30th September 2010, 20:57 | #12581 | Link |
You can add support for FOURCC 'png '? It is used in the mov-files. I used the same decoder, which decodes the "PNG1" and "MPNG". I substituted the FOURCC in the splitter, but it's not the best solution.
mov-png_example I wanted to do the same "jpeg" (ffdshow_mediaguids.h, section //quicktime), but do not completely understand how to add changes in TglobalSettings.cpp. |
1st October 2010, 07:34 | #12583 | Link |
Unavailable
@ dansrfe:
1) patch a copy of ffdshow.ax ; 2) unregister the original ffdshow.ax ; 3) hide the original ffdshow.ax in a temp folder, move the modified .ax into ffdshow's folder ; 4) register the patched .ax file ; 5) start playing a DVD with MPC, then press the pause button ; 6) run Graphstudio, press CTRL + G, click "Connect" ; N.B.: I configured MPC to "prefer" ffdshow audio processor, since its default merit status is "DO_NOT_USE". P.S.: Several weeks ago, Keiyakusha tried to convince that "it would be very bad" if ffdshow had dedicated standalone filters, without shared capabilities & settings. Now, let's see whether he will change his mind. Last edited by Midzuki; 1st October 2010 at 07:42. Reason: formatting |
2nd October 2010, 14:06 | #12586 | Link |
Nope, they are still float.
MPC-HC 2.2.1 |
4th October 2010, 10:28 | #12588 | Link |
MOV PCM problem
Hi. I have problem with playback of few MOV files from Canon IXUS 200 IS. It play in wierd slow motion in graphstudio - 2.5FPS. If i disable audio, it play just fine. Here is graph: MP4Splitter.ax rev.1.4.2646.0, FFDshow 3608 MPC MPA audio decoder play it without any issue too on both machines. Here video is sample Media info: Code:
Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Baseline@L4.1 Format settings, CABAC : No Format settings, ReFrames : 1 frame Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 4s 566ms Bit rate mode : Variable Bit rate : 23.1 Mbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 30.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.837 Stream size : 12.6 MiB (97%) Language : English Encoded date : UTC 2010-10-03 10:07:35 Tagged date : UTC 2010-10-03 10:07:35 Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177 Transfer characteristics : BT.709-5, BT.1361 Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M Audio ID : 2 Format : PCM Format settings, Endianness : Little Format settings, Sign : Signed Codec ID : sowt Duration : 4s 566ms Bit rate mode : Constant Bit rate : 705.6 Kbps Channel(s) : 1 channel Sampling rate : 44.1 KHz Bit depth : 16 bits Stream size : 393 KiB (3%) Language : English Encoded date : UTC 2010-10-03 10:07:35 Tagged date : UTC 2010-10-03 10:07:35
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin Last edited by hoborg; 4th October 2010 at 10:31. |
4th October 2010, 18:15 | #12590 | Link | |
No idea what can causing it, but if i use MPC MPA audio decoder, it is working fine, so must be something in FFDshow.
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin |
5th October 2010, 10:52 | #12591 | Link |
@devs
Possible bug in h.264/avc decoder Haali Media Splitter + ffdshow r3572 (libavcodec / ffmpeg-mt with 1-4 threads) = corrupted image Haali Media Splitter + ffdshow r3572 (DVXA enabled) = no corruption sample http://www.mediafire.com/?4z2as0yjvnjoage
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 5th October 2010 at 10:55. |
5th October 2010, 16:30 | #12592 | Link |
crash when seeking
hi,
since rev.3501 (3500 works fine) when I'm seeking fast (holding & sliding the cursor) with mpc-hc, it crash. After many tests, i've found that this is caused by the AC3 encoding option (16, 32 & 32 float are ok), absolutely nothing else is activated (i used 48000hz inputs since resample was desactivated). On the MPC side, i've found that if i disable his filters (avi & mp3 for my tests) it works again. Going back to previous versions didn't do anything (last try:1.3.1896) sorry for my poor english & testing abilities , and thanks for all your work. system: XP sp3. ffdshow x86 regular & icl11 edit: doesn't seem to crash with multichannels tracks (tried ac3,truehd, dts(hd), lpcm) Last edited by augur; 5th October 2010 at 18:57. Reason: add informations |
6th October 2010, 15:53 | #12594 | Link |
Should be fixed in 3611.
MPC-HC 2.2.1 |
6th October 2010, 17:31 | #12595 | Link |
ffdshow does not render pgs subtitles from a .ts file at all. Internal mpc renderer with EVR-CP renders it fine. Also I want to bump the broken karaoke ssa support in ffdshow problem. Please give some sort of eta of when these problems can be expected to be fixed. Thanks again ffdshow devs.
7th October 2010, 16:11 | #12596 | Link |
I have a problem with ffdshow expanding the height of the video, repeating lower lines, if it is not MOD 16. But it does that in a rather strange way.
- ffdshow_rev3611_20101006_xvidvideo-ru_x86_icl11 - mpc-homecinema.1.4.2667_(x86)_msvc2010 both from xvidvideo.ru; this effect happened with earlier versions too. At first I usually had disabled all internal decoders and splitters of MPC-HC where useful, to allow decoding via ffdshow. But it appears that the MPC-HC internal decoder does the same as ffdshow. The media info dialog in MPC-HC (Shift+F10; Details) shows the following values, depending on ffdshow or MPC-HC wether or not using DXVA for decoding H.264: a) if DXVA decoding for H.264 is enabled: General { Video size = 640 x 368 }; stream list { Video: MPEG4 Video (H264) 640x360 25.00fps [Video] } -- at least MOD 16 b) if DXVA decoding for H.264 is disabled: General { Video size = 640 x 372 }; stream list { Video: MPEG4 Video (H264) 640x360 25.00fps [Video] } -- not even MOD 16?! Test files: MP4 or MKV (same content, ~330 KB each) P.S.: DGIndexNV 2026 and 2030 warn "Stream specifies cropping" (for the MKV) and report the "coded size" as 640x384 (even MOD 32). Last edited by LigH; 7th October 2010 at 16:25. |
8th October 2010, 01:04 | #12598 | Link |
any chance the DXVA filter can be made to produce the same output as the software-only filter in the following respect...
for interlaced material, output colorspace - e.g. NV12 only set interlace flag in output media type I find this is essential when watching e.g. some Concert Blu-Rays. just wondering if it's possible! also could the DXVA filter be somehow rolled into the main filter such that it can be chosen based on a profile rule? (and is there any way of creating a profile rule to distinguish interlaced from non-interlaced content??) |
