Old 15th October 2018, 12:57   #53241  |  Link
nevcairiel
Originally Posted by Manni View Post
EDIT: also I forgot we needed D3D11 to get 10bits without FSE, that's probably why I'm using it
This only requires madVR in D3D11 presentation mode, it has nothing to do with how the decoder operates.
There is only a few things that the decoder mode influences:
- CPU-only madVR algorithms (black bar detection, and maybe others?), does not work with DXVA2 Native or D3D11 Native
- Deinterlacing, doesn't work with D3D11 Native only.
Everything works with Software decoding or DXVA2/D3D11 Copy-Back (because copy-back looks like software decoding to a renderer). And between those last two, DXVA2 Copy-Back is usually preferable because its more efficient, unless you need D3D11 to access a headless GPU.
Old 15th October 2018, 12:57   #53242  |  Link
mytbyte
Originally Posted by mclingo View Post
you'll get a crushed desktop in this config though so web and youtube and other stuff will be crushed too wont it?
Correct, anything that outputs full range is crushed, just confirmed on my LG HDMI monitor.
mytbyte is offline   Reply With Quote
Old 15th October 2018, 13:00   #53243  |  Link
mclingo
I see, I'm a one stop shopper myself, minimal setup, I dont like having to change TV preset based on content. I will test it for myself though.
cheers
Please move this discussion to here from herein, its blocking MADVR issues.
https://forum.doom9.org/showthread.php?t=175769
LG OLED EF950-YAM RX-V685-RYZEN 3600 - 16GBRAM - WIN10 RX 5700 - https://www.videohelp.com/software/madVR/old-versions
Old 15th October 2018, 13:01   #53244  |  Link
iSeries
Well that's your choice, but I'm not going to settle for crushed near-black just because I don't want to press a button on the remote ;-) Like I said, I only use it as a HTPC (Kodi DSplayer also), so I never even really see the desktop. Kodi DSplayer is set to 16-235, as is MadVR, GPU to 0-255, TV to 16-235. All levels are correct, no near-black crush.
LGs simply do better when working limited range.
iSeries is offline   Reply With Quote
Old 15th October 2018, 13:03   #53245  |  Link
or you use 1-255.
Old 15th October 2018, 13:08   #53246  |  Link
iSeries
Yes, that's also an option. As is raising the TV brightness one notch. But both those options raises everything, whereas the only difference between limited>full>limited and full>full>full is that first near-black shade which is crushed with the latter. All other shades above that are at equal brightness (measured with meter).
No idea if that would be detrimental to the TVs HDR tonemapping as well. For sure, the advice is to not touch any of the default settings on the TV for HDR as it messes up the tonemapping.
Old 15th October 2018, 13:25   #53247  |  Link
j82k
Complete 0-255 chain vs MadVR at 16-235, GPU at 0-255, and TV at low doesn't make a difference on my C8.
Tested in a pitch black room using the linked and other black clipping test pattern.
Also it would have really surprised me if it made a difference regarding near-blacks/black crush.
j82k is offline   Reply With Quote
Old 15th October 2018, 13:34   #53248  |  Link
Manni
Thanks, that clarifies everything. I'll compare DXVA2 CB and D3D11 CB, although I'm often using Teamviewer to control the HTPC without having to switch the PJ on or switch inputs on my 4K monitor, so if that's what you call headless GPU I'll probably need D3D11.
Win11 Pro x64 b23H2
Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33
madVR/LAV/jRiver/MyMovies/CMC
Denon X8500HA>HD Fury VRRoom>TCL 55C805K
Old 15th October 2018, 13:40   #53249  |  Link
no it's not headless. native would fail if you use your whole system headless.
Old 15th October 2018, 13:57   #53250  |  Link
nevcairiel
The primary GPU is always available through DXVA2-CB as well, thanks to D3D9Ex. Just any secondary fully headless GPUs would not be.
Old 15th October 2018, 14:10   #53251  |  Link
Manni
OK thanks. Only one GPU here anyway.
Win11 Pro x64 b23H2
Old 15th October 2018, 14:22   #53252  |  Link
iSeries
Maybe LG changed something in 2018, but I can assure you LG TVs have shown the same thing going back ten years lol. Remember to test, brightness has to be at default 50. The black square one is really the best way to set brightness
Old 15th October 2018, 14:38   #53253  |  Link
mclingo
i'll have a look tonight on my ageing EF950 OLED
Old 15th October 2018, 16:42   #53254  |  Link
SamuriHL
SamuriHL's Avatar
For me I have to set madvr to 16-235, GPU full, and TV low to get the proper levels on my C8. So no, IMO, it has not changed in the 2018 models. Default brightness of 50. I can only claim this to be my experience.
Old 15th October 2018, 17:01   #53255  |  Link
austonrush
Originally Posted by austonrush View Post
Hey Guys, I've got a repeated frames glitch when starting a video file. The audio plays in the background but, the video portion initially freezes. This started after the latest windows 10 and nvidia upgrade, never had it before. It can freeze for up to 10 seconds sometimes. Anyone else seeing this? It is not exclusive to any one video.
https://imgur.com/a/t8eGSZZ on average it repeats about 900 frames before the video kicks in.
