Old 23rd June 2016, 11:31   #1801  |  Link
pinterf
Originally Posted by Reel.Deel View Post
I started making some changes to the documentation and need some opinions. Here's the difference between the two: http://diff.pics/JbQx0fvGOTeM/1
I added a syntax and parameters section and I also highlighted the syntax and listed all the parameters and their descriptions. I would like to do this to all the internal filters. Yea or nay?
Yes. And a big thanks for dealing with the documentation which is usually the last one in the task queue, at least for the programmers point of view.
pinterf is offline
Old 23rd June 2016, 11:33   #1802  |  Link
pinterf
Originally Posted by tormento View Post
Post edited and DGIs inserted.
Please look original thread and see all the trials I did.
Will try to strip down things. As far as I remember, I could even use prefilter 2 instead of 4 or x86 vs x64 and nothing changed.
Thank you for saving time for me. I run too much things parallel nowadays and each one is a challenge for me.
pinterf is offline
Old 23rd June 2016, 12:55   #1803  |  Link
tormento
Acid fr0g
tormento's Avatar
Done encoding with any prefilter. Error occurs only with 4.
Uploaded resulting files.
@turment on Telegram
tormento is offline
Old 23rd June 2016, 15:49   #1804  |  Link
Groucho2004
The more I think about it, the more I like the blank slate approach when it comes to how to go from here regarding AVS+.
In order to serve frames to a client, all that's needed is avisynth.dll and optionally a some (compatible) plugins in a directory. The user doesn't have to "install" Avisynth and switching between versions (and auto-load plugin directories) can be done in an instant without rebooting.
Considering this, re-compiling all compatible plugins catering for an all new interface shouldn't be such a big deal.
If a user really has to use some ancient plugin, he could just switch to the "official" AVS2.6.
Groucho's Avisynth Stuff
Groucho2004 is offline
Old 23rd June 2016, 16:47   #1805  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Starting with RemoveGrain that was last compiled with VS2005
MysteryX is offline
Old 23rd June 2016, 16:56   #1806  |  Link
Groucho2004
Why? What's wrong with RGTools?
Old 23rd June 2016, 21:27   #1807  |  Link
ultim
AVS+ Dev
ultim's Avatar
Everybody please, there is no need to point out that a conversion layer can be written. As described in #1770, I know that the old interface can be worked around. But frankly, I will not invest my own time in developing and maintaining compatibility to something which we actually want to switch away from, once we switched away from it. I will not block such attempts, so if somebody comes up with working patches, I'll merge them. But those patches won't come from me.
As for accessing size_t members using int-functions: That will work in *most* cases, as long as plugins are well-behaved. Unfortunately, by some brain-dead decision in the early development of avs classic, the class members have been made public. Knowing the quality standards of many plugins, there is no guarantee that somebody does not access the fields directly, or maybe even create/dereference instances of VideoFrame objects. They shouldn't, most plugins probably don't, but this is a breaking change of the ABI, and I won't be doing code reviews of all plugins to determine which ones we broke and which ones we didn't.
It would be a different story if we had a central repository of all plugins in Git so that we can recompile them with a single click, as well as a package manager, so that if somebody updates the core, plugins will be updated automatically to the new interface. This was a GSoC-proposal once...
AviSynth+
ultim is offline
Old 23rd June 2016, 22:48   #1808  |  Link
ultim
AVS+ Dev
ultim's Avatar
As pinterf is now an active contributor, I feel it is time to submit again an old problem I introduced months ago.
Here is the original sample from BD.
When I apply the following script, using AviSynth 2.6 MT, I have good encodings.
13HoursAV26.dgi
PHP Code:
SetMTMode(3)
SetMemoryMax(2048)
LoadPlugin("D:\eseguibili\media\DGDecIM\dgdecodeim.dll")
DGSourceIM("E:\in\2_24 13 hours — The secret soldiers of Benghazi\13HoursAV26.dgi"silent=true)
ChangeFPS(last,last,true)
SetMTMode(2)
crop(01400, -140)
SMDegrain (tr=4,PreFilter=4,thSAD=400,contrasharp=false,refinemotion=false,plane=4,chroma=true,lsb=true,mode=6
Result.
