Old 17th February 2018, 23:02   #49041  |  Link
XMonarchY
Does anyone use madVR to upscale or enhancement non-motion, still images, photos, textures, etc? I know madVR is meant for motion, but it has so many upscaling and overall options that it seems like it could have advantages over common upscaling techniques used in Photoshop and GIMP, especially for amateur users like me.
MadVR has many more options for upscaling, downscaling, artifact removal, sharpness, and a ton of other functions used in still imagery creation and editing. It would be nice if there were "madVR plugins" for common editing software like Photoshop, GIMP, and Paint.NET. Unless of course and madVR features are quite useless for still imagery enhancement.
8700K @ 5Ghz | ASUS Z370 Hero X | Corsair 16GB @ 3200Mhz | RTX 2080 Ti @ 2100Mhz | Samsung 970 NVMe 250GB | WD Black 2TB | Corsair AX 850W | LG 32GK850G-B @ 165Hz | Xonar DGX | Windows 10 LTSC 1809
XMonarchY is offline   Reply With Quote
Old 18th February 2018, 01:06   #49042  |  Link
Originally Posted by el Filou View Post
@Asmodian @huhn @ryrynz I think steakhutzeee's issue is that for some reason the upstream filter is not detecting his PAL DVDs as film material and is outputting an interlaced stream to madVR.
yeah of cause it is. there is no auto detection.
Old 18th February 2018, 01:25   #49043  |  Link
ryrynz
ryrynz's Avatar
Originally Posted by Dean007 View Post
Before it was just blueish seek bar. It was way better. Is this because of Madvr? Anyone knows how to get it back?
Yes. That's madvr's exclusive mode seek bar. Go into your player and set madvr as renderer. If need be set madvr to exclusive mode.. Klite shouldn't have changed your madvr settings though.
Old 18th February 2018, 01:28   #49044  |  Link
ryrynz
ryrynz's Avatar
I do know madshi has plans to allow users to use his algorithms in Avisynth/Vapoursynth, outside of that you'll just have to wait and see.. I doubt you'll see anything this year. So for right now you'll just have to use the screenshot functionality on your upscaled images within your player.
Old 18th February 2018, 04:41   #49045  |  Link
QBhd
QB the Slayer
QBhd's Avatar
Originally Posted by GCRaistlin View Post
Is there a media player that supports madVR and can play acestream links?
No but you can use the AceStream Player and setup up a stream output that can then be opened up in your favorite madVR capable player:
https://prnt.sc/igafpe
Once the AceStream is running just open this in your player (I use PotPlayer):
http://localhost:8902/tv.asf
This is off-topic and should be discussed elsewhere. But yes it can be done easily, I do it all the time.
QB
QBhd is offline   Reply With Quote
Old 18th February 2018, 07:48   #49046  |  Link
cork_OS
cork_OS's Avatar
madshi has already answered this question:
I may consider creating a Photoshop plugin at some point in the future. There might be different algo speed levels available in the future. But yes, these algos need to be manually adjusted per video, which does reduce their real life suitability.
Photoshop plugins are supported by several Windows photo tools. So it makes the most sense. Any other plugin type is specific to only one tool, which makes no sense to me.
I'm infected with poor sources.
cork_OS is offline   Reply With Quote
Old 18th February 2018, 08:18   #49047  |  Link
ryrynz
ryrynz's Avatar
Shh, using search is hard.
Old 18th February 2018, 11:55   #49048  |  Link
el Filou
el Filou's Avatar
Do you mean there is an issue on his system, or it isn't possible?
LAV can detect my PAL DVDs as films and disable the interlace flag on output pin (see my OSD screenshot: https://drive.google.com/open?id=1Qu...5RKj2lxJuM5ZR0 , this is playing directly from a retail disc)
Edit: I arrived to this conclusion because when I play bonuses madVR then says "deinterlacing on (says upstream)", same with DVB SD TV recordings.
