12th June 2009, 20:31 | #5161 | Link | |
Main problem is I don't have NVidia card. BTW is there any trial version?
12th June 2009, 20:38 | #5162 | Link | |
oh yep i do use yadif and your right, the PSP is hardly going to show up any differences in quality. I do think it speeds things up considerably though as the de interlacing is all done on the GPU and frees up the CPU. When your converting the 2 hour 50fps england game from ITV HD, the extra 10fps makes a difference! although i must confess i have not done full like for like testing in megui hardware vs ripbot software, maybe i should.... |
12th June 2009, 20:42 | #5164 | Link | |
@Balthazar2k4 Copy text as code. Those Attachments must be approved. It can take days.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 12th June 2009 at 20:45. |
12th June 2009, 20:48 | #5167 | Link |
Spline36Resize
12th June 2009, 20:54 | #5168 | Link | |
D:\>"C:\Program Files\RipBot264\tools\bepipe\bepipe.exe" --script "import(^D:\Temp\RipBot264temp\job1\job1.avs^)" | "C:\Program Files\RipBot264\Tools\enc_aacPlus\enc_aacPlus.exe" - "D:\Temp\RipBot264temp\audio.aac" --lc --cbr 98804 *************************************** BePipe by dimzon *************************************** Script used: # BEGIN import("D:\Temp\RipBot264temp\job1\job1.avs") # END Scanning for Audio Stream... Found Audio Stream Channels=2, BitsPerSample=16, SampleRate=48000Hz Writing Header... Writing Data... 0%ERROR: AVIStreamRead returned error. ******************************************************************** * AACPlus v2 Encoder (using Winamp 5.2 enc_aacplus.dll) * Source timestamp Mon May 15 17:24:26 2006 * Build May 15 2006, 17:24:35 ******************************************************************** * NOTE! enc_aacplus.dll must be into executable directory * get it from Winamp 5.2 plugins directory * tested on Winamp 5.2 Release Feb 23 2006 Full (Not Pro) version) ******************************************************************** Input file: - Output file: D:\Temp\RipBot264temp\audio.aac SampleRate: 48000 ChannelCount: 2 BitsPerSample: 16 Bitrate: 98804 ChannelMode: Stereo Encoder: AAC-LC Encoding... Finalizing... Done D:\>"C:\Program Files\RipBot264\tools\avs2yuv\pipebuf.exe" "C:\Program Files\RipBot264\tools\avs2yuv\avs2yuv.exe" "D:\Temp\RipBot264temp\job1\job1.avs" -raw - : "C:\Program Files\RipBot264\tools\x264\x264_x64.exe" --pass 1 --bitrate 933 --stats "D:\Temp\RipBot264temp\job1\job1.stats" --sar 1:1 --level 3.0 --vbv-bufsize 1000 --vbv-maxrate 10000 --no-cabac --filter 0,0 --ref 1 --b-adapt 0 --direct auto --subme 7 --partitions p8x8,b8x8,i4x4,p4x4, --me umh --threads auto --thread-input --progress --no-psnr --no-ssim --fps 23.976 --frames 136512 --partitions none --subme 3 --me dia --output "D:\Temp\RipBot264temp\video.264" - 1280x544 : 4 x264 [info]: 1280x544 @ 23.98 fps x264 [info]: using SAR=1/1 x264 [warning]: frame MB size (80x34) > level limit (1620) x264 [warning]: MB rate (65214) > level limit (40500) x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2 x264 [warning]: VBV buffer size too small, using 1251 kbit x264 [info]: profile