I was able to isolate this to a LAV hardware decoder d3d11 issue. It only occurs when the display switches herz before playback ie. 60hz to 23hz etc. If I'm already at 23hz and start the video it works without any presentation glitches. If I switch to DXVA2 copyback everything works as it should. This has only been an issue since I upgraded windows 10 to the latest build.
austonrush is offline   Reply With Quote
Old 15th October 2018, 18:09   #53256  |  Link
Warner306
Originally Posted by mytbyte View Post
I'm not technical enough to understand the BT.2390 paper in full, and can't quite grasp how the rolloff algorithm works (for 200 cd/m2 max brightness on a comp monitor, the 70% I measured as being way too high, 80-100 are flat i.e clipped in the graph (probably depends on MaxL of content and mastering monitor etc). But, everything under 50% (95 nits) is more-less following the PQ curve at all times so there should be no major black crush from MadVR's tone map curve (note: I'm doing HDR->SDR)
Something is lost in translation when going from HDR -> SDR.
If the target nits is higher than the display's actual brightness, you are only getting a ratio of the original curve.
Example: 480 target nits shown at 200 actual nits
480 nits is the lowest value of BT.2390 where the soft knee (where compression begins) is above reference white (100 nits). Lower values will place the soft knee lower and lower and compress at least some of the first 100 nits. The lower the target nits, the more reference white is compressed.
Approximate display brightness for reference white for 480 target nits at 200 actual nits:
4.8 ratio of target nits/reference white — 480/100 = 4.8 — at 200 actual display nits — puts an untouched diffuse white at close to 42 nits — 200/4.8 = 42 nits
In current test builds, if the content is below 480 nits, clipping is selected for as long as possible. This helps improve the brightness of content that is above the soft knee up to the set target nits, and even above the target nits, by eliminating the compression curve and reducing it as much as possible up to the peak brightness of the source.
Approximate brightness of 470 nits actual scene peak at 200 display nits with clipping enabled:
2.4 ratio of target nits/display nits — 480/200 = 2.4 — at 200 actual display nits — puts 470 nits at close to 196 nits — 470/2.4 = 196 nits
Clipping is always predictable because it is the ratio of the target nits/display nits. BT.2390 is only predictable up to the soft knee. After the soft knee, the entire range is compressed and will change depending on the brightness of the scene.
You would actually lose less brightness by outputting in PQ (HDR Output) to an HDR display because the target nits and display nits should match.
The gamma curve mismatch means this scale is not exact, but it is a general guide to actual brightness output.
Old 15th October 2018, 18:48   #53257  |  Link
VoodooNBGD
Hi all,
Does someone know if chroma upscaling in madVR works in one or two steps, when presentation resolution is larger than luma plane resolution?
For example, I have a H264 video in 1280x720 pixels (4:2:0 color with progressive scan). So, when I play it on a 1080p display, does madVR:
1. First upscales chroma from 640x360 to luma plane resolution (1280x720) using selected chroma upscale algorithm
2. Combines 1280x720 luma with upscaled chroma
3. Upscales the resulting picture to 1080p using selected image upscale algo
OR
1. Directly upscales chroma from 640x360 to desired presentation resolution (1080p) using selected chroma upscale algo
2. Upscales luma from 1280x720 to 1080p using selected image upscale algo
3. Combines both images to presentation picture
Thanks!
VoodooNBGD is offline   Reply With Quote
Old 15th October 2018, 19:47   #53258  |  Link
Siso
Soul Seeker
Siso's Avatar
Is reduce compression artifacts needed when upscaling 1080p encodes to 2560x1080p? I was thinking using it with NGU Sharp - medium at strength 1.
Old 15th October 2018, 19:51   #53259  |  Link
Betroz
Is this for real?
Betroz's Avatar
report back what you get.
Which movie player are you using?
I am using MPC-HC, and yes of course I have set MadVr as video renderer
With these settings, both black level tests posted here show black crush :
- GPU set to Full RGB and 0-255 in Nvidia settings
- MadVr set to 0-255
- TV set to :
Black level HIGH
Gamma 2.2
Brightness 49
OLED light 50
Now the Windows desktop is brighter since I have the TV set to High in Black Level, and as I said the test pattern is very dark. I can't see all the boxes.
Edit : Small update here : I have increased my TV brightness to 53, and now I pass the THX Optimizer test image for brightness. Image here : https://ibb.co/dfZPLf
Edit 2 :The opening scene in Star Wars the last Jedi when you see the scrolling text over the dark sky with stars, with TV Black level set to Low, the black is perfect black. With Black Level set to High, black is not pitch black anymore. All this confirms my previous testing. So...
We can take this discussion in the other tread (https://forum.doom9.org/showthread.php?t=175769&page=6) I can post this there aswell.
My HTPC : i9 10900K | nVidia RTX 4070 Super | TV : Samsung 75Q9FN QLED
Betroz is offline   Reply With Quote
Old 15th October 2018, 20:07   #53260  |  Link
ryrynz
ryrynz's Avatar
Originally Posted by Siso View Post
Is reduce compression artifacts needed when upscaling 1080p encodes to 2560x1080p.
Needed? No. Is it beneficial for your content? Maybe. You'll have to compare for yourself. There are no wrong options here.
