Old 31st December 2008, 18:44   #61  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
multiAVCHD button will generate folder structure and file names compatible with:
* Memory Stick
* SD/MMC
* USB
multiBD button will generate content, suitable for optical media:
* BD
* DVD
AVCHD output does not require most of the folders, but it works fine with them, so I left them being created.
Old 31st December 2008, 18:51   #62  |  Link
asherungar
how do i add more than 1 .srt file to the same mkv?
asherungar is offline   Reply With Quote
Old 31st December 2008, 18:54   #63  |  Link
deank
deank's Avatar
For now, there is no way. I'll add this in next releases.
Old 31st December 2008, 19:05   #64  |  Link
idbirch2
Mr
Originally Posted by deank View Post
Look at the log. Can you see some lines reading:
New offset for m2ts#X -> X
Can you PM me the log of this unsuccessful procedure? I did a lot of tests and it never happened.
Yes, I see those lines. I've PM'd you the full contents of the log. I didn't have the original log so I created the whole project again, the problem was exactly the same though.
idbirch2 is offline   Reply With Quote
Old 31st December 2008, 19:25   #65  |  Link
asherungar
i dont get a menu
using a PS3 and a Western Digital 1TB.
i can play the MTS files seperatly if i choose in the PS3 "Display All", but no menu, just a black screen,
also, the movie is 1280x720 but my TV shows that its playing at 1080p.
Old 31st December 2008, 19:31   #66  |  Link
deank
deank's Avatar
If it shows playing but no video is shown, than it is MKV incompatible format. PS3 is pickable and MKVs should conform high@4.1 profile.
It is not multiAVCHD malfunction. Did you manage to play anything else generated with mutiavchd?
Old 31st December 2008, 19:47   #67  |  Link
asherungar
i think you didnt understand. the menu doesnt show up.
i click on the AVCHD folder from the PS3, and nothing happens, no "play" is shown (the white arrow..).
i can although pick a specific MTS file if i choose "Display all" which lets me see the whole file structure.
thanks
Old 31st December 2008, 19:57   #68  |  Link
deank
deank's Avatar
redownload the whole package from http@1 link in 1st post.
Old 31st December 2008, 20:06   #69  |  Link
asherungar
has to be link 1? rapidshare is really slow by me..
sorry for the nag
Old 31st December 2008, 21:16   #70  |  Link
asherungar
i couldnt play anything with multiavchd, meaning no menu is shown,
even movies that work using avchd_me.
and also it puts the 3 mts files of the menu as the last files in team folder, is that ok?
thanks
Old 31st December 2008, 21:18   #71  |  Link
Krawhitham
thanks
Does it work on NTSC systems?
The menu files are 25 FPS
Krawhitham is offline   Reply With Quote
Old 31st December 2008, 21:22   #72  |  Link
asherungar
im preety sure it supports NTSC
Old 31st December 2008, 21:27   #73  |  Link
Krawhitham
All I'm going by is this, I found it on another site in a Menu making tutorial
Important Note: To improve compatibility for everyone, please create NTSC menus. Menus with 25fps will not play on North American PS3 and will hang. Please ensure that your menus are all NTSC.
Old 31st December 2008, 21:33   #74  |  Link
asherungar
and is multiavchd menus NTSC? i have a north american PS3...
can i just change the frame rate to 23.976?
Old 31st December 2008, 21:47   #75  |  Link
deank
deank's Avatar
I'm not sure how non-european PS3s handle multiAVCHD output. My PS3 plays menus @1920x1080i/25hz(fps).
I have no means to test other platforms, but other users report multiAVCHD usage to be compatible with their SAPs so, that's a stand for me.
I'm 80mins away from new year celebration, so I'll be away for some hours now.
Something I'd ask you is to delete all your posts, that have been answered to, or the ones irrelevant to multiAVCHD developement.
Thank you, and have a nice 2009!
Dean Kasabow
Old 31st December 2008, 21:49   #76  |  Link
asherungar
wait, is there a way you can try to create NTSC menus?
Old 31st December 2008, 22:39   #77  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
AVCHD standard supports framerates up to 59.94 fps (for 1080p up to 29.97fps) so you don't have to change anything. My PS3 (euro) plays 23.976 and 29.97 fps without problems so I see no reason why your version would not play 25 fps!
Old 1st January 2009, 00:48   #78  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
AVCHD standard supports framerates up to 59.94 fps (for 1080p up to 29.97fps) so you don't have to change anything....
And with a profile not exceeding high@L4.0
SeeMoreDigital is online now   Reply With Quote
Old 1st January 2009, 01:30   #79  |  Link
asherungar
but i did everything just as simple as it is... still no menu...anyone with an american PS try it?
thanks!
Old 1st January 2009, 02:23   #80  |  Link
asherungar
again, is it ok that in the end the menu is the last 3 MTS files in the stream directory?
and i get an error message in the end that its unable to delete a file from the temp directory:
then an empty window comes up:
anybody encounter that?
please help...i just bought a new 1TB HD for this...
Thanks!