Baseline, level 3.0 D:\Temp\RipBot264temp\job1\job1.avs: 1280x544, 5000000/208543 fps, 136512 frames x264 [info]: slice I:1757 Avg QP:27.75 size: 39266 x264 [info]: slice P:134755 Avg QP:31.94 size: 4360 x264 [info]: mb I I16..4: 51.9% 0.0% 48.1% x264 [info]: mb P I16..4: 8.6% 0.0% 0.0% P16..4: 25.4% 0.0% 0.0% 0.0% 0.0% skip:66.0% x264 [info]: final ratefactor: 30.48 x264 [info]: coded y,uvDC,uvAC intra:26.5% 46.2% 17.0% inter:5.2% 6.4% 0.7% x264 [info]: kb/s:922.4 encoded 136512 frames, 266.90 fps, 922.48 kb/s D:\>"C:\Program Files\RipBot264\tools\avs2yuv\pipebuf.exe" "C:\Program Files\RipBot264\tools\avs2yuv\avs2yuv.exe" "D:\Temp\RipBot264temp\job1\job1.avs" -raw - : "C:\Program Files\RipBot264\tools\x264\x264_x64.exe" --pass 2 --bitrate 933 --stats "D:\Temp\RipBot264temp\job1\job1.stats" --sar 1:1 --level 3.0 --vbv-bufsize 1000 --vbv-maxrate 10000 --no-cabac --filter 0,0 --ref 1 --b-adapt 0 --direct auto --subme 7 --partitions p8x8,b8x8,i4x4,p4x4, --me umh --threads auto --thread-input --progress --no-psnr --no-ssim --fps 23.976 --frames 136512 --output "D:\Temp\RipBot264temp\video.264" - 1280x544 : 4 x264 [info]: 1280x544 @ 23.98 fps x264 [info]: using SAR=1/1 x264 [warning]: frame MB size (80x34) > level limit (1620) x264 [warning]: MB rate (65214) > level limit (40500) x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2 x264 [warning]: VBV buffer size too small, using 1251 kbit x264 [warning]: direct=auto not used on the first pass x264 [info]: profile Baseline, level 3.0 D:\Temp\RipBot264temp\job1\job1.avs: 1280x544, 5000000/208543 fps, 136512 frames x264 [info]: slice I:1757 Avg QP:27.68 size: 42801 x264 [info]: slice P:134755 Avg QP:31.72 size: 4369 x264 [info]: mb I I16..4: 35.7% 0.0% 64.3% x264 [info]: mb P I16..4: 3.1% 0.0% 1.6% P16..4: 23.7% 6.1% 1.6% 0.1% 0.1% skip:63.7% x264 [info]: coded y,uvDC,uvAC intra:31.3% 54.7% 23.6% inter:4.4% 8.0% 0.8% x264 [info]: kb/s:932.9 encoded 136512 frames, 145.00 fps, 932.95 kb/s D:\>"C:\Program Files\RipBot264\tools\mp4box\mp4box.exe" -tmp "D:\Temp\RipBot264temp" -ipod -add "D:\Temp\RipBot264temp\video.264" -fps 23.976 -add "D:\Temp\RipBot264temp\audio.aac":lang=eng -mpeg4 -new "D:\Finished\A Bugs Life (HD).mp4" AVC-H264 import - frame size 1280 x 544 at 23.976 FPS Import results: 136512 samples - Slices: 1757 I 134755 P 0 B - 1 SEI - 1642 IDR AAC import - sample rate 48000 - MPEG-4 audio - 2 channels Setting up iTunes/iPod file... Forcing AVC/H264 SAR to 1:1... Saving D:\Finished\A Bugs Life (HD).mp4: 0.500 secs Interleaving ------------------------- Elapsed Time: 00h:24m:43s Last edited by Balthazar2k4; 12th June 2009 at 20:57. |
12th June 2009, 20:59 | #5169 | Link |
Will be possible to upload source sample to www.mediafire.com (50MB)
12th June 2009, 21:24 | #5170 | Link | |
12th June 2009, 22:30 | #5171 | Link |
Use DGSplit
12th June 2009, 23:30 | #5173 | Link |
just did a quick test in megui, one using hardware deinterlacing and one using yadif. both used exactly the same script and settings, apart from deinterlacing method. a 10 min clip of the tennis. software was 34.88 FPS and hardware was 55.49 FPS...
