Old 20th July 2019, 19:54   #41  |  Link
nevcairiel
Git has always worked fine for me on Windows, but I use the official Git for Windows, which I told to use the Windows SSL library, and not whatever mingw uses with its own certificate stuff.
Old 21st July 2019, 19:51   #42  |  Link
filler56789
SuperVirus
filler56789's Avatar
Well ++ FWIW ++ just-for-the-record:
I moved from MSYS1 to MSYS2 in 2016, and since then I have used only and always a sufficient subset of the ~portable git package~ downloaded from the official Git source
[But between 2011 and 2016 I used a tiny subset of the extinct msysgit, and that tiny subset "just worked" as well.]
Because I just want to download source-code through git, and because I still hadn't found a git server that refuses the git protocol, there was no problem for me in using just some .EXEs instead of the entire git package.
Let's be honest, at least for needs like mine, git is BLOATWARE and bloatware is pure evil
Not to mention that its Windows port is not as good as their creators and maintainers believe...
for example, I don't see the point
(assuming there is a (good) point)
in hardcoding exec_path = /mingw##/libexec/git-core in the Windows releases.
Why didn't they choose /usr instead?
Anyway, fortunately I discovered that placing the folders *ssl* and *git-core* in the same parent directory is what git.exe requires for dealing with HTTPS
(both under the MSYS2 environment and under cmd.exe).
filler56789 is offline   Reply With Quote
Old 22nd July 2019, 09:35   #43  |  Link
LigH
LigH's Avatar
The media-autobuild suite loads x264 nicely from the mentioned server. It runs Mercurial (hg) for x265 or git for x264, as required, in MSYS2/MinGW.
New German Gleitz board
Old 2nd January 2020, 20:21   #44  |  Link
LigH
LigH's Avatar
New upload: x264 core:159 r2991 1771b55
x264 0.159.2991 1771b55
(libswscale 5.6.100)
(libavformat 58.35.101)
(ffmpegsource 2.31.0.0)
built on Jan  2 2020, gcc: 9.2.0
x264 configuration: --chroma-format=all
libx264 configuration: --chroma-format=all
x264 license: GPL version 2 or later
libswscale/libavformat/ffmpegsource license: GPL version 2 or later
Happy New Year 2020
Old 3rd January 2020, 00:35   #45  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Happy New Year 2020
Old 17th April 2020, 12:13   #46  |  Link
LigH
LigH's Avatar
New upload: x264 core:160 r3000_33f9e14
x264 0.160.3000 33f9e14
(libswscale 5.6.101)
(libavformat 58.42.100)
built on Apr 16 2020, gcc: 9.3.0
Old 17th April 2020, 20:06   #47  |  Link
LoRd_MuldeR
Software Developer
Old 19th May 2020, 10:50   #48  |  Link
LigH
LigH's Avatar
Updated archive: x264 core:160 r3000_33f9e14
(libavformat 58.43.100)
built on May 18 2020, gcc: 10.1.0
Old 19th May 2020, 13:08   #49  |  Link
manolito
manolito's Avatar
Thanks for the update...
The only differences I can see is a new gcc version and a newer libavformat version. X264 itself has not changed, so does the new build make a difference for real life encodes?
Old 19th May 2020, 14:17   #50  |  Link
LigH
LigH's Avatar
I doubt; just for the people who can't sleep without bleeding edge software.
Old 19th May 2020, 16:41   #51  |  Link
manolito
manolito's Avatar
This excludes me...
Old 25th June 2020, 07:57   #52  |  Link
LigH
LigH's Avatar
New upload: x264 core:160 r3009 4c9b076
x264 0.160.3009 4c9b076
(libswscale 5.8.100)
(libavformat 58.47.100)
built on Jun 22 2020, gcc: 10.1.0
Old 26th June 2020, 20:09   #53  |  Link
benwaggoner
Is this a new release? I've not been able to find any current changelog or release notes.
Ben Waggoner
My Compression Book
Old 26th June 2020, 22:15   #54  |  Link
LoRd_MuldeR
Software Developer
TTBOMK, x264 doesn't really have "releases", just a bunch of commits pushed the official Git repository every know and then. But yes, there have been a few fixes recently.
You can simply look at the Git log:
https://code.videolan.org/videolan/x...commits/master
...or just:
https://gist.github.com/lordmulder/6...c990c0312c0763
Old 4th July 2020, 02:49   #55  |  Link
masterkivat
変身!
masterkivat's Avatar
I don't want to steal LigH's protagonism in providing builds, but I just set up MABS here in my machine and I'm enjoying it, it's a great tool for people like me who know "nothing" about compiling audio/video encoders.
Anyways, I noticed that a new rev for x264 was up and I decided to upload the build I got from MABS: x264 0.161.3015 4c2aafd
>x264 --version
(libavformat 58.48.100)
built on Jul 3 2020, gcc: 10.1.0
Hope everything went fine with it
masterkivat is offline   Reply With Quote
Old 4th July 2020, 19:42   #56  |  Link
LigH
LigH's Avatar
I do not mind at all. So I have less pressure.
Old 15th July 2020, 08:36   #57  |  Link
masterkivat
変身!
x264 0.161.3018 db0d417
>x264 -V
(libavformat 58.50.100)
(lsmash 2.16.1)
built on Aug 11 2020, gcc: 10.2.0
Old 15th July 2020, 13:15   #58  |  Link
LigH
LigH's Avatar
New upload: x264 core:161 r3018 db0d417
(lsmash 2.16.1)
built on Jul 15 2020, gcc: 10.1.0
Old 25th August 2020, 14:52   #59  |  Link
LigH
LigH's Avatar
Updated archive: x264 core:161 r3018 db0d417
(libavformat 58.51.100)
(ffmpegsource 2.40.0.0)
(lsmash 2.16.1)
built on Aug 25 2020, gcc: 10.2.0
Old 27th October 2020, 04:24   #60  |  Link
masterkivat
変身!
x264 0.161.3027 4121277 (x64)
>x264 -V
(libavformat 58.63.100)
(lsmash 2.16.1)
built on Oct 26 2020, gcc: 10.2.0
