18th August 2015, 17:10 | #1 | Link |
X264 Horizontal Rips on i_threads> 1
I'm trying to write an x264 encoder. However, I cannot set i_threads to anything greater then 1 and still get a usable picture out.
My Settings Code:
Preset : veryfast Tune : zerolatency Profile : high i_width : 1920 i_height : 1080 i_fps_num : 25 i_fps_den : 1 i_timebase_num : 1 i_timebase_den : 1000 i_keyint_max : 32 b_repeat_headers : 1 b_annexb : 1 b_intra_refresh : 1 b_aud : 1 b_open_gop : 1 RC: i_rc_method : X264_RC_ABR i_bitrate : 5120 i_vbv_buffer_size : 5120 i_vbv_max_bitrate : 5120 * 1.1 i_qp_constant : 20 f_qblur : .5 f_complexity_blur : 20 Analyse: i_me_method : X264_ME_UMH i_subpel_refine : 7 i_me_range : 16 b_psnr : 0 b_ssim : 0 i_noise_reduction : 2 inter : X264_ANALYSE_I4x4 | X264_ANALYSE_I8x8 | X264_ANALYSE_PSUB16x16 i_threads = 1: http://tinypic.com/player.php?v=14xd...8#.VdNUyPlVhBc i_threads = 2: http://tinypic.com/player.php?v=b7ex...8#.VdNWyvlVhBc What could be causing this? |
18th August 2015, 20:12 | #3 | Link |
API's, the input is a bitmap buffer I fill manually every 5 frames
That is exactly the parameters I am using. Code:
static int count = 0; static int one; if (count % (TARGET_FPS / 2) == 0) { one = rand() % 8; } int two, three; do { two = rand() % 8; } while (two == one); do { three = rand() % 8; } while (three == one || three == two); COLORREF* colorBuffer = reinterpret_cast<COLORREF*>(buffer); COLORREF background = GetColor(one); COLORREF lineOneInnerColor = GetColor(two); COLORREF lineOneOuterColor = GetColor(three); COLORREF lineTwoColor = GetColor(three); COLORREF lineThreeColor = GetColor(three); if (count % (TARGET_FPS / 5) == 0) { for (int i = 0; i < DEFAULT_WIDTH * DEFAULT_HEIGHT; ++i) { colorBuffer[i] = background; } for (int i = 0; i < LineOneOuterLength; ++i) { PIXELLOCATION p = LineOneOuter[i]; int index = p.Y * DEFAULT_WIDTH + p.X; colorBuffer[index] = lineOneOuterColor; } for (int i = 0; i < LineOneInnerLength; ++i) { PIXELLOCATION p = LineOneInner[i]; int index = p.Y * DEFAULT_WIDTH + p.X; colorBuffer[index] = lineOneInnerColor; } for (int i = 0; i < LineTwoLength; ++i) { PIXELLOCATION p = LineTwo[i]; int index = p.Y * DEFAULT_WIDTH + p.X; colorBuffer[index] = lineTwoColor; } for (int i = 0; i < LineThreeLength; ++i) { PIXELLOCATION p = LineThree[i]; int index = p.Y * DEFAULT_WIDTH + p.X; colorBuffer[index] = lineThreeColor; } } count++; Code:
::avpicture_fill(&picRaw, static_cast<uint8_t*>(bufferIn), AV_PIX_FMT_RGB32, iWidthIn, iHeightIn); ::sws_scale(sws, picRaw.data, picRaw.linesize, 0, iHeightIn, picIn.img.plane, picIn.img.i_stride); picIn.i_pts = static_cast<int64_t>(mi_pts); picIn.i_type = X264_TYPE_AUTO; ::x264_encoder_encode(pEncoder, &pNals, &iNalCount, picIn, &picOut); memcpy(bufferOut, pNals[0].p_payload, i_frame_size); |
x264 |
