Old 20th May 2010, 21:20   #1  |  Link
bartel75
Used Registerer
Filter for 'weird' interlacing?
Hello,
Could anyone suggest a nice filter to make the following video smooth again? The regular deinterlace filters (tomsmocomp, yadif, etc.) don't seem to handle this one...
Video sample (6 mb vob):
http://rapidshare.com/files/389671750/VTS_01_1.VOB
or
http://www.megaupload.com/?d=ZKRYGNXQ
Thanks in advance, and sorry for the rather vague title; I don't know how I'd call this phenomenon, so it was a bit hard to search the forum for similar cases. If you know what this is actually called, thanks for letting me know...
bartel75 is offline   Reply With Quote
Old 20th May 2010, 21:36   #2  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
The obvious question: Did you try YadifMod+NNEDI2 or TempGaussMC yet ???
Old 20th May 2010, 21:45   #3  |  Link
poisondeathray
it's actually not interlaced , and those horizontal lines are encoded into each separate field
I don't know how to improve it without blurring the crap out of it - But I would wait for some of the experts to chime in
Old 20th May 2010, 22:30   #4  |  Link
LoRd_MuldeR
Software Developer
Now that I actually have the sample, it looks like the individual fields already contain something that looks like re-sized interlace.
I doubt there is a way to "fix" this mess
Old 20th May 2010, 22:35   #5  |  Link
bartel75
Used Registerer
I guess I'll just leave it like it is, then. Thanks for your input, guys...
Old 20th May 2010, 23:04   #6  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
I think it's an old 405-line broadcast. You might get something slightly nicer by downsizing vertically (but to what size is a matter for experimentation) and then bobbing/reinterlacing. I'd have a go myself but it's bedtime...
David
wonkey_monkey is offline   Reply With Quote
Old 20th May 2010, 23:12   #7  |  Link
LoRd_MuldeR
Software Developer
A very quick experiment with this code crudely smoothed out the interlacing artifacts:
MPEG2Source("C:\Temp\!_Downloads\VTS_01_1.d2v")
SeparateFields()
Merge(Last.SelectEven(),Last.SelectOdd())
NNEDI3(field=-2)
NNEDI3(dh=true)
Old 20th May 2010, 23:37   #8  |  Link
wonkey_monkey
I tried:
lanczosresize(720,320) # guesswork; another value for height may work better
bob # also use a better bobber!
lanczosresize(720,576)
My guess: film recording telecined to 405-line videotape, then converted to PAL in a quick-and-dirty fashion.
David
Old 21st May 2010, 00:23   #9  |  Link
bartel75
Used Registerer
Very acceptable!
Very slow (0.12 fps)!
Old 21st May 2010, 00:24   #10  |  Link
bartel75
Used Registerer
Originally Posted by davidhorman View Post
I tried:
Not as nice as LoRd_MuldeR's solution, but at least the speed is within reason. Thanks!
Old 21st May 2010, 01:31   #11  |  Link
10L23r
It looks like a 1.5x upscale, so it should be
lanczosresize(720,384)
10L23r is offline   Reply With Quote
Old 21st May 2010, 10:55   #12  |  Link
2Bdecided
It's a telerecording (kinescope) from a 405-line TV broadcast. They would have pointed a film camera at a TV screen, and captured the image displayed. The camera would have been synchronised to the video signal. This is quite high quality, and has captured both fields without blurring.
The resulting film has just been transferred to DVD like any other normal feature film - the "interlacing" you see is on the film print - the transfer from film to DVD isn't "interlaced" as such. (I know it's flagged interlaced, but so are many PAL film transfers).
It's quite rare for the original interlacing to be so well intact - it would have made this film very difficult to re-transmit, because there's no way the interlacing can "line up" again, so you'd get very strange effects watching the film on a 405-line interlaced CRT. Usually the fields are blurred together a little using spot wobble, either on the TV screen as the film is being captured, or in the film scanner when the film is being converted back to video.
It must be possible to detect the original scan lines, recover the original interlaced video, deinterlace it, and upscale it (this will have about 375 visible lines - you need 576 for PAL). Deinterlacing and upscaling can be done very well in AVIsynth, but I don't think anyone has ever recovered the original scan lines from a film print like this.
yet.
...but given that the far harder problem of colour recovery from a B&W film print has been acheived, this should be a walk in the park for some clever person!
Cheers,
David..
2Bdecided is offline   Reply With Quote
Old 21st May 2010, 11:04   #13  |  Link
2Bdecided
Without anything clever, my suggestion would be...
PHP Code:
mpeg2source("405-line interlaced VTS_01_1.d2v")
bilinearresize(720,188)
nnedi2(field=0,dh=true)
spline36resize(720,576
Adjust the number 188 - higher to maintain more detail (but leave more "interlacing").
You could make it adaptive and only process the areas with movement. That would keep full resolution on stationary parts (where there's no "interlacing") - though adaptively blurring like this make look even stranger than having the whole thing look soft.
Cheers,
David.
Old 21st May 2010, 11:52   #14  |  Link
Terka
dont know if its suitable, but yuo may have a look at:
http://compression.ru/video/old_film..._shift_en.html
Terka is offline   Reply With Quote
Old 21st May 2010, 14:20   #15  |  Link
LoRd_MuldeR
Software Developer
Originally Posted by bartel75 View Post
Very acceptable!
NNEDI has some "speed -vs- quality" options you could tweak for speed. Also NNEDI2 is a lot faster than NNEDI3...
Old 21st May 2010, 14:37   #16  |  Link
bartel75
Used Registerer
I put the number just a little higher (204) and used spline36resize(720,528) to get the AR right. I'm currently encoding (at 4 fps, which is acceptable for me).
The quality is not great, but at least it's better than the original dvd!
Thank you (all of you) for your suggestions!
Old 21st May 2010, 14:39   #17  |  Link
bartel75
Used Registerer
I just noticed, based on 2Bdecided's suggestion!
Old 21st May 2010, 16:38   #18  |  Link
2Bdecided
btw, what is the DVD?
Old 21st May 2010, 17:07   #19  |  Link
bartel75
Used Registerer
http://www.amazon.com/Beethoven-Cell.../dp/B000092T5P (European R2 version)
Old 22nd May 2010, 01:19   #20  |  Link
zilog jones
zilog jones's Avatar
yet.
Field restoration from telerecordings has been done: http://en.wikipedia.org/wiki/VidFIRE
I have not seen any of the restored programmes mentioned (they don't seem to broadcast them very often) but it sounds promising.
zilog jones is offline   Reply With Quote
avisynth, filters
