Old 3rd July 2009, 12:53   #9061  |  Link
picman1
Thanks Atak that's good to know.
I downloaded the trial version and after trying different gui's and finally from the command line using these examples from a previous post :eac3to app.dts app.pcm -0,2,1,3,4,5,6,7
pcm2tsmu app.pcm output.pcm -c 8
I got a good 7.1 with correct speaker layouts.
Then I used Tsmuxer to bring the video and audio together and the video and audio looks and sounds great.
If I upgrade this version to TMT 3 will I have to use the same commands or is there a better way to get the correct 7.1 stream with the new version?
What version of TMT 3 will I need to upgrade to, standard, gold or platinum?
Thanks for the help.
picman1 is offline
Old 3rd July 2009, 15:54   #9062  |  Link
Fiffy
ArcSoft Decoder in TMT 3.0 works as well with eac3to.
Could you tell us how you made it work? Eac3to doesn't recognize the Arcsoft filters with a vanilla TMT3 install.
Fiffy is offline
Old 3rd July 2009, 16:47   #9063  |  Link
xkodi
1) TMT2 installs dtsdecoderdll.dll version 1.1.0.0
2) TMT3 installs dtsdecoderdll.dll version 1.1.0.1
3) TMT 3.0.1.133 Patch installs dtsdecoderdll.dll version 1.1.0.5
http://www.arcsoft.com/downloads/dig...update_all.exe
you need to have installation of TMT2 on which eac3to recognize the dtsdecoderdll.dll, i.e. "eac3to -test" returns:
ArcSoft DTS Decoder (1.1.0.0) works fine
then just replace dtsdecoderdll.dll version 1.1.0.0 with version 1.1.0.1 or version 1.1.0.5 from TMT3 and then when you run "eac3to -test" you should get:
ArcSoft DTS Decoder (1.1.0.1) works fine
or
ArcSoft DTS Decoder (1.1.0.5) works fine
4) TMT 3.5 installs dtsdecoderdll.dll version 1.1.0.10, but it doesn't work with eac3to.
BTW, there is also new CinemasterAudio.DLL version 4.3.0.236 from the new version 2.6.3 of SONIC CineVision, which works good with eac3to. if you look here:
http://forum.doom9.org/showthread.ph...14#post1158014
and here:
http://forum.doom9.org/showthread.ph...81#post1212881
you will see that this is the first new version of CinemasterAudio.DLL from very long time that works good with eac3to
xkodi is offline
Old 3rd July 2009, 19:26   #9064  |  Link
Fiffy
I don't understand. Are you saying I should replace the dll in a TMT2 installation with one from TMT3? That's not what I want. I want to switch to TMT3, but retain a DTS filter that is usable from eac3to. Before the current TMT3 beta, it was possible to keep TMT2 and 3 installed in parallel, but the beta (and presumably the upcoming official update) doesn't allow that anymore, so it is currently not easily possible to use TMT3 beta while keeping a filter that is usable from eac3to.
Fiffy is offline
Old 3rd July 2009, 20:38   #9065  |  Link
Joniii
I got some errors while ripping one Blu-ray. Do I need to worry about this (audio/video out of sync or something) or did eac3to fix everything?
1: MPEG2, 1080p24 /1.001 (16:9)
2: DTS Master Audio, 5.1 channels, 24 bits, 48khz
   (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48khz)
[a02] Extracting audio track number 2...
[v01] Extracting video track number 1...
[a02] Extracting DTS core...
[v01] Creating file "e:\koh.mpeg2"...
[a02] Creating file "e:\koh.dts"...
[a02] [1:30:49] The source file seems to be damaged (discontinuity).  <WARNING>
[v01] [1:30:49] The source file seems to be damaged (discontinuity).  <WARNING>
[a02] This track is not clean.  <WARNING>
[a02] [3:09:33] The source file seems to be damaged (discontinuity).  <WARNING>
[v01] Video overlaps for 14 frames at playtime 1:30:48.  <WARNING>
[a02] Audio overlaps for 61ms at playtime 1:30:49.  <WARNING>
[a02] Starting 2nd pass...
[a02] Realizing DTS gaps...
Video track 1 contains 272688 frames.
eac3to processing took 16 minutes, 34 seconds.
Done.
Joniii is offline
Old 3rd July 2009, 20:44   #9066  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
You just need following files from TMT 3.0 package
ASAudioHD.ax
dtsdecoderdll.dll
MagCore.dll
MagPCMac.dll
MagUIEngine.dll
MagUIInter.dll
Once you have them you can remove TMT from your computer if you don't like it.
