26th September 2012, 22:02 | #561 | Link |
Post the Avisynth version AVSMeter reports and your complete script.
Groucho's Avisynth Stuff |
26th September 2012, 23:00 | #564 | Link |
I just tried several MT modes with the latest MT version and AVSMeter reports them correctly. No idea why it does not work for you.
Edit: Ouch, it seems that Ian was the first to see the forest for the trees.
Groucho's Avisynth Stuff Last edited by Groucho2004; 26th September 2012 at 23:04. |
26th September 2012, 23:22 | #565 | Link |
tried this, but still nothing's change and avsmeter still reports 0. Must be something wrong with my computer but I can't find the problem.
SetMTMode(1,0) MPEG2Source("mt_test.d2v") SetMtMode(2) LimitedSharpenFaster() |
26th September 2012, 23:31 | #566 | Link |
Just put "SetMTMode(5)" in the first line.
27th September 2012, 02:48 | #568 | Link |
Sorry, I'm pretty much out of ideas. Probably a long shot - Maybe something in your "autoload" directory is interfering?
27th September 2012, 05:02 | #569 | Link | |
UPDATE: After further investigation, I was able to find the problematic avs script in the plugins folder, named tbcv01.avs, one i got back in 2008. Removing it will solve the problem. I'll leave a note in the avisynth plugin wiki about this issue. Last edited by lansing; 27th September 2012 at 06:00. Reason: update status |
3rd October 2012, 20:31 | #571 | Link |
Please allow me to reveal myself as novice. I am using 2.60MTalpha_SEt 8/28/12 and obviously, DeleteFrame(0,0) does not delete two frames, but just one.
Question: is there, and if so where, a bugtracking list, and is this issue maybe already known? Sorry for causing effort with this probably misplaced post. |
3rd October 2012, 22:39 | #572 | Link |
Avisynth Developer
DeleteFrame(0,0) is only supposed to delete 1 frame.
The input list is internally sorted, deleting duplicates. The coding choices were to ignore duplicates or throw an error, it was decided by a very small margin that ignoring duplicates would be a more useful implementation. To delete the first 2 frames either do :- DeleteFrame(0, 1) or DeleteFrame(0).DeleteFrame(0) |
8th October 2012, 18:48 | #574 | Link |
Hi, does anyone know how to get around the problem of mpc-hc not closing down properly when using avisynth. I have read on some threads that this is due to a problem somewhere in avisynth / mt? I am using SVP Interframe scripts with the latest avisynth from this thread, and whenever avisynth is enabled in ffdshow, mpc-hc refuses to gracefully shut down about 30% of the time. Sometimes it silently stays there in task manager, other times it will give a program not responding windows dialog.
Any hacked workarounds that has proven to work for anyone or does anyone know the reason for this? |
8th October 2012, 19:30 | #575 | Link | |
8th October 2012, 20:08 | #576 | Link |
Hi ney2x, I try to keep upto date with ffdshow builds from xhmikosr's page here http://xhmikosr.1f0.de/ (currently using build 4487)and avisynth 2.6 MT builds from this thread (currently using 2012.08.28: http://www.mediafire.com/file/4dm34k...rk/avisynth.7z). I'll try a different build of ffdshow now from xvidvideo.ru and report back.
EDIT: Wow you're right, I havn't been able to reproduce with the xvidvideo one at least. Opened a video 20 times and got 0 crashes of mpc-hc. Usually I would get at least 6 or 7. I'll ping xhmikosr Last edited by mark0077; 8th October 2012 at 20:14. |
21st October 2012, 23:42 | #579 | Link |
Is there any way to get the MT.dll to work with AviSynth v2.6... or plans to build one... I have tried v0.7 and it (understandably) throws up an error regarding the wrong avisynth.dll version. SetMTMode() gives a speed improvement, but MT("filter") is vastly faster. This is the only reason I still use v2.58.
