Old 23rd January 2010, 10:22   #261  |  Link
The Scientist
The Scientist's Avatar
OK thanks for the feedback, another version will be out soon, I've spent this past 2 days almost re-writing everything from scratch, things (options) will look slightly different and it will act differently upon loading files.
A quick thought to the subtitles, the last version I released is now looking for the proper IFO name not an amended one like those produced from pgc.NET.
The Scientist is offline   Reply With Quote
Old 23rd January 2010, 11:17   #262  |  Link
jgawera
Are you saying we shouldn't be using pgc.net?
is there an alternative now?
Thanks
<crosses fingers for more batching stuff>
jgawera is offline   Reply With Quote
Old 23rd January 2010, 13:37   #263  |  Link
The Scientist
Well to be honest it's like this, I started updating pgc.NET, then started messing with avi.NET, then started re-writing loads of things, thought about what to do about the "IFO" naming, I just put it back to normal until I got round to finishing pgc.NET but got hung up in the last avi.NET update..... I did change pgc.NET and added batch options and auto "indexing" and subtitle extraction e.t.c. but just never got round to finishing properly. I will finish it after the next avi.NET update.
Old 23rd January 2010, 14:08   #264  |  Link
jgawera
So for now, is there a workaround?
Can I just rename an IFO file to get avi.NET to pick up the subs?
Thanks for all your efforts.
Old 23rd January 2010, 15:52   #265  |  Link
The Scientist
Yes, just rename back to normal format for that title set.
Old 26th January 2010, 09:45   #266  |  Link
The Scientist
New beta version released, please test, thanks.
Old 26th January 2010, 22:57   #267  |  Link
Last Survivor
2.7.0.0 screen.size problem
Hello,
I enjoy using avi.net, but have a problem with the latest version, 2.7, there is no 560 width on the screen.size anymore while in the past version there was. Has this size been removed on purpose, or am I having a problem (bug?). As of now, I'm back to using 2.6.5.0.
Last Survivor is offline   Reply With Quote
Old 27th January 2010, 00:02   #268  |  Link
The Scientist
No that's not a bug, it was intentional, silly me..... I'll put it back and update the beta shortly.
Old 27th January 2010, 04:19   #269  |  Link
Last Survivor
Thanks very much for a quick response and fix! I await the beta and check it out!
Old 27th January 2010, 16:17   #270  |  Link
The Scientist
OK I've done 2nd BETA now.
Old 29th January 2010, 02:11   #271  |  Link
Last Survivor
Thanks, I've installed it and it works fine. I did notice one thing different from 2.6.5.0 - when changing widths, the bitrate doesn't change in 2.7 like it does in 2.6.5.0. Its no big matter, just noticed it.
Also a suggestion (if you can), a way to add a volume control. Alot of the video I enter are very loud when previewing. Would be nice to adjust volume on the preview. But if not, no big deal, I can always mute the computer.
Also I notice you claim that .NET 3.5 is required to use, however I don't have .NET 3.5 installed (only up to 3.0). Course this would be nice if you don't change as I don't have plans as of yet to upgrade to 3.5, just wanted to pass that on in case of something missed.
Thanks again for putting 560 width back in. Much appreciated!
Old 29th January 2010, 03:44   #272  |  Link
The Scientist
Glad to hear the beta seems to be working OK.
Yeh that's right, I did like that feature so it will be put back in.
Hmmm, I never even gave that a thought, I'll sort something out.
Yeh I just say 3.5 because that's the way the project is setup in VS but if it works in 3.0 then great.
No problem.
Old 31st January 2010, 17:16   #273  |  Link
vukodlak75
Thanks for fixing some of those issues in the betas. Looking forward to the final release
"For long you live and high you fly
But only if you ride the tide
And balanced on the biggest wave
You race towards an early grave."
vukodlak75 is offline   Reply With Quote
Old 31st January 2010, 17:33   #274  |  Link
ricardo.santos
ricardo.santos's Avatar
thanks for all the bugfixing and program improvements
ricardo.santos is offline   Reply With Quote
Old 1st February 2010, 19:02   #275  |  Link
The Scientist
OK I think I've done most of what I set out to do, beta3 released. I've just got to look through again and make sure there's no over-sights though there shouldn't be anything too wrong......
Old 1st February 2010, 19:41   #276  |  Link
Metrisch
Nice, but the Speed is wrong.
Next Thing can you give more Options to End Avi.net
Likes Hilbernate Supend to Ram etc.
PS The TMP Files are not deleted after Encoding here.
Metrisch is offline   Reply With Quote
Old 1st February 2010, 21:18   #277  |  Link
The Scientist
Oh yes, silly me, I've re-uploaded the fixed version, thanks.
As for your other problem I can't comment yet until the picture gets authorised.
Old 1st February 2010, 21:55   #278  |  Link
Metrisch
Ok older Vers 2700 show's Speed like 145 fps right ?
The Beta show's Speed 133456789 think it means only 133 .
6 Digits to much
Sorry for the bad English hope you understand
Old 1st February 2010, 22:00   #279  |  Link
The Scientist
I think I understand, any chance you can email that error picture to cloneadUK@hotmail.com
Thanks
Old 1st February 2010, 22:47   #280  |  Link
Last Survivor
Thanks for the fixes. Everything seems to be working fine (bit rates change when I change the widths, etc).
