15th June 2012, 16:57 | #42 | Link |
! sorry my english bad ! i like using your tx264 gui this like minicoder (discontinued and not update)
I can be a little problem when using 0.7.2 Tx264 up, when I convert the movie anime all went smoothly with no problems, but when I do not find a complete description of the file earlier in the output folder (my ouput in " D:\ ") I am using win 7 x64 |
15th June 2012, 17:40 | #43 | Link | |
TEncoder, TX264, TAC
If you are using mp4 as container and your windows (or system's temp folder) is located at a driver other than "D:\" that can cause the problem. Last edited by ozok; 15th June 2012 at 19:18. |
15th June 2012, 19:12 | #44 | Link | |
EDIT: I think window system's temp folder problem, in log tell temp cannot delete or merge something like that, you have solution to fix it Last edited by rexdeymond; 15th June 2012 at 19:16. |
15th June 2012, 19:19 | #46 | Link |
@rexdeymond on main window at the bottom-left there is a button labeled "Logs/Outputs", click on it and from the new window click "Save" then send me the saved txt file. also you can send me screenshots or info about problematic files.
15th June 2012, 19:29 | #47 | Link |
@ ozok
I have some questions about the features present, can you give details about the features of the present, I used to use the medium, but when I use a very fast computer I always die alone instead of a BSOD, but what if I use the fast and the quality convet faster than convert what better or worse than the medium, you have recommendation what must i use for fast and good quality edit: my hadware [url]http://valid.canardpc.com/show_oc.php?id=2406735[url] Last edited by rexdeymond; 15th June 2012 at 21:45. |
15th June 2012, 19:59 | #49 | Link |
[16/06/2012 1:22:44] Started deleting temp files...
[16/06/2012 1:22:44] Deleted 0 file(s). [16/06/2012 1:22:44] Finished deleting temp files. [16/06/2012 1:24:16] Started deleting temp files... [16/06/2012 1:24:16] Deleted 1 file(s). [16/06/2012 1:24:16] Finished deleting temp files. -------------------------------------------- [16/06/2012 1:24:16] Starting encoding process [16/06/2012 1:24:16] Command lines: --pass 1 --bitrate 250 --profile high --preset medium --tune animation --stats "C:\Users\SLim\AppData\Local\Temp\TX264\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].stats" --output NUL "D:\D A T A ~ V I D E O\{ = X ! X = }\T0428-701781\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].mkv" --pass 2 --bitrate 250 --profile high --preset medium --tune animation --stats "C:\Users\SLim\AppData\Local\Temp\TX264\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].stats" --output "C:\Users\SLim\AppData\Local\Temp\TX264\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].mkv" "D:\D A T A ~ V I D E O\{ = X ! X = }\T0428-701781\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].mkv" -y -i "D:\D A T A ~ V I D E O\{ = X ! X = }\T0428-701781\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].mkv" -vn -f wav -map 0:1 "C:\Users\SLim\AppData\Local\Temp\TX264\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].wav" -br 48000 -if "C:\Users\SLim\AppData\Local\Temp\TX264\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].wav" -of "C:\Users\SLim\AppData\Local\Temp\TX264\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].aac" chapters -s "D:\D A T A ~ V I D E O\{ = X ! X = }\T0428-701781\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].mkv" tracks "D:\D A T A ~ V I D E O\{ = X ! X = }\T0428-701781\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].mkv" 2:"C:\Users\SLim\AppData\Local\Temp\TX264\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN]1.ass" 