2nd November 2018, 14:19 | #1181 | Link |
New uploads: (MSYS2; MinGW32: GCC 7.3.0 / MinGW64: GCC 8.2.0)
AOM v1.0.0-864-g351711076 now with TPL model (RDO modulation based on frame temporal dependency) and block based denoiser rav1e 0.1.0 (7492fc5 / 2018-11-01) dav1d 0.0.1 (287ba91 / 2018-11-02) |
2nd November 2018, 18:10 | #1182 | Link |
16x FTW
Report from a 1 day meeting on future codecs, h264 through VVC.
http://www.streamingmedia.com/Articl...P9-128213.aspx The most interesting quote is from a Youtube encoding engineer that AV1 encoding time is down to 16x slower vs. VP9, so that's a nice performance trend (no doubt giving up some % of quality). What's important (as benwaggoner always says) is what quality@perf tradeoffs are available. |
2nd November 2018, 20:39 | #1183 | Link | |
Flip side is no one expects spectacular quality from YouTube. It’s free. So even though video game captures always look terrible (lots of high frequency sharp edges...), that’s what people are used to and so they don’t really think about it any more. So YouTube can experiment a lot at how to make good-enough quality fast, which is a different direction from a lot of other folks, and a very useful one in encoder development. It can be a good starting point for live encoders, although a YouTube can handle some content taking 3x longer to encode than other content due to complexity. HEVC and AV1 have great tools for making text and video game footage a LOT better. But they are also pretty expensive to add to normal mode detection, so lot of heuristics to figure out when to use them are important. |
2nd November 2018, 22:26 | #1184 | Link |
Live encoding
I'm all for AV1 encoders getting faster, but of course on an absolute scale it's pretty slow still, spending a lot of CPU for all that efficiency.
I always figured live-encoding would be quite a wait, although the official framing of AV! always mentions that live-stream/chat was an important case they had thought about. So anyway I find a talk by Nathan Egge of Mozilla Most of the slides look familiar but there's a claim about live encoding I had not seen before. https://people.xiph.org/~negge/AVIF2018.pdf page 55: rav1e Live Encoding Shown at IBC in Sept 2018 ● 640x480 @ 30 fps ● Single tile / thread ● Simplified feature set I guess one sign of AV1 progress will be when someone posts a link here to an AV1 webcam. |
3rd November 2018, 11:01 | #1185 | Link |
I am maddo saientisto!
32/64bits binaries (GCC 8.2):
av1-1.0.0-877-ge5761e020: https://mega.nz/#!1sgl3QrB!x6F6SfLzz...vWZ-IMSzZukIWs A long standing multithreading bug has been fixed tonight, so here's a new build Cc @utack |
3rd November 2018, 16:11 | #1186 | Link |
I still don’t see aomenc.exe using more than one thread.
MPC-BE 1.6.11 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
3rd November 2018, 18:24 | #1189 | Link |
I'm cross compiling from a linux VM. Made it easier to switch between compiler versions back when I was investigating the optimization related bug, then the bug was worked around and the environment stuck.
Silver lining, I'm not stuck with an outdated compiler and I don't have to manage my own MSYS2 package. |
3rd November 2018, 18:57 | #1191 | Link |
What does your command line look like? So far I've been unable to make row-mt work myself
My tries so far: this one generates invalid bitstream: ../../bin8/aomenc --frame-parallel=0 --tile-columns=2 --tile-rows=2 --row-mt=1 --threads=4 --auto-alt-ref=1 --cpu-used=4 --tune=psnr --passes=2 --end-usage=q --cq-level=40 --test-decode=fatal -o test.av1.cq40.webm orig.i420.y4m Pass 1/2 frame 480/481 92352B 1539b/f 36899b/s 17849 ms (26.89 fps) Pass 2/2 frame 19/0 0B 17871 ms 1.06 fps [ETA unknown] 2423FFailed to decode frame 2 in stream 0: Corrupt frame detected Failed to decode tile data This one works but uses only 12-13% (one core) of my 4c/8t CPU: ../../bin8/aomenc --frame-parallel=0 --tile-columns=2 --tile-rows=2 --row-mt=1 --auto-alt-ref=1 --cpu-used=4 --tune=psnr --passes=2 --end-usage=q --cq-level=40 --test-decode=fatal -o test.av1.cq40.webm orig.i420.y4m Pass 1/2 frame 480/481 92352B 1539b/f 36899b/s 18130 ms (26.47 fps) Pass 2/2 frame 16/0 0B 18152 ms 52.88 fpm [ETA unknown] Last edited by SmilingWolf; 3rd November 2018 at 19:06. |
3rd November 2018, 19:30 | #1192 | Link | |
aomenc --codec=av1 --cq-level=20 --threads=4 Added: I do not understand what are the columns and rows in this context. If a codec divides a frame into identical independent cells, it is unclear how it can effectively compress in a multi-thread mode.
