Old 17th October 2013, 02:04   #61  |  Link
Marchand
Marchand's Avatar
Strongene Android HEVC/H.265 Decoder
Version: V2013.10.15 Release Date: 2013/10/15 Size: 6.24MB
Release Notes:
1. A demo version; 2. Adopting ffmpeg as audio-video framework, offering amended patches for ffmpeg; 3. Supporting .flv file with HEVC/H.265 stream; 4. Supporting .hevc, .hm10, .hm91, .bin and .bit format HEVC/H.265 streams; 5. The default thread setting is 1 and can be changed via application menu
Configuration:
Resolution: 480x320 pixels or above; Supporting ARMv7 CPU Architecture and NEON Multimedia Instruction Set; Supporting Android 2.3 or higher
http://xhevc.com/resouce/Strongene_L...2013_10_15.rar
Strongene iOS HEVC/H.265 Decoder
Version: V2013.10.15 Release: 2013/10/15 Size: 1.53MB
Release Notes:
Configuration:
Compatible with iphone and ipad; Supporting iOS 6.0 or higher
Marchand is offline   Reply With Quote
Old 17th October 2013, 12:34   #62  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Since yesterday, the current FFmpeg branch now supports HEVC decoder/demuxer streams...
Old 17th October 2013, 13:57   #63  |  Link
VFR maniac
Spinner of yarns
VFR maniac's Avatar
What way is used to encapsulate HEVC into FLV?
As far as I know, the specification is not published by Adobe.
I'll add the support of HEVC-in-FLV into ffmpeg/libav if available.
僕と契約して、L-SMASH developerになってよ!
L-SMASH | L-SMASH Works | Opus-in-ISOBMFF specification and reference software
VFR maniac is offline   Reply With Quote
Old 17th October 2013, 16:59   #64  |  Link
JEEB
もこたんインしたお!
JEEB's Avatar
The HEVC-in-FLV hack (or actually, hacks) is/are completely unrelated to Adobe in any way or form, and as we now have at least somewhat official ways of putting HEVC into containers, I would most definitely recommend people to refrain from using or implementing this hacked up mapping for public consumption. FLV is simple to hack things into, yes. But using possible values that Adobe might use in the future sounds like a big pot of problems.
(I still do wish that ISO/IEC would finally do their ballot and make 14496-15, 3rd edition, official -- the draft specification hasn't had changes done to it for months by now)
[I'm human, no debug]
JEEB is offline   Reply With Quote
Old 17th October 2013, 18:26   #65  |  Link
Kurtnoise
Kurtnoise's Avatar
A hack like this ?
Yeah, sadly...
Old 17th October 2013, 18:38   #66  |  Link
VFR maniac
Spinner of yarns
VFR maniac's Avatar
So, The Flash Player can't play them at all but they are called FLV? Retarded!
Originally Posted by Kurtnoise View Post
A hack like this ?
Yeah, sadly...
I don't think it works well unless the extradata encoded as concatenations of parameter sets with start codes and the stream is encapsulated as Annex B format.
As far as I read the change in MPC-HC BE, Strongene imitates the AVCDecoderConfigurationRecord not a draft of HEVCDecoderConfigurationRecord.
The ffmpeg/libav's HEVC decoder works only when extradata is encoded as HEVCDecoderConfigurationRecord (14496-15 format) or concatenations of parameter sets with start codes (Annex B format).
Old 17th October 2013, 21:04   #67  |  Link
benwaggoner
Wow, FLV is the last format I'd think anyone would adopt on purpose for a new technology unrelated to Flash!
Ben Waggoner
My Compression Book
Old 20th October 2013, 02:43   #68  |  Link
filler56789
SuperVirus
filler56789's Avatar
Can someone please say if the AVIs and VfW-based MKVs created through Graphstudio from the Strongene HEVC source filter
are or are not standard-compliant?
{ for the uninformed: sample file(s) @ http://optavisse.com/2013/07/11/hevc-in-avi-why-not/ }
filler56789 is offline   Reply With Quote
Old 20th October 2013, 08:10   #69  |  Link
VFR maniac
Spinner of yarns
VFR maniac's Avatar
There is no official specification of HEVC-in-AVI and VfW-based HEVC as there is no official specification of AVC-in-AVC and VfW-based AVC.
VfW is problematic for B-frames without hacks because of 1-frame-in-1-frame-out.
AVI is problematic for seek when any B-frame is present because AVI has no concept of presentation and/or composition timestamp.
Old 20th October 2013, 08:31   #70  |  Link
filler56789
SuperVirus
Thanks for the clarification.
I thought that B-frames were a problem only for the VfW API, not for the AVI and ASF containers themselves
At least according to http://guru.multimedia.cx/avi-and-b-frames/,
So one could now argue AVI doesnt support b frames as it doesnt store PTS and would if the application needs to know PTS (simpler players dont need to know the PTS…) to calculate the PTS based upon frame type and DTS, but that argument against AVI+b frames has a critical flaw, MPEG-PS and MPEG-TS dont store PTS for every frame either but only require it to be stored every 0.5 seconds or so. Which means that the same complicated calculate the PTS from DTS + frame types code is needed for the official MPEG format too
Old 20th October 2013, 08:45   #71  |  Link
VFR maniac
Spinner of yarns
VFR maniac's Avatar
The point is that handling of AVI with frame/picture-reordering for presentation is CODEC specific.
It is out of ranges of container.
This is already problematic from a viewpoint of container.
Also, presentation/output order of AVC and HEVC depends on POC not frame/picture types unlike the MPEG-1/2 Video and VC-1.
For instance, IDR-picture is output after subsequent P-pictures in coded order when those P-pictures have negative POC.
Old 20th October 2013, 10:19   #72  |  Link
filler56789
SuperVirus
^ Again, thanks for answering.
I had to ask, because the most recent version of the DirectShow filter "MPCVideoDec.ax" doesn't understand HEVC-in-AVI:
http://forum.doom9.org/showthread.ph...29#post1648629
Old 21st October 2013, 00:33   #73  |  Link
benwaggoner
Out of order frames were kind of a hack in ASF as well, with some weird tricks being done with timestamps in the headers that need to get ignored by the decoders.
It worked okay for VC-1, but I was one of the advocates against using ASF for Smooth streaming with H.264 because the worst-case mismatches given a 2-second GOP and up to 16 B-frames were crazy.
I think trying to stuff HEVC into old file formats would mainly be opting into pain. And what would the point even be again?
Ben Waggoner
My Compression Book
Old 21st October 2013, 00:52   #74  |  Link
filler56789
SuperVirus
I wasn't aware of that ,
thanks for the information
Hmmm, the "trick that works for VC-1", is it the same thing as storing VC-1 in Matroska by using the "VfW-compatible" mode (which is what mkvmerge does)?
Old 21st October 2013, 22:11   #75  |  Link
benwaggoner
Could be. I've actually never made a MVK file in my life. But there are only so many ways to deal with out-of-order decode in file formats not designed for it.
Ben Waggoner
My Compression Book
decoder, encoder, h.265, hevc, open-source