will do ripbot specific tests and see if its that great as well, in theory should be |
13th June 2009, 10:19 | #5175 | Link |
Atak,
Noticed a new Bug with v1.14.1, Sunshine BR UK would reach the end of the extraction process and delete the video.mkv, v1.13.3 completes fine. Most likely related to the latest version of eac3to included, just FYI really Thanks again for the awsome GUI By the way for other Win7 users info this tool replaces the need to manually edit the registry to fix the VC1 FFDSHOW issue (I know you are already aware of this Atak) http://www.hack7mc.com/2009/06/prefe...windows-7.html
Q6600 @ 3.2Ghz -Asus P5Q-Pro 4Gb DD2, GTX260 core 216 Win 7 64bit Home Premium |
13th June 2009, 16:03 | #5176 | Link |
Runtime Error!
this is my first post as up to the last few days i have used your software w/o a problem since it was first developed. so thank you for taking your time to develop such an outstanding and stable piece of software. easy to use and VERY useful.
about a week ago, out of the blue, i began receiving the following error. tried reverting back to an older version of your software and even updated to v1.14.1 and it still occurs. i googled the error, and searched this thread but could not find any answer. any assistance you can provide would be appreciated. luger9mm |
13th June 2009, 17:28 | #5177 | Link |
Hi Atak,
I have an trouble with version 1.14.1, 1.13.3 and 1.13.1. I have installed right now ffdshow clsid 2992, avisynth 2.5.8. i convert an mkv HD 1080P, already 23.98, 1980x8xx and audio is out of sync on preview, and same when project is done. when i change "xx copy stream" for 256kbps the max available is the same. The time movie is 2 sec difference between the video and audio. The mkv source is sync. Can you help me with this case please? Thanks for you time! Job1.avs Code:
#MT #VideoSource video=DirectShowSource("D:\--= Complete =--\Fight.Club.BluRay.x264\fightclub-1080p.mkv",audio=false).ConvertToYV12() #Deinterlace #Decimate #Crop #Resize video=Spline36Resize(video,1920,800).Sharpen(0.2).AddBorders(0,140,0,140) #Colors #Denoise #Subtitles #AudioSource LoadPlugin("C:\Program Files\Ripbot264\tools\AviSynth plugins\NicAudio\NicAudio.dll") audio=NicAC3Source("H:\temp\RipBot264temp\job1\audio.1.ac3") audio=ResampleAudio(audio,48000) #DownMix #Delay audio=DelayAudio(audio,0) #Tempo #Normalize #AudioDub audio=ConvertAudioTo16bit(audio) AudioDub(video,audio) #Triming #AVSameLength Trim(0,200167) #ColorSpace Code:
DirectShowSource("D:\--= Complete =--\Fight.Club.BluRay.x264\fightclub-1080p.mkv",audio=false).ConvertToYV12() ConvertToRGB32.ImageWriter("H:\temp\RipBot264temp\job1\", 72830, 72830, "bmp").Trim(72830,-1) |
13th June 2009, 20:48 | #5178 | Link | |||||
At the moment I can suggest this: 1) Install ffdshow 2975 and enable ffmpeg-mt (multithreaded decoder) decoder for h.264 2) Check audio sync in preview without modifing anything (Resize OFF!) 3) if delay is constant adjust manually audio delay in gui (last page) Quote:
I cannot see your screenshot so I can only suggest to reinstall AviSynth , FFDshow 2975 (recommended) and Haali Media Splitter.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 13th June 2009 at 20:54. |
13th June 2009, 21:27 | #5179 | Link |
i think i know why 8ternity's audio is out of sync and the same is happening to me, when i render out a 23.98 movie and tell ripbot to not change the framerate, it is still converting to 29.97, hence to movie is playing too fast and the audio gets further and further out of sync..
also another question, what are the requirements for "xxCopy Stream" to appear? I've noticed it doesnt always show up since moving to 1.14.1. |
13th June 2009, 21:31 | #5180 | Link | ||
without AviSynth MT i had 33.42 fps , with MT i got 46.75 fps
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 13th June 2009 at 22:16. |