Then copy all .dlls to System32 and register ASAudioHD.ax with regsvr32.exe
Atak_Snajpera is offline
Old 3rd July 2009, 20:57   #9067  |  Link
rica
Hi madshi, where the hell are you?
We've all missed you here, at least me
_ _ _ _ _ _ _
rica is offline
Old 3rd July 2009, 23:17   #9068  |  Link
Thunderbolt8
ASAudioHD.ax
dtsdecoderdll.dll
MagCore.dll
MagPCMac.dll
MagUIEngine.dll
MagUIInter.dll
is there any advantage of using the tmt3 files compared to the standard tmt1 files (when not using the tmt prog itself)?
Thunderbolt8 is offline
Old 3rd July 2009, 23:38   #9069  |  Link
jj666
Done.
Rerip your disk, I'd be concerned with such a log.
-jj-
jj666 is offline
Old 4th July 2009, 00:29   #9070  |  Link
Thunderbolt8
Originally Posted by rack04 View Post
Is there a way to override the removal of the fullrange flag from h264 streams?
EDIT: Nevermind I found "-keepFullRange"
what is the fullrange flag actually for, whats its purpose?
Old 4th July 2009, 03:20   #9071  |  Link
73ChargerFan
73ChargerFan's Avatar
It specifies that the video was encoded to use 0-255 instead of 16-235 values.
73ChargerFan is offline
Old 4th July 2009, 04:00   #9072  |  Link
Inspector.Gadget
ASAudioHD.ax
dtsdecoderdll.dll
MagCore.dll
MagPCMac.dll
MagUIEngine.dll
MagUIInter.dll
I did this on Vista x64 because I hate having TMT3 installed - I put all dlls in both SysWOW64 and System32 and then registered the filter in System32 - and eac3to doesn't see Arcsoft DTS decoder as installed. Argh! Any suggestions?
Inspector.Gadget is offline
Old 4th July 2009, 05:57   #9073  |  Link
Kythe
Guys, I'm getting an odd error. It's cropped up every now and then, and I'm wondering whether anyone else has seen it...
When demuxing an HD track (either DTS Master Audio or TrueHD) to flac from a movie file, the decoding sometimes quits with the error "The FLAC decoder thread seems to hang". This happened most recently during the second pass of a demux. Eac3to noted multiple overlaps in the demuxed audio track.
Does anyone have any idea what could be causing this, and how to fix it? I'm running this on older hardware (a single core, 1 GHz Pentium).
Kythe is offline
Old 4th July 2009, 12:34   #9074  |  Link
drlove
Restore diagnorm values
Hi, after using eac3to w/o -keepdiagnorm my TrueHD track has no diagnorm info at all and my A/V interpret that as -0dB and normalize to -31dB = the volume is very low. If I run the eac3to ones again on the track the log shows no diagnorm value at all, shouldn't eac3to sett the diagnorm to -31dB and not remove the value?
Can I add diagnorm info, of say -27dB, to a TrueHD track using eac3to? I don't have the source at my summer house so I can't redo the rip from the source BD at the moment. I only have the TrueHD track and the video file at my laptop/PCH.
Best regards L.
drlove is offline
Old 4th July 2009, 18:29   #9075  |  Link
DoomBot
Best regards L.
That would be nice if you could restore diagnorm info some how, if it could be done how do we know what the db would be to restore it after it was removed in the past. Is it always -27db or what?
DoomBot is offline
Old 4th July 2009, 18:47   #9076  |  Link
Atak_Snajpera
1) Copy all dlls to SysWOW64
2) Register: x:\Windows\sysWOW64\regsvr32.exe x:\Windows\sysWOW64\ASAudioHD.ax
Still nothing?
Old 4th July 2009, 18:52   #9077  |  Link
Inspector.Gadget
That's exactly what I did. Weird. I'll try it again after reinstalling TMT3 and see if it's some sort of conflict. Thanks for the help.
Old 4th July 2009, 19:34   #9078  |  Link
Atak_Snajpera
I also tested on W7 x64. No problems.
Old 4th July 2009, 21:26   #9079  |  Link
Inspector.Gadget
Thanks for the help, Atak, but it's not working. When I have TMT3 installed, eac3to can't find the DTS decoder. When I uninstall it, reboot, and copy the relevant DLLs and decoder into SysWOW64 and use exactly the commands above, I get a success message but eac3to still can't find the decoder. I'm beginning to think that this is some sort of version incompatibility.
Old 5th July 2009, 00:25   #9080  |  Link
yesgrey
When backing up the movies, I would like to remove the final credits, so I can save some space. If I use the -edit option I know I can remove the last part of the audio data, but is there in eac3to (or any other tool) an option for removing the last part of the video data?
yesgrey is offline
eac3to