MPC-BE 1.6.11 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource Last edited by v0lt; 3rd November 2018 at 19:38. |
3rd November 2018, 22:20 | #1193 | Link |
Tile columns (click to enlarge):
The frame is divided in N (10 in my case) columns of equal width. Each column in indipendent, so every thread can indipendently work on a tile. Using tile columns (and/or rows) makes decoding faster too, because each tile can be decoded by a separate thread, making playback way smoother You command line doesn't show any multithreading because you only have a single big tile, which is being worked on by thread 0, leaving threads 1,2,3 with nothing to do. Last edited by SmilingWolf; 3rd November 2018 at 22:28. |
4th November 2018, 06:54 | #1194 | Link |
@SmilingWolf
In this case, the video stream received in the multi-thread mode can be worse than the one-thread mode (with the same bitrate of course). Because motion prediction algorithms will not be able to work effectively. Added: I also noticed that some files are decoded by 2 threads, while others are always in single-threaded mode. This is strange, because It is not clear how this will affect hardware decoding.
MPC-BE 1.6.11 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource Last edited by v0lt; 4th November 2018 at 07:24. |
4th November 2018, 11:04 | #1195 | Link | |
I'll be running a couple of simple test encodes and decodes and report back some numbers. Do you have any samples? Files coming from YouTube perhaps? I'd like to inspect them. I know at least some of the first videos they put online in the AV1 test playlist used a single tile column, which forced single threaded decoding in anything using libaom (e.g. Firefox, Chrome, FFMpeg) |
4th November 2018, 12:13 | #1196 | Link |
@SmilingWolf
As far as I remember, streams obtained using rav1e v1.0.116 were decoded in single-threaded mode. But samples from elecard.com loaded at least 2 cores. Now it is difficult for me to recheck it, because the decoder in the player works faster than before.
4th November 2018, 12:20 | #1197 | Link |
Alright, rav1e doesn't support tiles yet, so every frame is a single big column
I'll inspect the Elecard samples ASAP. Meanwhile my encodes are finishing up, so I'll post size, quality and decoding time differences when they're done Last edited by SmilingWolf; 4th November 2018 at 12:25. |
4th November 2018, 18:23 | #1198 | Link |
The clip used is the F.Y.C one I described some pages ago
aomenc/aomdec: 1.0.0-877-ge5761e020 dav1d: 0.0.1 e0c3186 Quality and sizes: Code:
Sizes: test.av1.cq20.tc0.ivf: 5956739 test.av1.cq20.tc2.ivf: 6001827 +0.75% test.av1.cq20.tc6.ivf: 6091937 +2.22% PSNR-HVS-M: test.av1.cq20.tc0.ivf: 43.192 test.av1.cq20.tc2.ivf: 43.1736 -0.04% test.av1.cq20.tc6.ivf: 43.1489 -0.10% MS-SSIM: test.av1.cq20.tc0.ivf: 26.5095 test.av1.cq20.tc2.ivf: 26.4895 -0.07% test.av1.cq20.tc6.ivf: 26.467 -0.15% Code:
# aomdec --threads=8 --progress -o /dev/null test.av1.cq20.tc0.ivf 480 decoded frames in 4660361 us (103.00 fps) # aomdec --threads=8 --progress -o /dev/null test.av1.cq20.tc2.ivf 480 decoded frames in 3365067 us (142.64 fps) +27,79% # aomdec --threads=8 --progress -o /dev/null test.av1.cq20.tc6.ivf 480 decoded frames in 3267103 us (146.92 fps) +29,89% # time dav1d -i test.av1.cq20.tc0.ivf -o /dev/null --muxer yuv4mpeg2 -q --framethreads 8 --tilethreads 4 480 decoded frames in 1997 ms (240,36 fps) # time dav1d -i test.av1.cq20.tc2.ivf -o /dev/null --muxer yuv4mpeg2 -q --framethreads 8 --tilethreads 4 480 decoded frames in 1747 ms (274,75 fps) +12,51% # time dav1d -i test.av1.cq20.tc6.ivf -o /dev/null --muxer yuv4mpeg2 -q --framethreads 8 --tilethreads 4 480 decoded frames in 1763 ms (272,26 fps) +11,71% TC 2 generates 4 columns TC 6 generates 10 columns I write they "generate" N columns because there's an upper limit to how many columns fit in a given horizontal resolution, TC 6 implies an actual max of 2^6=64 columns and I use it as a catch all to generate as many columns as possible for my clips. So the take aways from all this:
Also, RE: Elecard clips: they use tile columns (5 for the 720p clips, 10 for the HD clips), so that's why the player used more than one core on those |
6th November 2018, 19:15 | #1199 | Link | |
Member
from 16fps with libaom to 77fps with Dav1d |
9th November 2018, 19:02 | #1200 | Link | |
