Old 19th March 2018, 02:15   #4001  |  Link
Dont know if below is bugged, or misleading error message, or both.
# OK
Blankclip(Length=1,Width=1,height=1,Pixel_type="YV24").PointResize(256,256)
# Resize: source image too small for this resize method. Width=1, Support=1.
Blankclip(Length=1,Width=1,height=1,Pixel_type="YV24").BilinearResize(256,256)
# Resize: source image too small for this resize method. Width=2, Support=2.
Blankclip(Length=1,Width=4,height=4,Pixel_type="YV12").BicubicResize(256,256)   # NOTE, YV12, Presumably error for chroma
Blankclip(Length=1,Width=2,height=2,Pixel_type="YV24").BicubicResize(256,256)   # NOTE, YV24
# Resize: source image too small for this resize method. Width=4, Support=4.
Blankclip(Length=1,Width=4,height=4,Pixel_type="YV24").Lanczos4Resize(256,256)
Blankclip(Length=1,Width=4,height=4,Pixel_type="YV24").GaussResize(256,256)
Blankclip(Length=1,Width=4,height=4,Pixel_type="YV24").BlackmanResize(256,256)
# Resize: source image too small for this resize method. Width=3, Support=3.
Blankclip(Length=1,Width=3,height=3,Pixel_type="YV24").LanczosResize(256,256)
Blankclip(Length=1,Width=4,height=4,Pixel_type="YV24").sincResize(256,256)
Blankclip(Length=1,Width=2,height=2,Pixel_type="YV24").Spline16Resize(256,256)
Blankclip(Length=1,Width=3,height=3,Pixel_type="YV24").Spline36Resize(256,256)
Return Last
For eg YV24, width=2, height=2, Says width = 2, Support=2 (when it clearly produces an error message, ie seems not to support 2).
Think its been like this 4E4 (believe it exists as above in avs standard).
EDIT: Presume similar on height, untried.
StainlessS is offline
Old 19th March 2018, 03:32   #4002  |  Link
raffriff42
Retried Guesser
raffriff42's Avatar
misleading I'd say
avs_core\filters\resample_functions.cpp(247)
if (source_size <= filter_support) {
env->ThrowError("Resize: Source image too small for this resize method. Width=%d, Support=%d", source_size, int(ceil(filter_support)));
EDIT one quick fix
env->ThrowError("Resize: Source image too small for this resize method. Width=%d, Minimum=%d", source_size, int(ceil(filter_support))+1 );
So instead of
you would see
source image too small for this resize method. Width=1, Minimum=2.
raffriff42 is offline
Old 19th March 2018, 14:08   #4003  |  Link
qyot27
qyot27's Avatar
Maybe it's because I'm tired, but if a filter is supposed to support value X (as per filter_support in the code there), it shouldn't be erroring out when equal to the value of filter_support. It only should in the less than case. Unless filter_support is not actually the minimum supported value, but the maximum unsupported value (in which case it being named 'filter_support' in the code is also misleading or incorrect).
In other words, either the operator in the code is wrong (it should be just <, not <=) or the naming of both 'filter_support' and the 'Support' field in the error message are wrong.
qyot27 is offline
Old 24th March 2018, 04:44   #4004  |  Link
raffriff42
Retried Guesser
raffriff42's Avatar
I'm getting access violations when downsizing inside an Animate call. Maybe it's just my system.
It does not happen in AVS 2.6.1, and it does not happen when "z_" avsresize filters are substituted.
ColorbarsHD(width=640, height=400)
## optional - these do not change the test result
KillAudio
ConvertToYV12
Trim(0, length=150)
Animate(0, 120, "_MyBlur", 0.0, 60.0)
## optional - make the clip longer so AvsMeter can chew on it
R=Reverse
Last+Reverse
Loop(100)
return Last
function _MyBlur(clip C, float rad)
    ## HEART OF THE TEST:
    ## BilinearResize causes intermittent...
    ##   | Exception 0xC0000005 [STATUS_ACCESS_VIOLATION]
    ##   | Module:   C:\Windows\system32\KERNELBASE.dll
    ##   | Address:  0x00007FFF071D92FC
    ## (64-bit)
    ## or...
    ##   | Module:   C:\Windows\SysWOW64\avisynth.DLL
    ##   | Address:  0x618064ED
    ## (32-bit)
    ## but avsresize "z_BilinearResize" is OK
    return (rad<0.1) ? C
    \ : C.BilinearResize(
    \        m4(Float(C.Width)/(rad+1.0)),
    \        m4(FLoat(C.Height)/(rad+1.0)))
    \    .GaussResize(
    \        C.Width, C.Height, p=19)
### MOD-4-and-at-least-16 helper function
## @ Didée
function m4(float f)
    (f<16) ? 16 : Int(Round(f/4.0)*4)
Old 24th March 2018, 05:01   #4005  |  Link
Did not try z_lib resizers, but your script (as supplied, running for 3 mins) does OK on XP32 bit.
