Link | |
ByteShare
RipBot264v1.19.6\Tools\avs2yuv\avs2yuv64.exe -Update- Don't mean to come off hostile, just wondering if there are other places that RipBot will use the x64 version? Last edited by byteshare; 13th June 2017 at 19:16. Reason: Clarify |
13th June 2017, 19:34 | #14928 | Link |
Because It is part of package. Generally I do not delete any files after extraction. I just keep everything intact.
https://github.com/MasterNobody/avs2yuv/releases
13th June 2017, 20:52 | #14929 | Link | |
ByteShare
14th June 2017, 15:20 | #14930 | Link | |
But, this other computer, also does not want to encode with the option "distributed encoding" edit: I have an NAS encoder directly on are disk that is in network will fix the problem? If yes, how ? Last edited by Nosirus; 14th June 2017 at 15:24. |
14th June 2017, 18:32 | #14931 | Link |
When you get this https://youtu.be/ScGt6vEu5co what do you see in Encoding Server app window?
14th June 2017, 20:27 | #14932 | Link | |
I do not know how to make it work once, it seems to link to the "residential group" but the folder "D:\Temp\RipBot264temp" is automatically deleted The network management of windows is really a horror! I often have this error |
15th June 2017, 13:30 | #14933 | Link |
Have you disabled Password protected sharing?
https://youtu.be/b-BICnj62iE?t=13s
15th June 2017, 15:13 | #14934 | Link |
Use NAS share drive instead of a local drive for Temp
Looking at most of the scripts created, it looks as if RB uses the netbios name of the locations of the directories and file locations.
can you make it so that i can use a share on a NAS instead? I gather that in the ripbot264.ini file that the variable TEMP translates into a netbios name for the temp location and the job working directory when in DE mode. I tried setting the TEMP variable as StoreTempFilesin=\\nas\sharedrive as the temp location, which Iwould translate expect it to translate to \\nas\sharedrive\Temp\RipBot264temp\ But that doesn't seem to work. Any plan to allow us to use a NAS unit instead of having the files local? or suggestions how i could accomplish? |
15th June 2017, 16:35 | #14935 | Link | |
The folder share "D:\Temp\RipBot264temp" is well indicated, but I have to re-apply it for it to work RipBot264 seems to change rights every time, possible? Last edited by Nosirus; 15th June 2017 at 16:42. |
15th June 2017, 20:57 | #14936 | Link | |
How about this question?
16th June 2017, 14:59 | #14938 | Link |
Just "encoding terminated" in loop
https://www.youtube.com/watch?v=3MMWx1ni_Fk What's happening, thanks for your support |
21st June 2017, 16:18 | #14939 | Link | |
ByteShare
For example: C:\Temp\RipBot264temp\Job238\Chunks\1.avs load the 1.avs into AvsPmod while the encode is trying in RipBot and see what error it gives you (bottom left click the triangle). AvsPmod: https://avspmod.github.io/ |
24th June 2017, 17:40 | #14940 | Link |
Batch Problem In New Release
In version 1.19.6, the batch function is not working correctly (at least, not on my Win7 system). Previous versions were fine.
I add the files (about 45 files) and they all appear in the “Batch mode” batch list. However, when I click “Start”, the pre-processing begins, but only the first 3 files are processed out of the 45 in the batch list. I then click “Done”, after those 3 are pre-processed, and those 3 files appear, as they should, in the list of jobs that begin to process. Those 3 then are converted correctly. Also, thanks Atak_Snajpera, for adding custom script in batch mode, although I haven’t tried it yet due to the above problem. |
