16th May 2010, 18:49 | #61 | Link |
Programmer (or just 教务长)
I'll look at it tomorrow. Most of my tests were made with video+subtitles. That's how easySUP detects the resolution and framerate, otherwise it defaults to 1280x720@23.976... Or that's what I remember.
16th May 2010, 19:20 | #62 | Link |
Aging Video Hobbyist
Argh, I'm trying to duplicate my exact sequence, but having some trouble. I should point-out tho that I've been launching easySUP from it's own directory, and I also have mAVCHD in another directory--maybe C:\Program Files (x86)\easySUP\easySUP.exe is looking at the .ess and .ini in C:\Program Files (x86)\multiAVCHD or something.
Anyway now that you told me it looks for info from the .srt file, I know to make my settings/load my .ess AFTER I've loaded the .srt. Otherwise my settings get munged it seems. |
21st May 2010, 12:40 | #63 | Link |
21st May 2010, 15:30 | #64 | Link |
Thanks Dean, I will give it a try.
Without having specifically nailed it down, I still suspect part of my recent problem(s) with it were related to having easySUP in both its own folder and elsewhere with mAVCHD. I decided to leave easySUP with mAVCHD and not have it separate. |
21st May 2010, 15:32 | #65 | Link |
It shouldn't cause problems to have both, but...
easySUP uses a folder "easySUP" under the path it is saved in and all of its work is done there. When you have time - give it a try to see if there is any difference. Dean |
1st June 2010, 14:10 | #66 | Link |
Feature request:
1. When it automatically saves the sup, it saves it as .sup. It would be nice to save it with the name of the srt inserted. Example: movie.srt - movie.sup 2. A queue, for processing more than 1 subtitle at once. Thx. |
8th June 2010, 20:54 | #69 | Link |
generate BDN XML + png
i try to use easysup to generate BDN XML and the png
I import a test srt file and it starts and takes ages to process I dont get the point it seems to encode something but I just need the xml file and the png pictures. any ideas thanks |
8th June 2010, 21:07 | #70 | Link |
If you expected to get the result within 4-5 mins may be a new definition of "ages" is needed.
easySUP uses 2 applications and you can follow their progress while conversion is performed. TO GET THE POINT: While it "encodes something" - it creates the PNG files that you want PLUS the XML. Did you expect to get it done in 2 seconds?! Last edited by deank; 8th June 2010 at 21:09. |
9th June 2010, 10:20 | #71 | Link |
I made a test with the following srt file (7 subtitles only)
_____________ it takes 25 minutes to generate as a comparaison i used the program advanced subtitler from DVD Logic http://www.dvd-logic.com/subtitler.htm it takes 5 seconds to generate so something migt be wrong in my setup, any ideas? __________________________________ 1 11:30:01,720 --> 11:30:04,360 Ok, fertig und Action! 2 11:30:14,640 --> 11:30:17,640 66, 67, 68. Meine Glückszahl. Cut. 3 11:30:22,640 --> 11:30:24,680 Alle auf die Markierungen. 4 11:31:20,160 --> 11:31:24,080 Was braucht ein Film, der die Fantasie des Publikums in eine Traumwelt entführt, 5 11:31:24,160 --> 11:31:27,160 die über ein Jahr lang aufgebaut wurde? 6 11:31:27,880 --> 11:31:32,800 Ironischerweise sind die Werkzeuge dafür weniger fantasievoll. Lange Arbeitstage, 7 11:31:32,880 --> 11:31:36,880 endlose Planungen, präziseste Ausführung mit Hilfe von viel Personal und Technik... |
9th June 2010, 20:00 | #73 | Link |
After your post I thought why I actually use avs2bdnxml application to create the PNG's and the XML.
I created a small application just an hour ago (goSUP). It uses avisynth to create the PNGs and supports microDVD SUB, SRT and ASS/SSA files. It creates PNG+XML much much faster (in few seconds actually, so 100-200x speed improvement). It supports converting the PNG+XML to SUP/PGS with BDsup2sub. So in few words, you feed the app with .srt/.sub/.ssa/.ass file and you get PGS/SUP file (or/and PNG+XML). If there is any interest I can post more about it. Dean |
9th June 2010, 21:22 | #75 | Link |
I'll post a link for the .exe probably tomorrow. I'm still experimenting with shadow/outline/opacity settings.
At least it is really fast (about 50-100 subtitle lines per second depending on resolution). Dean |
9th June 2010, 21:32 | #76 | Link |
thank you Dean
I think the problem with the extremely long processing i had is due that in my srt file the timecode starts at 11:30:01,720 it means at 11 hours 30 min etc it seems that easysup starts to count by default at 00. so it assumed my film was 11 hours more ( I did not load any video ) a I right? Cyrille |
ass2sup, easysup, multiavchd, srt2sup, ssa2sup |
