Old 10th April 2010, 00:54   #21  |  Link
dstln
Person
dstln's Avatar
Encoding times certainly do matter but wow :P
I personally think it would make much more sense to have the "normal" requirement as realtime and then adjust "high speed" and "high quality" semi arbitrarily from there as you see fit. Either way it's too late now since the rules are already set and process in place, but yeah. Maybe next year.
dstln is offline   Reply With Quote
Old 16th April 2010, 15:14   #22  |  Link
Dyomich
Codec Analysis Expert
Real-time requirements differ too much for different PC configurations. It is main problem of this requirement. During previous comaprisons some developers told us that our PCs too slow or too fast for some requirements.
Dyomich is offline   Reply With Quote
Old 17th April 2010, 07:37   #23  |  Link
Biggiesized
Biggiesized's Avatar
Originally Posted by Blue_MiSfit View Post
Indeed. I consider ~12fps (half realtime for 24p) to be quite usable for most scenarios.
12 FPS is twice realtime. 48 FPS would be half real-time. (This is measured in terms of length of encoding. If you encoded 24p content at 12 FPS, it would take twice as long as if you encoded it at 24 FPS, which is realtime.)
Personally, I think 5 times real-time should be the minimum threshold. (That's roughly 5 FPS).
Biggiesized is offline   Reply With Quote
Old 17th April 2010, 13:52   #24  |  Link
AnonCrow
<nitpick> FPS is a unit of speed , not a unit of time. </>
AnonCrow is offline   Reply With Quote
Old 17th April 2010, 14:26   #25  |  Link
G_M_C
Originally Posted by bob0r View Post
Dyomich, i have prepared this graph for you:
Originally Posted by Emulgator View Post
The flat parts are amazing, feeling calm.
I lol'ed
An explination on what the graph represents might be usefull. But hey, people seem to love their graphs
G_M_C is offline   Reply With Quote
Old 24th May 2010, 12:13   #26  |  Link
Dyomich
Dear codec professionals!
We have finished H.264 Video Codecs Comparison report prepearing.
We have tested:
  • DivX H.264
  • Elecard H.264
  • Intel® MediaSDK AVC/H.264
  • MainConcept H.264
  • Microsoft Expression Encoder
  • Theora
  • x264
  • XviD (MPEG-4 ASP codec)
You can read it here http://compression.ru/video/codec_comparison/h264_2010/
Old 24th May 2010, 12:26   #27  |  Link
julius666
julius666's Avatar
We have tested:
  • DivX H.264
  • Elecard H.264
  • MainConcept H.264
  • Theora
  • x264
On the Speed/Quality tradeoff charts, normal preset's chart is missing for me.
julius666 is offline   Reply With Quote
Old 24th May 2010, 12:37   #28  |  Link
Dyomich
Thank you for remark!
Try to refresh your browser window.
Old 24th May 2010, 12:51   #29  |  Link
julius666
julius666's Avatar
Thx, it works now.
Of course x264 is winner in those cases too
Old 24th May 2010, 18:20   #30  |  Link
creamyhorror
Good to see this comprehensive codec evaluation again. I see MainConcept narrowly beat x264 on HDTV Normal preset. I wonder why? A particular type of material that MainConcept performs better on?
creamyhorror is offline   Reply With Quote
Old 24th May 2010, 18:22   #31  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Make sure to check the individual tests; it's quite possible for a single test to shift all the results in one direction if the results are dramatic enough.
Old 16th February 2011, 05:15   #32  |  Link
Bordo32
Blue_MiSfit, just curious if you have done a few codecs comparison as you have mentioned earlier:
"I'll be doing my own comparison soon, between Rhozet Carbon Coder (Mainconcept) and x264 at 50mbps 1080p for mezzanine file purposes."
Bordo32 is offline   Reply With Quote
codec testing, divx, h.264, msu
