Old 24th June 2018, 06:19   #15881  |  Link
burt123
burt123's Avatar
Originally Posted by mparade View Post
mparade asked :- Is it possible to keep more than 2 audio streams from the source?
I just have to say something here :-
At this stage, Ripbot can only process up to 2 audio tracks...I have asked a couple of times if this can be increased to 3 (more would be even better), but as yet, no change
burt123 is offline   Reply With Quote
Old 26th June 2018, 16:43   #15882  |  Link
byteshare
ByteShare
byteshare's Avatar
I tend to enjoy keeping the mkv title info from tacks so I manually remux subs and audio and/or use an outside tool to mux the audio back in after re-encoding it if more than 1 track (keep mkv title info).
Old 27th June 2018, 11:19   #15883  |  Link
burt123
burt123's Avatar
Originally Posted by byteshare View Post
I tend to enjoy keeping the mkv title info from tracks so I manually remux subs and audio and/or use an outside tool to mux the audio back in after re-encoding it if more than 1 track (keep mkv title info).
So does that mean you re-encode video only with Ripbot ??
So what might this "outside tool" be ??
One good thing about Handbrake is, you can add & change as many audio tracks as you like / need.
Old 29th June 2018, 11:44   #15884  |  Link
burt123
burt123's Avatar
Hey guy's, just got the latest auto update, and Atak has performed his magic again...."we" now have up to 3 audio tracks
Thankyou, Atak !!
Old 30th June 2018, 11:25   #15885  |  Link
burt123
burt123's Avatar
Hi Atak,
I just thought I'd report back on my use of Windows 7 SP1, over the last few months.
I haven't noticed any noticeable "improvement's" in the operation of Ripbot, since trying W7, as compared to my other pc's which are running Windows Server 2016.
I am still getting those annoying DE "chunk" / server stall's, which sometimes respond to stopping the particular Server IP, and letting another one take it's place, but sometimes I can't turn the offending server off, which leads me to my next comment...
The "Abort" command still doesn't work too well, rarely it will abort, but most times it just "says" it's aborting, but carry's on encoding, so the only option is the "kill it" with Task Manager, and even sometimes that doesn't completely stop everything, and a reboot is needed.
I'm not sure what the difference was between the newer "Abort" command, and the one you had in the DE window, that seemed to work every time.
That's about all I have to comment on....
Windows 7 has it's Pro's & con's, and so does Windows Server, but I'm not a fan of Windows 10 "1803".
Old 1st July 2018, 18:44   #15886  |  Link
pacaveli420
RipBot uses the medium present unless defined as something else:
http://x265.readthedocs.io/en/default/presets.html
Have you seen this thread: https://forum.doom9.org/showthread.php?t=174491
Has examples that are supposed to work.
Yes - I read through a bunch of threads and documentation on the options. However, there's a lot of options, information, and I'm not sure of all the defaults on RipBot. Does anyone notice anything missing? Anyone using a working profile?
pacaveli420 is offline   Reply With Quote
Old 4th July 2018, 13:09   #15887  |  Link
burt123
burt123's Avatar
Hi Atak,
Another update....
Can I ask a BIG favour....it's was way back on the 13th of April, since you updated to version 1.23.00, but 1.22 is still on Mediafire, can you PLEASE post 1.23 on Mediafire, or even better, the very latest build.....
Cheers
Old 4th July 2018, 20:07   #15888  |  Link
Jake802
Why would some of the videos I am converting come out with Audio but No Video, all I get is a Green Picture that plays with the audio. Thanks!
Jake802 is offline   Reply With Quote
Old 5th July 2018, 16:00   #15889  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Probably some GPU driver issues. Very common after some random update in win10.
Old 8th July 2018, 22:04   #15890  |  Link
NeFReT
Hello friends ripbot264 distributed coding Can we encode another computer on the internet? There is also a problem with windows 7 32 bit AviSynth + x64
NeFReT is offline   Reply With Quote
Old 10th July 2018, 22:59   #15891  |  Link
Ryushin
Ryushin's Avatar
How do I access old jobs before the update to three audio streams. At first it shows an error about not finding audiolist3.txt file so I copy audiolist2.txt to audiolist3.txt. The next error is shows is:
" is not a valid integer value.