3:"C:\Users\SLim\AppData\Local\Temp\TX264\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN]2.srt" --chapters "C:\Users\SLim\AppData\Local\Temp\TX264\\chapters.txt" -o "D:\D A T A ~ C O N V E T E R\TX264(0.7.4.1523)\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].mkv" "C:\Users\SLim\AppData\Local\Temp\TX264\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN]1.ass" "C:\Users\SLim\AppData\Local\Temp\TX264\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN]2.srt" "C:\Users\SLim\AppData\Local\Temp\TX264\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].mkv" "C:\Users\SLim\AppData\Local\Temp\TX264\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].aac" -------------------------------------------- [16/06/2012 1:27:57] Done video encoding with x264 ffms [info]: 640x480p 1:1 @ 2187/91 fps (vfr) x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Fast FastShuffle SSEMisalign LZCNT x264 [info]: profile Main, level 3.0 x264 [info]: frame I:442 Avg QP:23.65 size: 18147 x264 [info]: frame P:14654 Avg QP:27.77 size: 2940 x264 [info]: frame B:26269 Avg QP:30.36 size: 158 x264 [info]: consecutive B-frames: 12.6% 20.7% 7.4% 10.2% 9.5% 39.5% x264 [info]: mb I I16..4: 49.8% 0.0% 50.2% x264 [info]: mb P I16..4: 8.0% 0.0% 0.0% P16..4: 26.0% 0.0% 0.0% 0.0% 0.0% skip:66.0% x264 [info]: mb B I16..4: 0.2% 0.0% 0.0% B16..8: 3.3% 0.0% 0.0% direct: 0.9% skip:95.7% L0:45.4% L1:47.1% BI: 7.5% x264 [info]: final ratefactor: 27.84 x264 [info]: coded y,uvDC,uvAC intra: 31.7% 36.4% 11.3% inter: 3.4% 2.7% 0.1% x264 [info]: i16 v,h,dc,p: 57% 22% 16% 5% x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 30% 15% 23% 4% 7% 5% 4% 6% 6% x264 [info]: i8c dc,h,v,p: 58% 16% 22% 3% x264 [info]: Weighted P-Frames: Y:4.0% UV:2.7% x264 [info]: kb/s:256.87 encoded 41365 frames, 202.28 fps, 256.87 kb/s [16/06/2012 1:34:16] Done video encoding with x264 ffms [info]: 640x480p 1:1 @ 2187/91 fps (vfr) x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Fast FastShuffle SSEMisalign LZCNT x264 [info]: profile High, level 3.0 x264 [info]: frame I:442 Avg QP:22.71 size: 18084 x264 [info]: frame P:14654 Avg QP:26.21 size: 2832 x264 [info]: frame B:26269 Avg QP:31.93 size: 165 x264 [info]: consecutive B-frames: 12.6% 20.7% 7.4% 10.2% 9.5% 39.5% x264 [info]: mb I I16..4: 33.0% 31.2% 35.7% x264 [info]: mb P I16..4: 3.1% 3.4% 1.7% P16..4: 19.5% 6.9% 3.1% 0.0% 0.0% skip:62.3% x264 [info]: mb B I16..4: 0.1% 0.0% 0.0% B16..8: 7.3% 0.4% 0.1% direct: 0.1% skip:92.1% L0:41.2% L1:57.1% BI: 1.7% x264 [info]: 8x8 transform intra:38.7% inter:56.9% x264 [info]: coded y,uvDC,uvAC intra: 30.2% 44.9% 17.3% inter: 2.8% 3.6% 0.2% x264 [info]: i16 v,h,dc,p: 60% 22% 10% 8% x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 20% 9% 50% 4% 3% 4% 2% 4% 3% x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 26% 13% 23% 6% 7% 8% 5% 7% 4% x264 [info]: i8c dc,h,v,p: 56% 17% 22% 4% x264 [info]: Weighted P-Frames: Y:4.0% UV:2.7% x264 [info]: ref P L0: 58.5% 8.0% 14.6% 7.1% 5.0% 5.3% 1.5% 0.0% x264 [info]: ref B L0: 80.0% 12.5% 4.9% 1.9% 0.7% x264 [info]: ref B L1: 95.1% 4.9% x264 [info]: kb/s:250.20 encoded 41365 frames, 111.00 fps, 250.21 kb/s [16/06/2012 1:34:24] Done audio decoding ffmpeg version N-41416-g718607b Copyright (c) 2000-2012 the FFmpeg developers built on Jun 8 2012 12:49:40 with gcc 4.6.3 configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-runtime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libass --enable-libcelt --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-libnut --enable-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libutvideo --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --ena libavutil 51. 56.100 / 51. 56.100 libavcodec 54. 25.100 / 54. 25.100 libavformat 54. 6.101 / 54. 6.101 libavdevice 54. 