HTPC: Windows 10 1809, MediaPortal 1, LAV Filters, ReClock, madVR. DVB-C TV, Panasonic GT60, 6.0 speakers Denon 2310, Core 2 Duo E7400, GeForce 1050 Ti
Old 18th February 2018, 13:09   #49049  |  Link
mytbyte
Playing cinema content in a 23.976Hz multiple means that audio will be 0.1% too slow and yes you can hear the difference when A/B'ing, music will be out of tune for that matter. Only some TV shows are actually meant to be watched at 23.976Hz AFAIK, my point being that 23.976 content is rarely meant to be watched at its native rate
I must admit I don't quite understand exactly what you are trying to say, can you pls elaborate? (Most)All 24 fps cinema content is released as 23.976, or broadcast as fractional framerate, audio is in sync with that framerate and should be watched at that particular refresh or a multiple of it. So, re-syncing to 24 Hz or a multiple would actually mean changing the speed of audio (not necessarily the pitch - this can be retained), not the other way around, AFAIK...
mytbyte is offline   Reply With Quote
Old 18th February 2018, 16:24   #49050  |  Link
el Filou
el Filou's Avatar
If audio is in sync with 23,976 fps then it means it was slowed down from original audio which was in sync with 24,000 fps by 0,1%, or else sound would be out of sync by 7 seconds at the end of a 2 hour movie.
(not that it matters to anyone except people who enjoy A/Bing a 0,1% pitch difference. )
Old 18th February 2018, 16:45   #49051  |  Link
leeperry
Kid for Today
Music will be out of tune anyway, but this is getting OT I'm afraid so enjoy your movies playing at 99.9% speed if you like: https://www.innerfidelity.com/conten...and-his-gadget
My point is that 99.9% of 23.976 stored content is meant to be watched at its native 24fps speed, that's all.
Next stop is 25fps PAL speedup so sit tight but good to know that MPC can fix this crap w/o Reclock, might give it a shot then.
Old 18th February 2018, 17:41   #49052  |  Link
mytbyte
@leepery: OK, I get it...you may have the case unless the 23.976 transfer was already not pitch corrected (it's such a small difference that perhaps studios don't bother)...for 25 fps conversion, however, I know that it's quite common practice to pitch-correct (not universal practice, though)...how can you know that when reclocking back to 24 fps?
Old 18th February 2018, 18:54   #49053  |  Link
lavfilter can't decode DVD by it self it is using the MS decoder.
and it is normal that it is send as interlanced even with an soft telecine file and this is technically not wrong so this can be different between dvd and windows versions.
Old 18th February 2018, 19:41   #49054  |  Link
mytbyte
Perhaps el filou has some truly progressive PAL DVDs? A run through mediainfo would reveal the truth?
Old 18th February 2018, 19:50   #49055  |  Link
LigH
LigH's Avatar
MediaInfo knows little, it scans only technical flags in headers, but doesn't look at video frame contents. That's a job for your eyes and your brain.
Truly progressive video content might still be encoded in interlaced MPEG-2 format. There may be only few DVD Video productions encoded in progressive MPEG-2 video mode (I know only "Animatrix").
New German Gleitz board
Old 18th February 2018, 20:46   #49056  |  Link
a lot of DVDs are soft telecine which is practically progressive.
and 25 hz DVD are PsF which is again practically progressive.
Old 18th February 2018, 22:06   #49057  |  Link
mytbyte
yes, for PAL DVD that's correct at file level, but the player will present each half-frame separated in time every 50th of a second when it really needs to weave the fields together as full frame and present it twice for 50Hz display, in order to lose interlace deffects, line twitter and stairstepping on motion...you need progressive flag for that...I have tested and MadVR treats interlaced PAL PsF as video content instead of film unless you force film mode
Old 19th February 2018, 03:47   #49058  |  Link
Apache553
madVR lags too much on my HTPC.It consumes 75% of CPU but only 2% of GPU.I tried to reinstall the video card driver and the OS,but that didn't work.Is there anyone who knows how to solve this problem?Thanks!
My HTPC:
CPU: AMD Phenom II x4 965
Video card: R7 360 2gb
RAM: 8GB DDR3
MB: GIGABYTE GA-970A-DS3P
Apache553 is offline   Reply With Quote
Old 19th February 2018, 05:17   #49059  |  Link
maybe i didn't make my self clear enough with there is no "auto detection". so if a stream is flagged interlaced madVR will do what you tell it to do with an interlaced stream.
and every mpeg2 stream on a DVD has to be flagged as interlaced that's the spec. that's why they are PsF which is just a progressive stream flagged as interlaced and that'S why a soft telecine NTSC file has to be transform to interlaced 3:2.
this is simplified so not 100 % correct.
can you make a screen of your OSD (control+j)) don't use the forum to upload it plz.
Old 19th February 2018, 09:20   #49060  |  Link
Apache553
The screenshot is here: https://drive.google.com/file/d/1Mxf...ew?usp=sharing
