3rd November 2009, 03:39 | #9002 | Link | |
edit: now fixed in r20437. sorry for the regression... Last edited by jruggle; 3rd November 2009 at 04:00. |
3rd November 2009, 15:05 | #9003 | Link |
Thanks!
MPC-HC 2.2.1 |
3rd November 2009, 21:42 | #9004 | Link | |
Kid for Today
any chance you could make ffmpeg decode AC3 and DTS in 32float instead of 16 integer please? all the other AC3/DTS decoders in ffdshow output 32 float, this allows less rounding errors...especially when post-processing audio. |
4th November 2009, 20:29 | #9007 | Link |
Kid for Today
oh cool, you're the man! actually liba52 sounds fine already(and is 32float), but it's still very nice to have an alternative
OTOH, libdts sounds pretty bad(32 float too)...so 32float DTS in ffmpeg would be really fantastic. thanks for your prompt reply btw, much appreciated Last edited by leeperry; 4th November 2009 at 20:42. |
5th November 2009, 11:25 | #9008 | Link |
Media Control author
Hi all,
here I am again with a new beta build for HD bitstream Here is the link In this build I have fixed TrueHD and DTS HD bistream from the logs you posted. @tetsuo55 However DTS HD does not work because the HD blocks are stripped off by MPC splitter. I don't understand why, do you know something about it ? @testers I have posted an updated build of the hook tool on the same link I have PM. Please use this new build for the new tests, I have added traces on the media types used between the player and the audio card (the official MS media types are not accepted for all formats), and also on the wasapi implementation. I need you redo the tests with the new hook tool |
5th November 2009, 12:23 | #9012 | Link |
MPC-HC Project Manager
I have browsed through the source, but i do not see any stripping code.
Source is here: http://sourceforge.net/apps/trac/mpc...r/mpegsplitter
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
5th November 2009, 12:53 | #9013 | Link | |
The work to do on those is to trick the audio driver by providing LPCM format whereas it is compressed. This needs to be done after DTSHD/TrueHD/EAC3 bitstream completely work (from ffdshow to MPC wasapi audio renderer). Otherwise, there is a problem with DTS HD : the HD blocks are not stripped off correctly by ffdshow, this needs to be fixed. |
5th November 2009, 14:27 | #9015 | Link |
Let me finish breakfast and I'll give it a try. I have been ridiculously busy with work the last week and that will continue til the end of the week unfortunately. However, I'll give it a shot and see what I can do.
5th November 2009, 14:55 | #9016 | Link |
@Albain,
Here's my logs from beta26, using GeForce 9300 HDMI Audio, MKV container, and MatroskaSplitter (not Haali). TrueHD passthrough enabled, get LPCM audio... (http://pastebin.com/pastebin.php?dl=m464914fc) DTSHD passthrough enabled, get no audio... (http://pastebin.com/pastebin.php?dl=m3be23c4b) AC3 and DTS appear to bitstream ok. With DTSHD disabled i get the DTS core bitstreamed ok. Cheers |
5th November 2009, 15:12 | #9017 | Link |
@albain
http://pastebin.com/pastebin.php?dl=d2f084a8e No joy on TrueHD. Light doesn't come on for it and I get no sound at all. I'll try to do the hook tests later if I can get to it. |
5th November 2009, 15:30 | #9018 | Link |
CyberlinkUSA (Tom) just announced that PDVD9 will be updated later this month by a patch that give bitstream support for the 5xxx-cards.
So I was thinking: ''If Cyberlink can do it, why would others can't?''. Or is it a matter of a 'secret' that ATI only provided to Cyberlink? |
5th November 2009, 16:02 | #9019 | Link |
A.K.A Mangoat
Thanks albain.
I'll try the new hook tool when I have time - hopefully later on today and see how I get on. Though I expect I will still encounter issues unprotecting audiodg. Worth a try however. @ SamuriHL, are you using your Xonar for these tests at all, or is it just your ATI card? |
5th November 2009, 16:09 | #9020 | Link |
This won't work on the Xonar. The hook tool is made for that, but, the tryouts are made for the ATI card. I'll get to the hook tool later. I just have a lot of work to get through today. (and have been for the past 2 weeks, unfortunately)