0.100 / 54. 0.100 libavfilter 2. 78.101 / 2. 78.101 libswscale 2. 1.100 / 2. 1.100 libswresample 0. 15.100 / 0. 15.100 libpostproc 52. 0.100 / 52. 0.100 Input #0, matroska,webm, from 'D:\D A T A ~ V I D E O\{ = X ! X = }\T0428-701781\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].mkv': Metadata: creation_time : 2006-09-30 23:29:50 Duration: 00:28:43.70, start: 0.000000, bitrate: 1612 kb/s Stream #0:0(eng): Video: h264 (High), yuv420p, 640x480, SAR 1:1 DAR 4:3, 23.98 fps, 23.98 tbr, 1k tbn, 59.94 tbc (default) Metadata: title : bible black - episode 3: black sacrifice Stream #0:1(jpn): Audio: vorbis, 48000 Hz, stereo, s16 (default) Metadata: title : vorbis (stereo) Stream #0:2(eng): Subtitle: ssa (default) Metadata: title : .ass (styled) Stream #0:3(eng): Subtitle: text Metadata: title : .srt (plain) Stream #0:4: Attachment: ttf Metadata: filename : 39 Smooth.ttf mimetype : application/x-truetype-font Stream #0:5: Attachment: ttf Metadata: filename : KALLAMAR.TTF mimetype : application/x-truetype-font Stream #0:6: Attachment: ttf Metadata: filename : KALLI___.TTF mimetype : application/x-truetype-font Stream #0:7: Attachment: ttf Metadata: filename : KALLS___.TTF mimetype : application/x-truetype-font Output #0, wav, to 'C:\Users\SLim\AppData\Local\Temp\TX264\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].wav': Metadata: creation_time : 2006-09-30 23:29:50 encoder : Lavf54.6.101 Stream #0:0(jpn): Audio: pcm_s16le ([1][0][0][0] / 0x0001), 48000 Hz, stereo, s16, 1536 kb/s (default) Metadata: title : vorbis (stereo) Stream mapping: Stream #0:1 -> #0:0 (vorbis -> pcm_s16le) Press [q] to stop, [?] for help size= 323194kB time=00:28:44.23 bitrate=1535.5kbits/s video:0kB audio:323194kB global headers:0kB muxing overhead 0.000014% [16/06/2012 1:35:13] Done audio encoding with neroaac ************************************************************* * * * Nero AAC Encoder * * Copyright 2009 Nero AG * * All Rights Reserved Worldwide * * * * Package build date: Feb 18 2010 * * Package version: 1.5.4.0 * * * * See -help for a complete list of available parameters. * * * ************************************************************* Processed 1723 seconds... [16/06/2012 1:35:14] Done extracting chapters from mkv [16/06/2012 1:35:20] Done extracting subtitle from mkv Extracting track 2 with the CodecID 'S_TEXT/ASS' to the file 'C:\Users\SLim\AppData\Local\Temp\TX264\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN]1.ass'. Container format: SSA/ASS text subtitles Extracting track 3 with the CodecID 'S_TEXT/UTF8' to the file 'C:\Users\SLim\AppData\Local\Temp\TX264\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN]2.srt'. Container format: SRT text subtitles Progress: 100% [16/06/2012 1:35:20] Done muxing to mkv mkvmerge v5.5.0 ('Healer') built on Apr 6 2012 21:43:24 Error: Unknown chapter file format in 'C:\Users\SLim\AppData\Local\Temp\TX264\\chapters.txt'. It does not contain a supported chapter format. [16/06/2012 1:35:20] Started deleting temp files... [16/06/2012 1:35:20] Can't delete: Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN]1.ass [16/06/2012 1:35:20] Can't delete: Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN]2.srt [16/06/2012 1:35:20] Deleted 8 file(s). [16/06/2012 1:35:20] Finished deleting temp files. |
15th June 2012, 20:22 | #50 | Link | |
You can ignore "can't delete" warningsē |
15th June 2012, 21:43 | #51 | Link | |