When I use AviSynth+, I have image corruption.
13HoursAVS+.dgi
PHP Code:
SetMemoryMax(8000)
SetFilterMTMode("DEFAULT_MT_MODE"2)
SetFilterMTMode("ChangeFPS"3)
SetFilterMTMode("DGSource"3)
LoadPlugin("D:\eseguibili\media\DGDecNV\x64\DGDecodeNV.dll")
DGSource("E:\in\2_24 13 hours — The secret soldiers of Benghazi\13HoursAVS+.dgi")
#SetFilterMTMode("DGSourceIM", 3)
#LoadPlugin("D:\eseguibili\media\DGDecIM\x64\dgdecodeim.dll")
#DGSourceIM("E:\in\2_24 13 hours — The secret soldiers of Benghazi\13HoursCUT.dgi", silent=true)
#Crop(0, 140, 0, -140)
SMDegrain (tr=4,PreFilter=4,thSAD=400,contrasharp=false,refinemotion=false,plane=4,chroma=true,lsb=true,mode=6)
Prefetch(8
prefilter=1 OK
prefilter=2 OK
prefilter=3 OK
prefilter=4 CORRUPTION
Memento:
PHP Code:
prefilter
[int"-1"01234] or [clip: - ]
off (Default)
light controlled gauss blur
mild median/gauss blur
strong median/gauss blur
dfttest (spatial)
KNLmeansCL (spatio-temporal GPU filter)
variable prefiltered clip input variable
I have tried to use x86 version of AviSynth+, even DGIndexIM.
Results does not change.
The plugin versions I use are the following for both AviSynth and AviSynth+.
PHP Code:
[Avisynth CPP 2.6 plugins]
D:\Programmi\media\AviSynth+\plugins64\KNLMeansCL-0.7.6.dll  (n/a)
D:\Programmi\media\AviSynth+\plugins64\MaskTools-2.1b1-tp7.dll  (2.1.0.0)
D:\Programmi\media\AviSynth+\plugins64\MedianBlur2-0.94-tp7.dll  (n/a)
D:\Programmi\media\AviSynth+\plugins64\MVTools-2.7.0.22-pfmod.dll  (2.7.0.22)
D:\Programmi\media\AviSynth+\plugins64\RgTools-0.92.1-tp7.dll  (n/a)
Avisynth CPP 2.5 plugins]
D:\Programmi\media\AviSynth+\plugins64\DFTTest-1.9.4.dll  (1.9.4.0)
D:\Programmi\media\AviSynth+\plugins64\Dither-1.27.2.dll  (n/a
I can provide other movie examples too.
Ideas? Fixes?
P.S.: Previous post is here.
Instead of trying to find alternatives, I'd be happy if we found the bug.
Looking at the encodings, to me this looks like a clipping (overflow/underflow) bug, both at high and low pixel values. If that is true, once the binary filter causing this is isolated, the fix should be simple.
AviSynth+
ultim is offline
Old 23rd June 2016, 23:12   #1809  |  Link
tormento
Acid fr0g
tormento's Avatar
Prefilter=4 means KNLMeansCL and the belonging part of SMDegrain. The strange thing is that it happens only with AVS+
tormento is offline
Old 23rd June 2016, 23:28   #1810  |  Link
ultim
AVS+ Dev
ultim's Avatar
Not strange at all. It is with all likelyhood an internal filter in the Avs+ core. Most of those have been rewritten in Avs+ to get rid of inline assembly. And I do see SMDegrain making calls to internal functions along the prefilter=4 paths (too). KNLMeansCL might be the feature of prefilter=4, but I do not think this plugin is the cause of the problem.
