10th January 2006, 18:10 | #1121 | Link | ||
BeHappy/MeGUI developer
@Doom9
Ok, I understand You, lets continue architecture discussion. 1-st let's decide what kind of service must MeGUI provide for JobProvider. IMHO:
let's decide what kind of information must Job provide. IMHO:
BeHappy - AviSynth-based audio transcoding tool Audio encoding via AviSynth On2 VP7 is great in quality but it is unusable for long-term video backup puposes! Sincerely Yours, MCPD/MCTS |
10th January 2006, 18:15 | #1122 | Link |
Yet another question:
Does we really need Load/Update functionality @ JobList? How often does You use it?
10th January 2006, 18:21 | #1123 | Link |
Some ideas about "one click mode"
I think a really reason for "one click mode" is because you can't create mux job for non-existing file in current implementation. Job.OutputFileNames main pupose is to provide list of "expected files" and JobProvider can enumerate pending jobs in JobList and refer to job output and add this job to DependsOn list
10th January 2006, 18:44 | #1124 | Link | ||||||||
clueless n00b
setup, start, stop, pause, resume, changePriority and an even that returns a StatusUpdate object. There's the VideoEncoder that implements this interface, and which will pick the proper encoder once setup with the VideoJob has been called, a derived class CommandlineVideoEncoder which is a template for a generic commandline video encoder and offers methods to read from stdout and stderr and send the read lines somewhere, and finally the XviDEncrawVideoEncoder, which handles xvid_encraw.exe. Once I'm through with that, there's going to be another derived class from CommandlineVideoEncoder called x264Encoder or something like it, which implements the particularities of x264.exe, and another one for mencoder.exe. Then if at some point somebody wants to add an encoder that makes direct use of an API, he can write a class derived from VideoEncoder, and thus the class will have to provide all the generic methods that encoding really needs. A similar approach can be adopted for audio encoding and muxing. Perhaps the IVideoEncoder could be more generalized to a IJobProcessor or whatnot.. at the moment I'll be just happy if the whole video part runs as expected.. and if I have to redo parts for the most generic approach, so be it.. it's a learning experience as well after all.
10th January 2006, 18:51 | #1125 | Link | ||
clueless n00b
10th January 2006, 19:29 | #1126 | Link | |||||||||||||
if(job is AudioJob) { // bla-bla-bla } Quote:
2) It's possible to convert DGIndex into DLL with a rich API and wrap it into MeGUI Quote:
10th January 2006, 19:58 | #1127 | Link |
Mr. Sandman
CVS Update:
0.2.3.2004 10 Jan 2006 Added --nr (noise reduction) x264 option support. (even in tooltips)
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 10th January 2006 at 20:11. |
10th January 2006, 20:01 | #1128 | Link | |||||||
clueless n00b
Similarly, adding support for Winamp aac encoder actually means you need to sit down and think about the consequences first. That encoder gives raw aac files rather than MP4. That has an effect on something completely unrelated: bitrate calculations. Add Ogg Vorbis.. affects container selection and bitrate calculation. The list is long. It would be like supporting arbitrary input types in BeHappy.. you need to know the properties of the input stream so that you can create the proper AviSynth script. If I give you a format that you cannot handle, you have to refuse further processing, don't you? Same applies to MeGUI, except here the encoder output is also limited because there can be further processing. Quote:
10th January 2006, 21:13 | #1129 | Link |
Mr. Sandman
CVS update:
0.2.3.2005 10 Jan 2006 Misc. x264 config dialog reworking
10th January 2006, 21:23 | #1130 | Link |
From my testing with my interlace detection algorithm, I think I am ready to put it into MeGUI. However, I'm not sure how to treat it (ie as a Job, or something that just runs without a job). Here's a description of what happens when doing the analysis:
you press go. It analyses about 1% of the video by generating an AviSynth script and passing through that using the AVIFile wrapper, so that no external applications are used. If the source is interlaced/film, it runs through the file again to check field order. As it is only analysing 1% of the file, it should be quite quick. Does this warrant a queued job, especially considering that if you use it in the AviSynth Creation Window, you won't want to close the window for the job to run? (I clearly think it doesn't but the same happened originally with DGIndex, so I want to try to get it right the first time). Also, what sort of integration into MeGUI is wanted with this? I was thinking OneClick mode (obviously) would do this automatically, for better script generation, and AviSynth Window. In the OneClick mode it would be transparent to the user except for a checkbox: 'Automatic deinterlacing'. For the AviSynth window, it would have a button which says 'Analyse file...'. It would then analyse the video, tell the user the source type, and adjust the deinterlace filter combobox according to which filters are appropriate, and select the recommended one. What do you think? Also, about the 'Minimize to Tray' feature request: You say 'not a button'. I implemented this a little while ago with a menu item in the view menu, because I couldn't think of anywhere else to put it. Is this good enough? |
10th January 2006, 21:30 | #1131 | Link |
Mr. Sandman
Use the [X] to minimize to tray... and File -> Exit to exit MeGUI.
10th January 2006, 21:48 | #1132 | Link | ||||
clueless n00b
10th January 2006, 22:00 | #1133 | Link | |
10th January 2006, 22:12 | #1134 | Link | |
clueless n00b
10th January 2006, 22:29 | #1136 | Link |
CVS Update:
0.2.3.2006 10 Jan 2006 Fix a crash in OneClick mode caused by audio stream's name not being set. Fix a crash in OneClick mode when it detects too many files as DGIndex's output (made it's detection of these files more selective) Load Defaults Button Relocate the profile box in the individual codec configuration windows so it is accessible from all tabs |
10th January 2006, 23:23 | #1138 | Link |
developer wannabe
AutoEncode is broken in the most recent build. Select an AVS file, a WAV file, AutoEncode, accept the default option: null ref.
System.NullReferenceException: Object reference not set to an instance of an object. at MeGUI.CommandLineGenerator.generateMP4BoxCommandline(String mp4BoxPath, MuxSettings settings, String input, String output) at MeGUI.JobUtil.generateMuxJob(VideoJob vjob, SubStream[] audioStreams, SubStream[] subtitleStreams, String chapterFile, MUXTYPE type, String output) at MeGUI.VideoUtil.generateJobSeries(String videoInput, String videoOutput, String muxedOutput, VideoCodecSettings videoSettings, AudioStream[] aStreams, SubStream[] audio, SubStream[] subtitles, String chapters, Int64 desiredSize, Int32 splitSize, Double containerOverhead, MUXTYPE muxtype) at MeGUI.AutoEncodeWindow.queueButton_Click(Object sender, EventArgs e) at System.Windows.Forms.Control.OnClick(EventArgs e) at System.Windows.Forms.Button.OnClick(EventArgs e) at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ButtonBase.WndProc(Message& m) at System.Windows.Forms.Button.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) I can't look at GPL code while at work, obviously, so can't investigate yet... Last edited by Richard Berg; 10th January 2006 at 23:28. |
10th January 2006, 23:53 | #1139 | Link |
CVS Update:
0.2.3.2008 10 Jan 2006 Update Minimize to Tray to work with conditional compiling update compile.bat to work with .NET 2.0.50727. This only works if you have that exact version, so, hopefully, someone can find a better way to do this. |
11th January 2006, 00:03 | #1140 | Link |
Just while on discussion of restructuring MeGUI. What do people think about moving all class definitions and related setters/getters to either seperate c# files or all in one c# file.
Its just if i wanted to make a change to the class, or several classes i can go to that class's c# file and make the change there without having to try and find where the getters and setters are in each dialog. Thats just personal preferance really, but i think it makes code a bit easier to work with. |
development, megui, not a help thread |