EDIT: OK after redo at 6 mins.
Why this, (Round produces an Int already, you can answer for Didee if you like [did it change in more recent version of Avs])
EDIT: Only relevant mention of round I could find,
Changes from 2.06
Fixed ceil, floor and round functions.
Avs+ thread 1 Million and 25 thousand views since Sept 2013, WOW ! [cookies seem to track if user viewed already].
Old 24th March 2018, 08:04   #4006  |  Link
pinterf
Thanks, reproduced.
EDIT: and fixed on git.
pinterf is offline
Old 26th March 2018, 01:49   #4007  |  Link
`Orum
I'm curious, is it still best practice not to cache frames ever, for any purpose, as this post suggests? I'm still running into a few performance issues and I think they may be, at least in part, due to hammering the PCIe bus constantly when moving frames between the CPU and GPU.
My filters: DupStep | PointSize
`Orum is offline
Old 26th March 2018, 23:21   #4008  |  Link
Motenai Yoda
Motenai Yoda's Avatar
merge seems broken with 10 12 14 bit clip
powered by Google Translator
Motenai Yoda is offline
Old 27th March 2018, 01:17   #4009  |  Link
Yoda, give some example for Pintef, please.
Old 28th March 2018, 00:04   #4010  |  Link
Motenai Yoda
convertbits(10) #12 or 14
merge(last,0.33)
convertbits(8)
I also notice some memory leak since few releases, with avspmod, it will eat a lot of ram even with few previews after script modifications, but not sure is an avs+ bug or avspmod or other filter. It usually thrown an out of memory error like "can't access frame at this position" and then I get even some windows stuff not working well.
Old 28th March 2018, 02:52   #4011  |  Link
`Orum
I noticed something similar with ThrowError() and a lot of text, where AvsPmod (and not AviSynth+ I think--I'll have to test in another app when I have time) would essentially turn into this:
for(;;)
    malloc(1000000);
In any case I would never assume leaks or bugs are in AviSynth+ by testing with only AvsPmod, considering how insanely buggy AvsPmod alone is.
`Orum is offline
Old 28th March 2018, 09:35   #4012  |  Link
TheFluff
Excessively jovial fellow
for(;;)
    malloc(1000000);
If AvsPmod attempts to catch an exception thrown from inside Avisynth (for example, if a plugin raises an error using Avisynth's ThrowError), then yes, it'll most likely leak the exception object (if the catch actually works at all, which isn't certain either). Attempting to catch an exception from across a DLL boundary should in general never be done. It is only safe if both sides are built with the exact same compiler and linked with exactly the same runtime, but even then, just don't. Avisynth API calls should never be wrapped in try/catch blocks. See this article on the wiki.
TheFluff is offline
Old 28th March 2018, 13:53   #4013  |  Link
`Orum
That still doesn't explain why it would endlessly allocate memory until it couldn't any more.
Anyway, the point was that at the very least AvsP[mod] shouldn't be a test for memory leaks from AviSynth+. It should be tested with something a lot more stable, e.g. VirtualDub, avs2yuv, AVSmeter, etc. And even then, to make sure the leak is within AviSynth+ itself one should avoid external filters.
`Orum is offline
Old 28th March 2018, 20:33   #4014  |  Link
pinterf
New build with important fixes and some minor tweaks. Thanks for the reports.
Download Avisynth+ r2664-MT
In this changelog I left there intentionally some lines about a finally postponed modification. Read it as a preliminary info (32 bit float YUV chroma format). We could start a discussion about it.
20180328 r2664
-   Fix: YUY2 Sharpen overflow artifacts - e.g. Sharpen(0.6)
-   Fix: Levels: 32 bit float shift in luma
-   Fix: Merge sse2 for 10-14bits (regression)
-   Fix: AVX2 resizer possible access violation in extreme resizes (e.g. 600->20)
-   Fix: 32bit float PlanarRGB<->YUV conversion matrix
-   Fix: VfW: fix b64a output for OPT_Enable_b64a=true
-   Enhanced: VfW output P010 and P016 conversion to SSE2 (VfW output is used by VirtualDub for example)
-   Enhanced: ColorYUV: recalculate 8-16 bit LUT in GetFrame only when changed frame-by-frame (e.g. in autowhite)
-   Enhanced: ConvertBits 32->8 sse2/avx2 and 32->10..16 sse41/avx2 (8-15x speed)
Not included, preliminary for the near future:
-   Big change: 32 bit float YUV formats, U and V are now zero based.