AviSynth+
ultim is offline
Old 23rd June 2016, 23:53   #1811  |  Link
real.finder
I remember dogway say this happened if DGSourceIM + KNLMeansCL in the same script in avs+
See My Avisynth Stuff
real.finder is offline
Old 24th June 2016, 07:21   #1812  |  Link
LigH
LigH's Avatar
... so are two different plugins using the same hardware for acceleration, therefore might switch hardware operation modes of graphic chips independently of each other, especially when working multi-threaded. There is little surprise that this may corrupt the video when the GPU gets reprogrammed to decode the next frame while filtering the previous.
New German Gleitz board
LigH is offline
Old 24th June 2016, 08:46   #1813  |  Link
jpsdr
Honestly, about interface, evolution does the job only half, to do thing properly to the end, i would have put all the pitch in ptrdiff_t. If you have to break existing things, break it for a full good purpose, not half. And also the Getpitch functions should return the same.
But, i agree about something. These critical datas shouldn't have been public, and should be accessed only via functions.
Well, personnaly, i would have done :
class VideoFrame {
public:
	volatile long refcount;
	VideoFrameBuffer* const vfb;
	const size_t offset;
	const ptrdiff_t pitch;
	const uint32_t row_size;
	const int32_t height;
	const size_t offsetU, offsetV;  // U&V offsets are from top of picture.
	const ptrdiff_t pitchUV;
	const uint32t row_sizeUV;
	const int32_t heightUV;
jpsdr is offline
Old 24th June 2016, 11:12   #1814  |  Link
tormento
Acid fr0g
tormento's Avatar
It happens with DGSource (NV) + KNLMeansCL too.
tormento is offline
Old 24th June 2016, 11:13   #1815  |  Link
tormento
Acid fr0g
tormento's Avatar
Ok and why only with AVS+ and not with AVS standard?
tormento is offline
Old 24th June 2016, 11:22   #1816  |  Link
ultim
AVS+ Dev
ultim's Avatar
Can you provide a minimalistic script that reproduces the problem? Not with SMDegrain, but something without eval, without calling other scripts, without conditional code etc. As few lines as possible.
AviSynth+
ultim is offline
Old 24th June 2016, 11:30   #1817  |  Link
tormento
Acid fr0g
tormento's Avatar
Avisynth+
Sorry, not in my capabilities.
tormento is offline
Old 24th June 2016, 13:04   #1818  |  Link
DJATOM
DJATOM's Avatar
tormento
Avs+: r1841, MT-pfmod, x86
KNLMeansCL: http://rgho.st/6K5RRq2t8 (dunno how to check file version)
Script:
SetMemoryMax(8000)
SetFilterMTMode("DEFAULT_MT_MODE", 2)
SetFilterMTMode("ChangeFPS", 3)
DGSourceIM("13HoursCUT.dgi", silent=true)
Prefetch(8)
Results: http://screenshotcomparison.com/comparison/176528
Please ensure that your PC is not infected by viruses, then try my KNLMeansCL (32-bit dll).
I didn't tried to check this script on my PC, only on notebook.
DJATOM is offline
Old 24th June 2016, 13:31   #1819  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Originally Posted by DJATOM View Post
tormento
Script:
SetMemoryMax(8000)
Prefetch(8)
I've also been having issues with SMDegrain(prefilter=4) working terrible with MT; working faster with a single thread. I suppose this script will have the same problem.
MysteryX is offline
Old 24th June 2016, 13:44   #1820  |  Link
DJATOM
DJATOM's Avatar
Strange, but in avspmod x64 it only shows the first 800 pixels for height. Applying SMDegrain (with lsb) didn't change it, still 1920x800. 32-bit version works fine. Need to investigate.
Upd: made a new index and problem is fixed now (tested with avs+ r1873, x64; index made with DGIndexIM beta 50 X64). Still can't see any corruption :\
DJATOM is offline
