Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > Advanced authoring
Old 16th March 2017, 03:09   #1  |  Link
davidshao
Help with menu's in Scenarist
I am just starting to use Scenarist. I have all my assets ready and my playlists. After my first mux I tested my project and the problem I'm having is with the top menu. I decided to have a classic flow and have my top menu come up after my first play but the menu would only come up for maybe 10 seconds then go straight to main title movie. Any suggestions with what I'm doing wrong.
davidshao is offline   Reply With Quote
Old 20th March 2017, 13:51   #2  |  Link
mp3dom
Are you referring to BD or DVD? In case of BD, you need to put the syntax to do a loop. In case of DVD, you need to add the code to cellcommand or postcommand (depending by your need) that add the loop (basically, a link to itself)
menu, scenarist