    Internally YUV 32 bit float chroma center became 0.0 (the neutral value which is 128 in the 8-bit world)
    Like in VapourSynth or in avsresizer using z.lib image library.
    'Expr' changes are affecting built-in constants/operators when used in chroma plane of a 32bit clip.
    - 'cmin', 'cmax' return the zero-based shifted versions of the 16 and 240 (8 bit) values
    - For U and V planes, constant 'range_half' results in 0.0 instead of the old 0.5
    - 'scaleb' will also give zero-based result when found in an expression for chroma plane
      (e.g. for a 32 bit float clip the '128 scaleb' will result in 0.0 instead of 128/255 for U and V planes)
      But 'scalef' when the target or source of the constant conversion is 32bits, remains independent from the plane type.
    - 'range_max' is 0.5 for 32 bit float chroma
    - new constant 'range_min', which is -0.5 for 32 bit float chroma, (0 otherwise)
    Additional warning: when you move 32bit float U or V plane to Y using CombinePlane, you have to be sure
    that your filters do not rely on this new Y plane being in 0..1 range. Or else convert it by using Expr("x 0.5 +") to the 0..1 range
    Similarly: ExtractU and ExtractV will simply return the unaltered chroma planes, which are now zero-centered
pinterf is offline
Old 29th March 2018, 15:22   #4015  |  Link
GMJCZP
GMJCZP's Avatar
Thanks for the update.
I do not know if someone happens to me but the downloads by GitHub are very slow, and I have problems entering to avisynth.nl.
By law and justice!
GMJCZP's Arsenal
GMJCZP is offline
Old 29th March 2018, 15:23   #4016  |  Link
`Orum
Are variables not cached along with frames? For example (forgive the obvious assumptions made, it's just to illustrate the problem):
#define MAX_DELTA 1
for(int f = 0; f < 100; f++) {
	PVideoFrame vf = clip->GetFrame(f, env);
	strstream dbg;
	dbg << env->GetVarDef("FFPICT_TYPE", AVSValue('?')).AsInt() << ends;
	OutputDebugStringA(dbg.str());
	dbg.freeze(false);
	for(int n = 1, n <= MAX_DELTA; n++)
		foo(vf, clip->GetFrame(f + n, env)); // What foo() does isn't really relevant here, just know that it doesn't request any frames
If you raise MAX_DELTA, you suddenly get different output for your FFPICT_TYPE vars! This could also be a bug in FFVideoSource() but it seems more likely (to me, anyway) that the variables set when a frame is retrieved are not cached and restored when that frame is requested again and returned from AviSynth+'s cache later on. So, is that the case?
Edit: I can write my own filter in order to rule out (or in) FFVideoSource() as the problem if you'd like.
`Orum is offline
Old 29th March 2018, 16:03   #4017  |  Link
pinterf
Avisynth has no frame properties like Vapoursynth has. The method of filling the variable is a workaround hack which probably works only when the variable is constant.
You can define a filter to NonCachedGenericVideoFilter, like Reverse or Loop works internally.
pinterf is offline
Old 29th March 2018, 16:31   #4018  |  Link
`Orum
Ah, that's unfortunate. I don't suppose there's any chance this will change in the future?
Correct me if I'm wrong but this won't fix the issue if, for example, you have a script like this:
FFVideoSource("foo.mkv")
bar()
myfilter()
If bar() is someone else's filter that's cached and does frame requests outside of the current frame, my filter would still have issues getting the correct FFPICT_TYPE, right?
Edit: Now that I think about it, even if AviSynth+ cached these it would still require the earlier filter to do the request for any non-offset frames last. For instance, if you think about a filter that does a temporal blend of frame 'f' with radius 'x' (forward and backward), it would still have to request frame 'f' last and not frame 'f + x' to get the variable correct. It seems like a better solution is to either parse the the FFVideoSource() cache (if that even contains the picture types), or the source file itself, but neither is friendly if there's a simple Trim() in the script before it hits myfilter(). In any case, there's no general solution, as even the idea of a picture type disappears with any temporal filtering.
`Orum is offline
Old 29th March 2018, 19:37   #4019  |  Link
GMJCZP
GMJCZP's Avatar
Someone?
By law and justice!
GMJCZP's Arsenal
GMJCZP is offline
Old 29th March 2018, 20:20   #4020  |  Link
poisondeathray
Someone?
No problems here.
poisondeathray is offline