So I'm not sure what I need to change in the older jobs.
I also seem to have uncovered a bug with 4k discs and seamless branching. If I rip the disc using anydvd and let Ripbot264 combine the m2ts files, I will get audio that is out of sync towards the end of the film. If I rip the disc using MakeMKV and make a mkv file and then use RipBot264 to process the mkv, the audio comes out fine. Problems occurred with King Kong, Independence Day, and Gladiator.
Ryushin is offline   Reply With Quote
Old 11th July 2018, 01:21   #15892  |  Link
burt123
burt123's Avatar
Yeah, of course I had the same problem, and tried what you did, same result.
If you haven't got a lot of job's queued, might be best just to reload.
Or, try "edit" the "old" jobs, and just pull in the source, again.
Fortunately, I only had about 2 jobs queued up.
But on another pc, I had a LOT in the queue, that pc hasn't been updated yet.
Old 11th July 2018, 11:56   #15893  |  Link
byteshare
ByteShare
byteshare's Avatar
KNLMeansCL.DLL Not Found
Any ideas why'd I'd get this error:
Cannot load file 'C:/RipBot264/Tools/AviSynth plugins/KNLMeansCL/KNLMeansCL.dll'. Platform returned code 126: The specified module could not be found.
This is using the preview tool. Preview works fine if I turn off KNLMeansCL or use MDegrain2 instead.
Using ....Windows 10 64bit
I get the same error code (126) when trying to load MedianBlur2.dll as well. Not sure if related.
Old 11th July 2018, 13:03   #15894  |  Link
Ryushin
Ryushin's Avatar
Yea, I have about 90 jobs on that machine. I don't mind running a shell script to fix the jobs, but I do not know what it is complaining about. Perhaps Atak can make an update to allow editing of the older jobs.
Old 11th July 2018, 13:55   #15895  |  Link
Atak_Snajpera
I will release an auto-update shortly to address this issue.
Old 11th July 2018, 20:52   #15896  |  Link
byteshare
ByteShare
byteshare's Avatar
Since today's RipBot update still getting:
Only on one computer with same version of RipBot and Windows but different hardware...guessing it is specific to this one machine.
It used to work before a format, not sure what would have changed.
I might try another format
Old 11th July 2018, 21:14   #15897  |  Link
Danette
So, batch scripting seems to want to be available, but is not. With v1.22.0, I have batch files loaded and want to add an AVS file that will apply to all files. There is a drop-down option entitled "CUSTOM SCRIPT" that has two options:
1) "Do not use custom script"
2) "ConvertToInterlaced.avs"
On older versions, there was an option to load custom AVS files. In 1.22, there is no such option and the drop-down is useless as it simply limits you to no custom script. Am I missing something here or is it now impossible to add custom scripting to batch processing?
Danette is offline   Reply With Quote
Old 11th July 2018, 21:19   #15898  |  Link
byteshare
ByteShare
byteshare's Avatar
You need to add the scripts to the custom folder in the:
..\RipBot\Tools\AviSynth plugins\Scripts\Custom
Once you add them, they'll show up as an option.
Old 11th July 2018, 22:02   #15899  |  Link
GZZ
Having an issue where the CombineAllChuncks.cmd contains an invalid filename for vjoin.exe. From File: "E:\RipBot264v1.22.0\Tools\vjoin\vjoin_.exe"
The "_" should be removed.
GZZ is offline   Reply With Quote
Old 11th July 2018, 22:23   #15900  |  Link
Danette
Thanks, but all I get is an error message when attempting to process. Could it be the script I'm using (which works with Virtualdub and MeGUI)? The script file I use is:
Import("C:\Program Files (x86)\AviSynth 2.5\plugins\QTGMC-3.32.avsi")
AssumeTFF()
QTGMC(Preset="Very Slow")
LimitedSharpenFaster()