General Unique ID : 229945979227156434504248381857017017353 (0xACFDFC153379096883397FFD3046B409) Complete name : D:\D A T A ~ V I D E O\{ = X ! X = }\T0428-701781\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP01.[ENG.SUBS].[UNCEN].mkv Format : Matroska Format version : Version 1 File size : 331 MiB Duration : 28mn 1s Overall bit rate mode : Variable Overall bit rate : 1 650 Kbps Encoded date : UTC 2006-09-17 00:42:37 Writing application : mkvmerge v1.7.0 ('What Do You Take Me For') built on Apr 28 2006 17:20:19 Writing library : libebml v0.7.7 + libmatroska v0.8.0 Attachment : Yes / Yes / Yes / Yes Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L5.1 Format settings, CABAC : Yes Format settings, ReFrames : 16 frames Codec ID : V_MPEG4/ISO/AVC Duration : 28mn 1s Bit rate : 1 489 Kbps Nominal bit rate : 1 885 Kbps Width : 640 pixels Height : 480 pixels Display aspect ratio : 4:3 Frame rate : 23.976 fps Original frame rate : 29.970 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.202 Stream size : 299 MiB (90%) Title : bible black - episode 1: school of black magic Writing library : x264 core 50 svn-557M Encoding settings : cabac=1 / ref=16 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=6 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / chroma_qp_offset=0 / slices=2 / nr=0 / decimate=1 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=0 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=1885 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 Language : English Default : Yes Forced : No Audio ID : 2 Format : Vorbis Format settings, Floor : 1 Codec ID : A_VORBIS Duration : 28mn 1s Bit rate mode : Variable Bit rate : 128 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 25.7 MiB (8%) Title : vorbis (stereo) Writing library : libVorbis 1.1.1/1.1.2 (UTC 2005-03-04) Language : Japanese Default : Yes Forced : No Writing application : Made with BeSweet v1.5b31 Encoded_Application/Url : http://DSPguru.doom9.org Text #1 ID : 3 Format : ASS Codec ID : S_TEXT/ASS Codec ID/Info : Advanced Sub Station Alpha Compression mode : Lossless Title : .ass (styled) Language : English Default : Yes Forced : No Text #2 ID : 4 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Title : .srt (plain) Language : English Default : No Forced : No |
15th June 2012, 22:00 | #52 | Link | |
Looks like TX264 detects chapters even though file hasn't got any.
About presets, from http://mewiki.project357.com/wiki/X264_Settings: Quote:
15th June 2012, 23:11 | #54 | Link |
@ozok thanks I've fixed the problem by unchecking the mux chapter, Can you make a feature file size, because I'm too lazy to calculate birate file if I convert a lot of movies
17th June 2012, 08:53 | #56 | Link |
@ozok : I can be the same problem with the first, but with a different file and I feel TX264 (0.7.4.1523) runs with no good to use subtitle files with style
Note: I tried to use MKV or MP4 as the container still has the same problem |
17th June 2012, 14:45 | #57 | Link |
Download works now. Just ran for first time. I get a can't find neroaac file error. I'm assuming your download does not include this file. I have it. Where do I stick it. If there are anymore files I need to complete full functionality..please advise. BTW, might want to put this in a FAQ text file with the download.
17th June 2012, 14:51 | #58 | Link |
@Mr. Monte place it in the Tools folder. You can disable that warning by following "Other Options">"Do not warn if neroaacenc is not present", if you don't want to have neroaacenc. All other files are there. I was not sure whether it'd cause problems if i had added it to the package. FAQ sound like a good idea thx.
17th June 2012, 20:37 | #59 | Link |
@rexdeymond
No discussion of torrent downloads is allowed per forum rule 6. Strikes can follow further violations. http://forum.doom9.org/forum-rules.htm @all No further help on this issue is to be given. Last edited by Guest; 17th June 2012 at 20:47. |
faac, mkv, mp4, neroaacenc, x264 |
