5th October 2017, 09:07 | #46203 | Link |
You can either give write access to the folder madVR is installed in (usually somewhere in Program Files) to your user account and then it will create a settings.bin file in it, or you can export the HKEY_CURRENT_USER\SOFTWARE\madshi\madVR key from the registry (the resulting .reg is quite big, so zip it if you want to share it).
@madshi Would it be possible for madVR to store the settings.bin in %ProgramData% ? That folder has the advantage of having write access even for standard users.
HTPC: Windows 10 22H2, MediaPortal 1, LAV Filters/ReClock/madVR. DVB-C TV, Panasonic GT60, Denon 2310, Core 2 Duo E7400 oc'd, GeForce 1050 Ti 536.40 |
5th October 2017, 16:34 | #46205 | Link |
Troubleshooter
small horizontal dashes (white or black) occassionally flashing durning video
I'm noticing small white horizontal dashes (most of the time white, but on occasion black) flash on the screen at what may be random times during playing of videos. I've also noticed they flash on quite frequently (although not always) right after I pause videos too. Its a brief flash, and doesn't remain on the screen making me unable to take a screen shot.
(MadVR, MPC-HC 64, LAV-64, XySubfilter) I'll post my settings if needed, but before that I thought it may ring a bell to a few of you who may have encountered it yourselves in the past. Any theories on what may be causing it, or a setting I should try changing to remedy it?
System specs: Sager NP9150 SE with i7-3630QM 2.40GHz, 16 GB RAM, 64-bit Windows 10 Pro, NVidia GTX 680M/Intel 4000 HD optimus dual GPU system. Video viewed on LG notebook screen and LG 3D passive TV. |
5th October 2017, 18:27 | #46207 | Link | |
Just one remark: the Dynamic range setting in Adjust video colour section shouldn't have an effect on madVR.
5th October 2017, 21:19 | #46208 | Link |
Yes, that is very strange. I haven't had a problem with Nvidia + full range RGB in years.
madVR options explained |
5th October 2017, 22:18 | #46212 | Link |
Jinc is the the highest quality non-doubling scaler. It is a simple very high quality choice if you do not notice the difference from NGU.
5th October 2017, 23:36 | #46213 | Link |
The video block in the 1050 decodes pretty much everything and hardly consumes any power, and it's dedicated so you're not using other processing resources. The only case I'd see in your situation for not using it would be if copy-back mode has problems (usually with UHD content).
6th October 2017, 05:39 | #46214 | Link | |
I noticed that madVR produces a 1920x800 image and your VLC screenshot is 1920x804, the aspect ratio is different. I don't know much about VLC, but what renderer and decoder does it use? If it's DXVA and/or EVR, are you sure your graphics card video 'enhancements' are not processing the image? And how does it produce screenshots? Or did you use print screen? I also tried basic EVR, and the resulting image is 1920x804 like your VLC screenshot, but with the same brightness levels as madVR. I think the VLC image is the bad one here. Edit: this scene is a very good showcase of how much better at rendering madVR is than GPU drivers & EVR, btw!
HTPC: Windows 10 22H2, MediaPortal 1, LAV Filters/ReClock/madVR. DVB-C TV, Panasonic GT60, Denon 2310, Core 2 Duo E7400 oc'd, GeForce 1050 Ti 536.40 Last edited by el Filou; 6th October 2017 at 05:51. |
6th October 2017, 08:21 | #46215 | Link | |
Soul Seeker
6th October 2017, 10:11 | #46216 | Link |
Can someone give me tips for faster skipping/jumping inside low quality formats like porn? It needs 2-4sec to rebuild after jumping with my high settings on NGU AA, but maybe I did something wrong. HD 1080p movies work without delay.
I have tried to lower the setting and deactivate the NGU, but it doesn't really help, so it seams something else is wrong. |
6th October 2017, 11:00 | #46217 | Link |
I'm testing them but I do not see any difference between the various scalers, maybe I can not figure out what the differences are and with what images i have to do the tests?
6th October 2017, 12:03 | #46218 | Link | |
Could you try it that way? (If you're still around) |
6th October 2017, 12:23 | #46219 | Link | |
6th October 2017, 12:48 | #46220 | Link | |
When I skip/jump the decoder queue goes up over the set limit from 16 to 19/21 for a few sec, in this time the video stops. I'm using a i7 7700k, should I set the decoder queue higher then the default to fix the problem?
LG 27MU67-B, i7-7700K, MSI GTX 1080Ti Gaming X, MPC-HC / MPV |
