16th October 2009, 16:13 | #5624 | Link | |
Any other thoughts? Has anyone been able to transcode this movie? |
17th October 2009, 07:10 | #5629 | Link | |
@Mr. Movies
Hi! Is the following information from your earlier post regarding a full disc copy or a movie-only copy?: Quote:
17th October 2009, 08:08 | #5631 | Link |
I got a problem now with retrieving the audio:
[09:00:13] PHASE ONE, Encoding - [09:00:13] Extracting A/V streams [VID_00505] - Error in attempt to extract audio/subs. - Can't create output file C:\USERS\USER1\APPDATA\LOCAL\BD REBUILDER\WORKFILES\00505+00506+00509+00511+00512+00514+00515+00517+00518+00520+00521+00523+00524+00526+00527+05032+00530+00532+00533+00535+00536+00538+00539+00542+00545+05033+00548+00550+00551+00553+00554+00556+00557+00559.track_4352.dts [09:00:15] - Failed to retrieve audio, aborted Could the problem be the path length? |
17th October 2009, 08:49 | #5632 | Link |
There must be someting in my configuration goofed up if you all are able to run with out errors so I'll have to go back and look closer at my codecs and so on. Thanks for the feed back it really helps to know it should be working.
@Sharc If your running Vista or 7 that could cause you problems I personally wouldn't output to my user/application data folders that's really for programs to use for user settings and is considered Windows system files area so it is protected somewhat. Make a temp folder in your root directory and output there not in APPDATA, USERS, WINDOWS, DOCUMENTS AND SETTINGS, or PROGRAMDATA subfolders. @setarip_old The settings shown previously are for a full backup which is my prefered mode as I do like to have some of the special features in my backups that way I can archive my retail disc keeping it safe. But I have tried it both ways as stated in my secound post just didn't see a need to re-post all the same info with just that little change since the out come was exactly the same. |
17th October 2009, 11:49 | #5633 | Link | |
Strange, I have always been using the APPDATA/LOCAL folder in Vista and never had an issue. Looks like the problem popped up with the recent updates of Vista; I am not sure though. |
17th October 2009, 14:07 | #5634 | Link | |
@Mr. Movies
I say this because IMDB and multiple other sites indicate the movie-only running time to be 1:47 - which would leave only 11 minutes regarding extras and others. Can anyone verify the "approximate total content" indicated for their successful full disc rip of "Wolverine"? |
17th October 2009, 18:55 | #5636 | Link | |
Here my value for the full disc: - Approximate total content: [03:39:26.936] This looks different, doesn't it? |
17th October 2009, 20:40 | #5637 | Link |
In light of all the effort by "jdobbs" (and Doom9 members aiding in beta testing) to track down and correct true bugs related to commercial BluRays, I hope another Gladiator-like "situation" hasn't arisen to waste "jdobbs" time...
17th October 2009, 21:23 | #5639 | Link |
There was an invalid character in a file on the Gladiator BD that was on the newsgroups, caused a problem for some people trying to re-encode it with BD-Rebuilder... It was an illegal download situation and not a real bug.
17th October 2009, 22:26 | #5640 | Link | |
config
The audio sync issue is noted exactly the same on both devices |
