26th September 2008, 15:45 | #424 | Link |
I've a problem.
DGAVCDecNVindex run correctly, and I can save the projet. But I can load the avs file in MEGUI (the soft close immediatly) and when i want to test directly with X264 command line I see teh error message : "RAWYUV imput requires a resolution" ??. If you have any suggestion for a solution ? THX. |
26th September 2008, 15:55 | #425 | Link | |
aka XaS
Post your script though, there's probably something missing in it.
Q9300 OC @ 3.2ghz / Asus P5E3 / 4GB PC10600 / Geforce 8600 GTS |
26th September 2008, 16:50 | #427 | Link | |
I did ask for a step-by-step. I just don't have time to do experiments to figure things out. EDIT: OK, I have remote desktop working. Now, what do I do exactly? Do I connect and start the encode and then disconnect? Do I start it locally and then connect from remote? You gotta tell me what to do. EDIT 2: I remote connected and tried to start DGAVCIndexNV. I get a CUDA init failure 100. I have written to Nvidia about it. Probably something related to the DX/D3D init. Last edited by Guest; 26th September 2008 at 17:22. |
26th September 2008, 17:30 | #428 | Link | |
Nvidia responds as follows:
26th September 2008, 18:32 | #429 | Link |
Bummer. VNC is ok software, I like that its open and free. But it really reduces my ability to work as I mentioned before with sluggish performance and random dropouts.
Thanks for checking with nvidia. I'll go see if radmin can work around this. |
26th September 2008, 20:02 | #430 | Link |
mp4 specs are freely available:
http://standards.iso.org/ittf/Public...12_2005(E).zip
26th September 2008, 22:46 | #436 | Link |
@rebkell
What do you mean by "have one in history"? Can you please give us a step-by-step? Thanks! @all I just installed the Nvidia driver 178.13 which came out within the last few days and my High Profile, Level 5.1 streams now decode properly. The problem with non-detection of the CUDA device requiring a reboot is also believed to be fixed by this driver version. |
26th September 2008, 23:01 | #437 | Link | |
After it's through, go to the Log tab and expand the Job(s) one of the lines will be very long and it's the x264 encode line, just right click it and Edit Text->Node and it will open the command line for the first pass in notepad. It will contain the exact command used by x264 for the encode. Do the same for the second pass to get the final pass command line. |
26th September 2008, 23:28 | #439 | Link | |
"C:\Program Files\megui\tools\x264\x264.910.modified.exe" --pass 1 --bitrate 3400 --stats "G:\Junk\Bones\Bones0405.stats" --level 4.1 --keyint 60 --min-keyint 1 --bframes 3 --direct auto --subme 1 --analyse none --ipratio 1.1 --pbratio 1.1 --vbv-bufsize 9000 --vbv-maxrate 24000 --qcomp 0.5 --me dia --merange 12 --threads auto --thread-input --progress --no-psnr --no-ssim --output NUL "G:\Junk\Bones\Bones0405.avs" "C:\Program Files\megui\tools\x264\x264.910.modified.exe" --pass 2 --bitrate 3400 --stats "G:\Junk\Bones\Bones0405.stats" --level 4.1 --keyint 60 --min-keyint 1 --ref 3 --mixed-refs --bframes 3 --b-rdo --bime --weightb --direct auto --subme 6 --analyse p8x8,b8x8,i4x4,i8x8 --8x8dct --ipratio 1.1 --pbratio 1.1 --vbv-bufsize 9000 --vbv-maxrate 24000 --qcomp 0.5 --me umh --merange 12 --threads auto --thread-input --progress --no-psnr --no-ssim --output "G:\Junk\Bones\Bones0405.mkv" "G:\Junk\Bones\Bones0405.avs" |
27th September 2008, 17:44 | #440 | Link |
I don't know if I'm the only one experiencing this, but if I have a script that looks like this:
AVCSource("1.dga", deinterlace=true) ++ AVCSource("2.dga", deinterlace=true) Then when virtualdubmod gets to the second AVCSource, it crashes with some error that says it can't be "read." If I run them seperately, then both of them work fine. Also, once an AVS is loaded into vdubmod, and then if one closes that file, and tries to load another one (without physically closing the program), vdubmod crashes again based on the same type of message. Something is getting hung up is my guess? |
