Old 3rd January 2020, 21:19   #7301  |  Link
benwaggoner
Originally Posted by Greenhorn View Post
Oddly, enabling ssim-rd by itself will disable psy-rd, but if you manually specify both they'll both be used.
Have you confirmed they are both operating, or is it possible one overrides the other?
If psy-rd + ssim-rd looks different than just psy-rd OR ssim-rd, than they are doing something together. But it wouldn't be surprising if different rd modes can't operate simultaneously. Although, algorithmically, I could see these being able to function simultaneously.
Ben Waggoner
My Compression Book
Old 4th January 2020, 08:07   #7302  |  Link
Greenhorn
Woops
That was an embarrasing mistake on my part. While the x265 CLI output will imply that both psy-rd and ssim-rd are enabled if you specify psy-rd after ssim-rd, it produces bit-identical output to not having ssim-rd enabled.
Similarly, enabling ssim-rd without doing anything to psy-rd is identical to manually disabling psy-rd. The encoder is clear about this, though, so hopefully I didn't manage to confuse anyone reading about that.
Greenhorn is offline   Reply With Quote
Old 6th January 2020, 17:26   #7303  |  Link
jlpsvk
what's better? ssim-rd or psy-rd?
AMD Ryzen 9 5950X, 32GB DDR4-3200 CL16, RTX 3060, 2TB NVMe PCIE4.0, NAS with 8x16TB HDD
jlpsvk is offline   Reply With Quote
Old 6th January 2020, 17:32   #7304  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
psy-rd... again, from my own testing ssim-rd produces visual distortions in some samples I tested long ago. ssim-rd is optimized to get the best SSIM metric values. While SSIM is (much) better than PSNR, it isn't perfect. psy-rd biases towards the energy of the source and will give, at higher values, a more subjectively looking better quality
There's also dynamic-rd but it needs vbv-bufsize and vbv-maxrate *and* you need to be hitting those for dynamic-rd to optimally do its thing
Old 6th January 2020, 23:05   #7305  |  Link
benwaggoner
--dynamic-rd is really a speed/quality tradeoff option, orthogonal to the style of RD actually being applied. dynamic-rd changes the --rd parameter when the VBV buffer is hit, so a faster, lower quality setting can be used for easier sections of the video.
Ben Waggoner
My Compression Book
Old 7th January 2020, 00:18   #7306  |  Link
benwaggoner
Say, is anyone making Windows binaries with AVX-512 support somewhere? I wanted to do some tests.
Ben Waggoner
My Compression Book
Old 7th January 2020, 01:06   #7307  |  Link
jlpsvk
just use --asm avx512
Old 7th January 2020, 02:24   #7308  |  Link
Magik Mark
What values would you suggest for vbv buffer when encoding 1080p and 2160p in 2 pass. Maybe a guide or a table. Thanks alot
Sent from my iPhone using Tapatalk
Asus ProArt Z790 - 13th Gen Intel i9 - RTX 3080 - DDR5 64GB Predator - LG OLED C9 - Yamaha A3030 - Windows 11 x64 - PotPlayerr - Lav - MadVR
Magik Mark is offline   Reply With Quote
Old 7th January 2020, 04:36   #7309  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
If you're encoding for streaming, I'd start with maxrate = 1.1x - 1.5x bitrate and bufsize = 2x bitrate.
Else set them to the profile maximums
Old 7th January 2020, 05:12   #7310  |  Link
Magik Mark
Oh I see. Can you refer me to the table detailing max buffer for every profile? Thanks
Old 7th January 2020, 08:33   #7311  |  Link
l00t
Where's my loot?
Unfortunately, according to my experiences, it won't do any good, because the CPU's clock speed will be significantly lower and will compensate the speed boost from using AVX512 (or at least this was the case for a Xeon Gold 6152).
l00t is offline   Reply With Quote
Old 7th January 2020, 09:17   #7312  |  Link
jlpsvk
yeah... avx512 produces much more heat... so probably safety issue...
Old 7th January 2020, 14:35   #7313  |  Link
LazyNcoder
Hello guys,
Any good, accurate and easy way to convert h265 HDR bt2020 to SDR bt709 using Avisynth/Vapoursynth (maybe via Staxrip)?
Something like what madVR is doing, without all the troubles.
LazyNcoder is offline   Reply With Quote
Old 7th January 2020, 15:30   #7314  |  Link
redbtn
redbtn's Avatar
Originally Posted by LazyNcoder View Post
Hello guys,
Easy, no. You can try HDR to SDR conversion, but you have to adjust settings to every movie.
redbtn is offline   Reply With Quote
Old 7th January 2020, 16:05   #7315  |  Link
LazyNcoder
Eh, thanks?
Any tutorials/tools for doing that?
I can search I know. But you could save a lot of time being wasted for me or other people reading your reply. After all, that's why we are all here. Thank you
Old 7th January 2020, 19:00   #7316  |  Link
redbtn
redbtn's Avatar
I don't have any tutorials, but some links can help you.
http://forum.doom9.org/showthread.php?p=1847425
http://forum.doom9.org/showthread.php?p=1888974
http://forum.doom9.org/showthread.php?p=1880345
http://forum.doom9.org/showthread.php?p=1800667
Old 7th January 2020, 19:16   #7317  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Hello guys,
https://forum.doom9.org/showthread.p...84#post1893684
Old 7th January 2020, 21:13   #7318  |  Link
Majorlag
For x264 look at https://en.wikipedia.org/wiki/Advanced_Video_Coding under Levels
For x265 look at https://en.wikipedia.org/wiki/High_E...y_Video_Coding or for a more detailed deep dive at https://en.wikipedia.org/wiki/High_E...ers_and_levels
For my encodes I use 1080p:--vbv-bufsize 20000 --vbv-maxrate 20000 and for 2160p:--vbv-bufsize 25000 --vbv-maxrate 25000, so that I make sure to meet DXVA requirements for some older finicky set top boxes.
Majorlag is offline   Reply With Quote
Old 7th January 2020, 22:25   #7319  |  Link
benwaggoner
By default I'll use the maximum values defined by the Profile, Tier, and Level. Wikipedia's HEVC article has a very nice table.
Sent from my SM-T837V using Tapatalk
Ben Waggoner
My Compression Book
Old 7th January 2020, 22:29   #7320  |  Link
benwaggoner
Hello guys,
There is no "accurate" way to do this. HDR and SDR masters are actually done as seperate creative passes, emphasizing different visual elements. They get approved seperately by the creatives before release.
If you want 709, best to start with the 709 source. There is almost no HDR content that isn't also available in SDR.
Ben Waggoner
My Compression Book
