Old 7th January 2009, 21:25   #181  |  Link
burro08
burro08's Avatar
Fix my problem dean i chaned the destination back to the defaut drive, it is the same as where the avchd folder are and it worked i have mts files yay lol
burro08 is offline   Reply With Quote
Old 7th January 2009, 22:22   #182  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
I think it should work now. Please check to see if custom chapters are set correctly.
Just update.
Old 7th January 2009, 22:30   #183  |  Link
burro08
burro08's Avatar
it did but i have only a black screen when i play it on the ps3.. any ideas y?
Old 7th January 2009, 23:17   #184  |  Link
deank
deank's Avatar
1st idea is: you hear audio - no video... MKV video is not supported by PS3... either it is level > 4.1 or encoded with unsuported options (x264).
Old 7th January 2009, 23:19   #185  |  Link
burro08
burro08's Avatar
just a black screen no msg or sound
Old 7th January 2009, 23:36   #186  |  Link
turbojet
Custom chapters seems to work well now, at least from checking the meta file. But I keep getting AVCHD/BD that are very small <100 KB. Sometimes _TEMP has a full AVCHD/BD in there sometimes it doesn't. I've tried to check and uncheck move files, and check and uncheck top menu. This happened on 2 different mkvs that used to work, on 2 different boxes, vista 64 and xp 32. Any ideas?
Old 7th January 2009, 23:42   #187  |  Link
Forrest
MediaInfo seem doesn't work.
MultiAVCHD awaits MediaInfo log and not continue (mediainfo "my_video.mkv" --logfile=mediainfo.txt).
No problem with chapters each 5 min.
Forrest is offline   Reply With Quote
Old 7th January 2009, 23:56   #188  |  Link
deank
deank's Avatar
Sorry... it is fixed in build 126
@turbojet:
But I keep getting AVCHD/BD that are very small <100 KB. Sometimes _TEMP has a full AVCHD/BD in there sometimes it doesn't. I've tried to check and uncheck move files...
Try un-checking [x] Delete temp files and see what's inside _TEMP.
Old 8th January 2009, 00:06   #189  |  Link
Forrest
Thanks. Build 126 is ok, and custom chapters are set correctly :-)
Old 8th January 2009, 00:06   #190  |  Link
deank
deank's Avatar
So let's call it a night it is 1am here, so no updates for eight hours
Old 8th January 2009, 01:01   #191  |  Link
~bT~
н∂-αиαтι
something for tomorrow. autodownload has a mind of its own. sometimes works and other time it just sits there.
maybe u can add a button for updates? like the donation button
Old 8th January 2009, 01:02   #192  |  Link
deank
deank's Avatar
Okay
Old 8th January 2009, 01:23   #193  |  Link
~bT~
н∂-αиαтι
if i tick custom chapters and the file doesn't have any, will it auto generate chapters every 5 mins? that would be great if it did. cheers for all the hard work so far. waiting for the day u release custom menus etc.
Old 8th January 2009, 09:45   #194  |  Link
deank
deank's Avatar
That's right. If you hover (o) Keep original chapters you will see a hint... as with most options.
Old 8th January 2009, 11:54   #195  |  Link
deank
deank's Avatar
Okay... quick update - something most of you will enjoy:
[x] Apply standard height to video in tsMuxer tab.
If your input MKV is not AVCHD compliant, multiAVCHD will set new height value in CLPI na MPLS files - value which is next compliant resolution. In other words: if your mkv height is <480 it will be set at 480p, if >480 and <576 will be set to 576, etc.
This should help most SAPs to play non standard resolution videos, and now PLAYSTATION3 will show subtitles with these non standard resolutions.
Still you may have artifacts at the bottom of the screen.
Bugfix: audio and subtitle tracks from one title were unnecessarily added to the next title. It is okay now.
Credits go to a fellow bulgarian for pointing it out to me.
Old 8th January 2009, 13:43   #196  |  Link
deank
deank's Avatar
wtf?
Old 8th January 2009, 13:56   #197  |  Link
odin24
odin24's Avatar
Location: The Great North (the better half of North America)
wtf?
SPAM!!!
About your new resizing option; does this apply to ~528p->720p and ~800p-->1080p? And when you say artifacts, do you mean the huge hideous green bar (for 2.35:1 ratios)?
Keep up the good work.
odin24 is offline   Reply With Quote
Old 8th January 2009, 14:01   #198  |  Link
deank
deank's Avatar
Yes, next compliant resolution. ~528p will become 576p
height<480 = 480p
480<height<576 = 576p
576<height<720p = 720p
720<height<1080 = 1080p
Nothing can be done for the annoying green bar, yet, but this way subtitles are shown and saps play it better.
Later I will rework the way *TS files are imported, because now it seems to have problems with audio out-of-sync or not importing properly at all. Everything is fine with MKV so far.
Old 8th January 2009, 14:45   #199  |  Link
Forrest
why not adjust the resolution according to the width?
if width=1280 -> height=720
if width=1920 -> height=1080
Old 8th January 2009, 14:51   #200  |  Link
deank
deank's Avatar
Can anyone try multiAVCHD under Wine emulator for Linux/MacOS?
Also download links in first post are updated. They point to my site, instead to rapidshare.
Latest PAL/NTSC LITE/FULL versions include everything you need (build 130).
